Hello,
I am using an Arduino UNO on Windows XP with Arduino IDE 1.6.8
After not using it for a month I tried to upload a sketch into it yesterday
but did not work and instead gave me the following error:
Arduino: 1.6.8 (Windows XP), Board: "Arduino/Genuino Uno"
Error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x60
avrdude: ser_send(): write error: sorry no info avail
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x60
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x60
I even tried to upload to the board without the ATMEGA328p chip
And the board behaved the same way as with the chip.
The Rx led flashed 3 time just when the upload started
then a few flashes after long intervals and finally the upload
failed.
The heartbeat on PIN 13 when the board is powered up or reset does
not seem to work anymore.
Is my chip fried...
Or there are problems with the bootloader.
It worked just fine a month ago.
The board and port are selected correctly.
The ATMEGA16U2 seems to be fine as it successfully passed the loopback test.
The code I was trying to upload was BareMinimum
- Should I buy a new chip.
- Or should I buy a new arduino.
- Or should I flash a new bootloader on the chip.
I am a newbie at electronics.
Any help is Appreciated.
