Upload fails: "avrdude: stk500_recv(): programmer is not responding"
Continuing the discussion from Programmer is not responding:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
Sketch uses 1144 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 13 bytes (0%) of dynamic memory, leaving 2035 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\SUPERS~1\AppData\Local\Temp\arduino_build_372948/Fade.ino.hex:i
avrdude: Version 6.3-20190619
     Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
     Using Port                    : COM5
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf7
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
option enabled in File -> Preferences.
pls help fast
Hi @supersid55555. Please add a reply here on this forum thread to tell us which Arduino board you are using.
Please be as specific as possible as some Arduino boards with similar names have significant differences and the forum helpers can only provide effective assistance if we are aware of which one is being used.
If you aren't sure how to describe which board you are using, you can provide the link to the online product listing you bought the board from and we'll proceed based on the information found there.
For grins check to be sure you have the correct board selected. Some also have a selection of boot loaders. You should also try powering everything down and starting anew.
Ok so I have 2 Arduino Uno without removable microprocessor.
What do I do?
You described the Arduino board you are uploading to as "Uno". Something that can be confusing is there are multiple boards with "UNO" in their name. We need to be certain of exactly which one you have. The reason is that the problem might be caused by the IDE not being correctly configured for your specific board.
Please tell us which of the following boards you are attempting to upload to:
If you aren't sure which one you have, you can provide a picture of the board or a link to the place you bought it from and we'll see if we can identify it.
