Is it possible, if this could be made to work?
The library is qMenu and I'm trying to make it work with I2C protocol while still contemplating how to implement the rotary encoder.
Please take alook at the modified code below which compiles without issues but does not show anything on the display.
qMenuSystem example #1
1. Connect OLED in SPI mode: DATA=D8, CLOCK=D9, SS=D10
2. Compile & upload
3. Open Serial monitor (Ctrl+Shift+M)
4. Use "q", "a", "s" to move across menu ("q" = up, "a" = down, "s" = select)
#define _Digole_Serial_I2C_
#include <DigoleSerial.h>
#include <Wire.h>
#include <qMenuDisplay.h>
#include <qMenuSystem.h>
#include "TestMenu.h"
DigoleSerialDisp mydisp = DigoleSerialDisp(4, 5);
qMenuSystem menu = qMenuSystem(mydisp);
menu.InitMenu(mnuRoot, cntRoot, 1);
int keycode = 0;
int clickedItem = 0;
if (Serial.available() > 0)
switch (Serial.read())
case 97:
menu.ProcessMenu(ACTION_DOWN);
case 113:
menu.ProcessMenu(ACTION_UP);
case 115:
clickedItem = menu.ProcessMenu(ACTION_SELECT);
if (clickedItem > 0)
// Logic for Root menu
if (menu.CurrentMenu == mnuRoot)
switch (clickedItem)
case 1:
menu.InitMenu(mnuSubmenu1, cntSubmenu1, 1);
case 2:
menu.InitMenu(mnuSubmenu2, cntSubmenu2, 1);
case 3:
menu.InitMenu(mnuSubmenu3, cntSubmenu3, 1);
case 4:
menu.MessageBox("Some message!");
// Logic for Submenu 1
else if (menu.CurrentMenu == mnuSubmenu1)
case 1:
case 2:
case 3:
case 4:
case 5:
menu.MessageBox("Item clicked");
case 6:
// Logic for Submenu 2
else if (menu.CurrentMenu == mnuSubmenu2)
case 1:
menu.MessageBox("On");
case 2:
menu.MessageBox("Off");
case 3:
menu.InitMenu(mnuRoot, cntRoot, 2);
// Logic for Submenu 3
else if (menu.CurrentMenu == mnuSubmenu3)
case 1:
menu.MessageBox("Enabled");
case 2:
menu.MessageBox("Disabled");
case 3:
menu.InitMenu(mnuRoot, cntRoot, 3);
and the accompaining TestMenu.h
// required for "const char" and "PROGMEM"
#define _PROG_TYPES_COMPAT_
#include <avr/pgmspace.h>
#include <Wire.h>
// texts for menus
const char itmBack[] PROGMEM = "< Back";
const char itmOn[] PROGMEM = "On";
const char itmOff[] PROGMEM = "Off";
const char itmEnabled[] PROGMEM = "Enabled";
const char itmDisabled[] PROGMEM = "Disabled";
const char itmRoot[] PROGMEM = "Root menu";
const char itmSubmenu1[] PROGMEM = "Submenu 1";
const char itmSubmenu2[] PROGMEM = "Submenu 2";
const char itmSubmenu3[] PROGMEM = "Submenu 3";
const char itmMessageBox[] PROGMEM = "Message box";
const char itmItem1[] PROGMEM = "Item 1";
const char itmItem2[] PROGMEM = "Item 2";
const char itmItem3[] PROGMEM = "Item 3";
const char itmItem4[] PROGMEM = "Item 4";
const char itmItem5[] PROGMEM = "Item 5";
// menus - first item is menu title and it does not count toward cnt
const char * mnuRoot[] = {
itmRoot,
itmSubmenu1,itmSubmenu2,itmSubmenu3,itmMessageBox};
const int cntRoot = 4;
const char * mnuSubmenu1[] = {
itmSubmenu1,
itmItem1,itmItem2,itmItem3,itmItem4,itmItem5,itmBack};
const int cntSubmenu1 = 6;
const char * mnuSubmenu2[] = {
itmSubmenu2,
itmOn,itmOff,itmBack};
const int cntSubmenu2 = 3;
const char * mnuSubmenu3[] = {
itmSubmenu3,
itmEnabled,itmDisabled,itmBack};
const int cntSubmenu3 = 3;
Thanks again.
