Hi everyone
Regarding to this TOPIC, I want to make two Arduino on the breadboard that communicate with each other via I2C protocol.
Can we use one crystal and a pair of 22Pf cap for two ATMEGA328P on breadboard?
Many thanks
Mahdiyar
Hi everyone
Many thanks
Mahdiyar
No; one crystal and load capacitors for each Arduino.
Or you can of course set them to run off the internal oscillator; a crystal is entirely optional.
You can also look at the CKOUT fuse setting which propagates the clock signal on portB0.
The other mcu chip would also need a corresponding fuse change CKSEL to accept an external clock signal. Care is required to ensure you can always undo such changes.
I do that all the time. I do however have a crystal and caps for each.
@6v6gt's idea of passing the clock between them is a good one - never thought of doing that.
However, with the different fuse settings, I feel adding a crystal is easier.
Ask if you need help with the I2C communication.
Willem.
Get two Pro Mini clones and mount them on your breadboard.
