Arduino OV7670 + SD
Hi all. I followed a guide to use arduino uno with OV7670 and everything works fine, but I can't find a way to save the screenshots to an SD card instead of transmitting them via serial. Can anyone help me please?
The guide i followed: How to Use OV7670 Camera Module with Arduino​ Uno
I used Arduino Uno rev 3 + Arduino Ethernet Shield 2
Circuit-Diagram-for-Interfacing-OV7670-Camera-Module-with-Arduino
It's stuck in the while at line 644... Don't know why
#include <stdint.h>
#include <avr/io.h>
#include <util/twi.h>
#include <util/delay.h>
#include <avr/pgmspace.h>
 * SD FILES
#include <SPI.h>
#include <SD.h>
#define SD_PIN 4
// File file;
 * LED PINS
#define RED_LED 12
#define GREEN_LED 10
#define YELLOW_LED 9
#define BUZZER 13
#define F_CPU 16000000UL
#define vga 0
#define qvga 1
#define qqvga 2
#define yuv422 0
#define rgb565 1
#define bayerRGB 2
#define camAddr_WR 0x42
#define camAddr_RD 0x43
/* Registers */
#define REG_GAIN 0x00                 /* Gain lower 8 bits (rest in vref) */
#define REG_BLUE 0x01                 /* blue gain */
#define REG_RED 0x02                  /* red gain */
#define REG_VREF 0x03                 /* Pieces of GAIN, VSTART, VSTOP */
#define REG_COM1 0x04                 /* Control 1 */
#define COM1_CCIR656 0x40             /* CCIR656 enable */
#define REG_BAVE 0x05                 /* U/B Average level */
#define REG_GbAVE 0x06                /* Y/Gb Average level */
#define REG_AECHH 0x07                /* AEC MS 5 bits */
#define REG_RAVE 0x08                 /* V/R Average level */
#define REG_COM2 0x09                 /* Control 2 */
#define COM2_SSLEEP 0x10              /* Soft sleep mode */
#define REG_PID 0x0a                  /* Product ID MSB */
#define REG_VER 0x0b                  /* Product ID LSB */
#define REG_COM3 0x0c                 /* Control 3 */
#define COM3_SWAP 0x40                /* Byte swap */
#define COM3_SCALEEN 0x08             /* Enable scaling */
#define COM3_DCWEN 0x04               /* Enable downsamp/crop/window */
#define REG_COM4 0x0d                 /* Control 4 */
#define REG_COM5 0x0e                 /* All "reserved" */
#define REG_COM6 0x0f                 /* Control 6 */
#define REG_AECH 0x10                 /* More bits of AEC value */
#define REG_CLKRC 0x11                /* Clocl control */
#define CLK_EXT 0x40                  /* Use external clock directly */
#define CLK_SCALE 0x3f                /* Mask for internal clock scale */
#define REG_COM7 0x12 /* Control 7 */ // REG mean address.
#define COM7_RESET 0x80               /* Register reset */
#define COM7_FMT_MASK 0x38
#define COM7_FMT_VGA 0x00
#define COM7_FMT_CIF 0x20   /* CIF format */
#define COM7_FMT_QVGA 0x10  /* QVGA format */
#define COM7_FMT_QCIF 0x08  /* QCIF format */
#define COM7_RGB 0x04       /* bits 0 and 2 - RGB format */
#define COM7_YUV 0x00       /* YUV */
#define COM7_BAYER 0x01     /* Bayer format */
#define COM7_PBAYER 0x05    /* "Processed bayer" */
#define REG_COM8 0x13       /* Control 8 */
#define COM8_FASTAEC 0x80   /* Enable fast AGC/AEC */
#define COM8_AECSTEP 0x40   /* Unlimited AEC step size */
#define COM8_BFILT 0x20     /* Band filter enable */
#define COM8_AGC 0x04       /* Auto gain enable */
#define COM8_AWB 0x02       /* White balance enable */
#define COM8_AEC 0x01       /* Auto exposure enable */
#define REG_COM9 0x14       /* Control 9- gain ceiling */
#define REG_COM10 0x15      /* Control 10 */
#define COM10_HSYNC 0x40    /* HSYNC instead of HREF */
#define COM10_PCLK_HB 0x20  /* Suppress PCLK on horiz blank */
#define COM10_HREF_REV 0x08 /* Reverse HREF */
#define COM10_VS_LEAD 0x04  /* VSYNC on clock leading edge */
#define COM10_VS_NEG 0x02   /* VSYNC negative */
#define COM10_HS_NEG 0x01   /* HSYNC negative */
#define REG_HSTART 0x17     /* Horiz start high bits */
#define REG_HSTOP 0x18      /* Horiz stop high bits */
#define REG_VSTART 0x19     /* Vert start high bits */
#define REG_VSTOP 0x1a      /* Vert stop high bits */
#define REG_PSHFT 0x1b      /* Pixel delay after HREF */
#define REG_MIDH 0x1c       /* Manuf. ID high */
#define REG_MIDL 0x1d       /* Manuf. ID low */
#define REG_MVFP 0x1e       /* Mirror / vflip */
#define MVFP_MIRROR 0x20    /* Mirror image */
#define MVFP_FLIP 0x10      /* Vertical flip */
#define REG_AEW 0x24        /* AGC upper limit */
#define REG_AEB 0x25        /* AGC lower limit */
#define REG_VPT 0x26        /* AGC/AEC fast mode op region */
#define REG_HSYST 0x30      /* HSYNC rising edge delay */
#define REG_HSYEN 0x31      /* HSYNC falling edge delay */
#define REG_HREF 0x32       /* HREF pieces */
#define REG_TSLB 0x3a       /* lots of stuff */
#define TSLB_YLAST 0x04     /* UYVY or VYUY - see com13 */
#define REG_COM11 0x3b      /* Control 11 */
#define COM11_NIGHT 0x80    /* NIght mode enable */
#define COM11_NMFR 0x60     /* Two bit NM frame rate */
#define COM11_HZAUTO 0x10   /* Auto detect 50/60 Hz */
#define COM11_50HZ 0x08     /* Manual 50Hz select */
#define COM11_EXP 0x02
#define REG_COM12 0x3c     /* Control 12 */
#define COM12_HREF 0x80    /* HREF always */
#define REG_COM13 0x3d     /* Control 13 */
#define COM13_GAMMA 0x80   /* Gamma enable */
#define COM13_UVSAT 0x40   /* UV saturation auto adjustment */
#define COM13_UVSWAP 0x01  /* V before U - w/TSLB */
#define REG_COM14 0x3e     /* Control 14 */
#define COM14_DCWEN 0x10   /* DCW/PCLK-scale enable */
#define REG_EDGE 0x3f      /* Edge enhancement factor */
#define REG_COM15 0x40     /* Control 15 */
#define COM15_R10F0 0x00   /* Data range 10 to F0 */
#define COM15_R01FE 0x80   /*      01 to FE */
#define COM15_R00FF 0xc0   /*      00 to FF */
#define COM15_RGB565 0x10  /* RGB565 output */
#define COM15_RGB555 0x30  /* RGB555 output */
#define REG_COM16 0x41     /* Control 16 */
#define COM16_AWBGAIN 0x08 /* AWB gain enable */
#define REG_COM17 0x42     /* Control 17 */
#define COM17_AECWIN 0xc0  /* AEC window - must match COM4 */
#define COM17_CBAR 0x08    /* DSP Color bar */
 * This matrix defines how the colors are generated, must be
 * tweaked to adjust hue and saturation.
 * Order: v-red, v-green, v-blue, u-red, u-green, u-blue
 * They are nine-bit signed quantities, with the sign bit
 * stored in0x58.Sign for v-red is bit 0, and up from there.
#define REG_CMATRIX_BASE 0x4f
#define CMATRIX_LEN 6
#define REG_CMATRIX_SIGN 0x58
#define REG_BRIGHT 0x55   /* Brightness */
#define REG_CONTRAS 0x56  /* Contrast control */
#define REG_GFIX 0x69     /* Fix gain control */
#define REG_REG76 0x76    /* OV's name */
#define R76_BLKPCOR 0x80  /* Black pixel correction enable */
#define R76_WHTPCOR 0x40  /* White pixel correction enable */
#define REG_RGB444 0x8c   /* RGB 444 control */
#define R444_ENABLE 0x02  /* Turn on RGB444, overrides 5x5 */
#define R444_RGBX 0x01    /* Empty nibble at end */
#define REG_HAECC1 0x9f   /* Hist AEC/AGC control 1 */
#define REG_HAECC2 0xa0   /* Hist AEC/AGC control 2 */
#define REG_BD50MAX 0xa5  /* 50hz banding step limit */
#define REG_HAECC3 0xa6   /* Hist AEC/AGC control 3 */
#define REG_HAECC4 0xa7   /* Hist AEC/AGC control 4 */
#define REG_HAECC5 0xa8   /* Hist AEC/AGC control 5 */
#define REG_HAECC6 0xa9   /* Hist AEC/AGC control 6 */
#define REG_HAECC7 0xaa   /* Hist AEC/AGC control 7 */
#define REG_BD60MAX 0xab  /* 60hz banding step limit */
#define MTX1 0x4f        /* Matrix Coefficient 1 */
#define MTX2 0x50        /* Matrix Coefficient 2 */
#define MTX3 0x51        /* Matrix Coefficient 3 */
#define MTX4 0x52        /* Matrix Coefficient 4 */
#define MTX5 0x53        /* Matrix Coefficient 5 */
#define MTX6 0x54        /* Matrix Coefficient 6 */
#define MTXS 0x58        /* Matrix Coefficient Sign */
#define AWBC7 0x59       /* AWB Control 7 */
#define AWBC8 0x5a       /* AWB Control 8 */
#define AWBC9 0x5b       /* AWB Control 9 */
#define AWBC10 0x5c      /* AWB Control 10 */
#define AWBC11 0x5d      /* AWB Control 11 */
#define AWBC12 0x5e      /* AWB Control 12 */
#define REG_GFI 0x69     /* Fix gain control */
#define GGAIN 0x6a       /* G Channel AWB Gain */
#define DBLV 0x6b
#define AWBCTR3 0x6c /* AWB Control 3 */
#define AWBCTR2 0x6d /* AWB Control 2 */
#define AWBCTR1 0x6e /* AWB Control 1 */
#define AWBCTR0 0x6f /* AWB Control 0 */
struct regval_list
    uint8_t reg_num;
    uint16_t value;
const struct regval_list qvga_ov7670[] PROGMEM = {
    {REG_COM14, 0x19},
    {0x72, 0x11},
    {0x73, 0xf1},
    {REG_HSTART, 0x16},
    {REG_HSTOP, 0x04},
    {REG_HREF, 0xa4},
    {REG_VSTART, 0x02},
    {REG_VSTOP, 0x7a},
    {REG_VREF, 0x0a},
    {0xff, 0xff}, /* END MARKER */
const struct regval_list yuv422_ov7670[] PROGMEM = {
    {REG_COM7, 0x0}, /* Selects YUV mode */
    {REG_RGB444, 0}, /* No RGB444 please */
    {REG_COM1, 0},
    {REG_COM15, COM15_R00FF},
    {REG_COM9, 0x6A}, /* 128x gain ceiling; 0x8 is reserved bit */
    {0x4f, 0x80},     /* "matrix coefficient 1" */
    {0x50, 0x80},     /* "matrix coefficient 2" */
    {0x51, 0},        /* vb */
    {0x52, 0x22},     /* "matrix coefficient 4" */
    {0x53, 0x5e},     /* "matrix coefficient 5" */
    {0x54, 0x80},     /* "matrix coefficient 6" */
    {REG_COM13, COM13_UVSAT},
const struct regval_list ov7670_default_regs[] PROGMEM = {
    // from the linux driver
    {REG_COM7, COM7_RESET},
    {REG_TSLB, 0x04}, /* OV */
    {REG_COM7, 0},    /* VGA */
     * Set the hardware window.  These values from OV don't entirely
     * make sense - hstop is less than hstart.  But they work...
    {REG_HSTART, 0x13},
    {REG_HSTOP, 0x01},
    {REG_HREF, 0xb6},
    {REG_VSTART, 0x02},
    {REG_VSTOP, 0x7a},
    {REG_VREF, 0x0a},
    {REG_COM3, 0},
    {REG_COM14, 0},
    /* Mystery scaling numbers */
    {0x70, 0x3a},
    {0x71, 0x35},
    {0x72, 0x11},
    {0x73, 0xf0},
    {0xa2, /* 0x02 changed to 1*/ 1},
    {REG_COM10, 0x0},
    /* Gamma curve values */
    {0x7a, 0x20},
    {0x7b, 0x10},
    {0x7c, 0x1e},
    {0x7d, 0x35},
    {0x7e, 0x5a},
    {0x7f, 0x69},
    {0x80, 0x76},
    {0x81, 0x80},
    {0x82, 0x88},
    {0x83, 0x8f},
    {0x84, 0x96},
    {0x85, 0xa3},
    {0x86, 0xaf},
    {0x87, 0xc4},
    {0x88, 0xd7},
    {0x89, 0xe8},
    /* AGC and AEC parameters.  Note we start by disabling those features,
    then turn them only after tweaking the values. */
    {REG_COM8, COM8_FASTAEC | COM8_AECSTEP},
    {REG_GAIN, 0},
    {REG_AECH, 0},
    {REG_COM4, 0x40}, /* magic reserved bit */
    {REG_COM9, 0x18}, /* 4x gain + magic rsvd bit */
    {REG_BD50MAX, 0x05},
    {REG_BD60MAX, 0x07},
    {REG_AEW, 0x95},
    {REG_AEB, 0x33},
    {REG_VPT, 0xe3},
    {REG_HAECC1, 0x78},
    {REG_HAECC2, 0x68},
    {0xa1, 0x03}, /* magic */
    {REG_HAECC3, 0xd8},
    {REG_HAECC4, 0xd8},
    {REG_HAECC5, 0xf0},
    {REG_HAECC6, 0x90},
    {REG_HAECC7, 0x94},
    {REG_COM8, COM8_FASTAEC | COM8_AECSTEP | COM8_AGC | COM8_AEC},
    {0x30, 0},
    {0x31, 0}, // disable some delays
    /* Almost all of these are magic "reserved" values.  */
    {REG_COM5, 0x61},
    {REG_COM6, 0x4b},
    {0x16, 0x02},
    {REG_MVFP, 0x07},
    {0x21, 0x02},
    {0x22, 0x91},
    {0x29, 0x07},
    {0x33, 0x0b},
    {0x35, 0x0b},
    {0x37, 0x1d},
    {0x38, 0x71},
    {0x39, 0x2a},
    {REG_COM12, 0x78},
    {0x4d, 0x40},
    {0x4e, 0x20},
    {REG_GFIX, 0},
    /*{0x6b, 0x4a},*/ {0x74, 0x10},
    {0x8d, 0x4f},
    {0x8e, 0},
    {0x8f, 0},
    {0x90, 0},
    {0x91, 0},
    {0x96, 0},
    {0x9a, 0},
    {0xb0, 0x84},
    {0xb1, 0x0c},
    {0xb2, 0x0e},
    {0xb3, 0x82},
    {0xb8, 0x0a},
    /* More reserved magic, some of which tweaks white balance */
    {0x43, 0x0a},
    {0x44, 0xf0},
    {0x45, 0x34},
    {0x46, 0x58},
    {0x47, 0x28},
    {0x48, 0x3a},
    {0x59, 0x88},
    {0x5a, 0x88},
    {0x5b, 0x44},
    {0x5c, 0x67},
    {0x5d, 0x49},
    {0x5e, 0x0e},
    {0x6c, 0x0a},
    {0x6d, 0x55},
    {0x6e, 0x11},
    {0x6f, 0x9e}, /* it was 0x9F "9e for advance AWB" */
    {0x6a, 0x40},
    {REG_BLUE, 0x40},
    {REG_RED, 0x60},
    {REG_COM8, COM8_FASTAEC | COM8_AECSTEP | COM8_AGC | COM8_AEC | COM8_AWB},
    /* Matrix coefficients */
    {0x4f, 0x80},
    {0x50, 0x80},
    {0x51, 0},
    {0x52, 0x22},
    {0x53, 0x5e},
    {0x54, 0x80},
    {0x58, 0x9e},
    {REG_COM16, COM16_AWBGAIN},
    {REG_EDGE, 0},
    {0x75, 0x05},
    {REG_REG76, 0xe1},
    {0x4c, 0},
    {0x77, 0x01},
    {REG_COM13, /*0xc3*/ 0x48},
    {0x4b, 0x09},
    {0xc9, 0x60}, /*{REG_COM16, 0x38},*/
    {0x56, 0x40},
    {0x34, 0x11},
    {REG_COM11, COM11_EXP | COM11_HZAUTO},
    {0xa4, 0x82 /*Was 0x88*/},
    {0x96, 0},
    {0x97, 0x30},
    {0x98, 0x20},
    {0x99, 0x30},
    {0x9a, 0x84},
    {0x9b, 0x29},
    {0x9c, 0x03},
    {0x9d, 0x4c},
    {0x9e, 0x3f},
    {0x78, 0x04},
    /* Extra-weird stuff.  Some sort of multiplexor register */
    {0x79, 0x01},
    {0xc8, 0xf0},
    {0x79, 0x0f},
    {0xc8, 0x00},
    {0x79, 0x10},
    {0xc8, 0x7e},
    {0x79, 0x0a},
    {0xc8, 0x80},
    {0x79, 0x0b},
    {0xc8, 0x01},
    {0x79, 0x0c},
    {0xc8, 0x0f},
    {0x79, 0x0d},
    {0xc8, 0x20},
    {0x79, 0x09},
    {0xc8, 0x80},
    {0x79, 0x02},
    {0xc8, 0xc0},
    {0x79, 0x03},
    {0xc8, 0x40},
    {0x79, 0x05},
    {0xc8, 0x30},
    {0x79, 0x26},
void error_led(void)
    DDRB |= 32; // make sure led is output
    while (1)
    {                // wait for reset
        PORTB ^= 32; // toggle led
        _delay_ms(100);
void twiStart(void)
    TWCR = _BV(TWINT) | _BV(TWSTA) | _BV(TWEN); // send start
    while (!(TWCR & (1 << TWINT)))
        ; // wait for start to be transmitted
    if ((TWSR & 0xF8) != TW_START)
        error_led();
void twiWriteByte(uint8_t DATA, uint8_t type)
    TWDR = DATA;
    TWCR = _BV(TWINT) | _BV(TWEN);
    if ((TWSR & 0xF8) != type)
        error_led();
void twiAddr(uint8_t addr, uint8_t typeTWI)
    TWDR = addr;                   // send address
    TWCR = _BV(TWINT) | _BV(TWEN); /* clear interrupt to start transmission */
    while ((TWCR & _BV(TWINT)) == 0)
        ; /* wait for transmission */
    if ((TWSR & 0xF8) != typeTWI)
        error_led();
void writeReg(uint8_t reg, uint8_t dat)
    // send start condition
    twiStart();
    twiAddr(camAddr_WR, TW_MT_SLA_ACK);
    twiWriteByte(reg, TW_MT_DATA_ACK);
    twiWriteByte(dat, TW_MT_DATA_ACK);
    TWCR = (1 << TWINT) | (1 << TWEN) | (1 << TWSTO); // send stop
    _delay_ms(1);
static uint8_t twiRd(uint8_t nack)
    if (nack)
        if ((TWSR & 0xF8) != TW_MR_DATA_NACK)
            error_led();
        return TWDR;
        TWCR = _BV(TWINT) | _BV(TWEN) | _BV(TWEA);
        if ((TWSR & 0xF8) != TW_MR_DATA_ACK)
            error_led();
        return TWDR;
uint8_t rdReg(uint8_t reg)
    uint8_t dat;
    twiStart();
    _delay_ms(1);
    twiStart();
    twiAddr(camAddr_RD, TW_MR_SLA_ACK);
    dat = twiRd(1);
    _delay_ms(1);
    return dat;
void wrSensorRegs8_8(const struct regval_list reglist[])
    uint8_t reg_addr, reg_val;
    const struct regval_list *next = reglist;
    while ((reg_addr != 0xff) | (reg_val != 0xff))
        reg_addr = pgm_read_byte(&next->reg_num);
        reg_val = pgm_read_byte(&next->value);
        writeReg(reg_addr, reg_val);
        next++;
void setColor(void)
    wrSensorRegs8_8(yuv422_ov7670);
    // wrSensorRegs8_8(qvga_ov7670);
void setResolution(void)
    writeReg(REG_COM3, 4); // REG_COM3 enable scaling
void camInit(void)
    writeReg(0x12, 0x80);
    _delay_ms(100);
    wrSensorRegs8_8(ov7670_default_regs);
    writeReg(REG_COM10, 32); // PCLK does not toggle on HBLANK.
void arduinoUnoInut(void)
    /* Setup the 8mhz PWM clock
     * This will be on pin 11*/
    DDRB |= (1 << 3); // pin 11
    ASSR &= ~(_BV(EXCLK) | _BV(AS2));
    TCCR2A = (1 << COM2A0) | (1 << WGM21) | (1 << WGM20);
    TCCR2B = (1 << WGM22) | (1 << CS20);
    OCR2A = 0;    //(F_CPU)/(2*(X+1))
    DDRC &= ~15;  // low d0-d3 camera
    DDRD &= ~252; // d7-d4 and interrupt pins
    _delay_ms(3000);
    // set up twi for 100khz
    TWSR &= ~3; // disable prescaler for TWI
    TWBR = 72;  // set to 100khz
    // enable serial
    UBRR0H = 0;
    UBRR0L = 1;                           // 0 = 2M baud rate. 1 = 1M baud. 3 = 0.5M. 7 = 250k 207 is 9600 baud rate.
    UCSR0A |= 2;                          // double speed aysnc
    UCSR0B = (1 << RXEN0) | (1 << TXEN0); // Enable receiver and transmitter
    UCSR0C = 6;                           // async 1 stop bit 8bit char no parity bits
// void StringPgm(const char *str)
//     do
//         while (!(UCSR0A & (1 << UDRE0)))
//             ; // wait for byte to transmit
//         UDR0 = pgm_read_byte_near(str);
//     } while (pgm_read_byte_near(++str));
void captureImg(String title)
    File dataFile = SD.open(title, FILE_WRITE);
    int h, w;
    // Serial.print("\n*MAYBE?*");
    while (!(PIND & 8))
        ; // wait for high
    // Serial.print("\n*645732890*");
    while ((PIND & 8))
        ; // wait for low
    // Serial.print("\n*YES*");
    h = 240;
    while (h--)
        w = 320;
        byte dataBuffer[320];
        while (w--)
            while ((PIND & 4))
                ; // wait for low
            dataBuffer[319 - w] = (PINC & 15) | (PIND & 240);
            while (!(PIND & 4))
                ; // wait for high
            while ((PIND & 4))
                ; // wait for low
            while (!(PIND & 4))
                ; // wait for high
        dataFile.write(dataBuffer, 320);
    dataFile.close();
    // interrupts();
    delay(100);
    noInterrupts();
    arduinoUnoInut();
    camInit();
    setResolution();
    setColor();
    writeReg(0x11, 10); // Earlier it had the value:writeReg(0x11, 12); New version works better for me :) !!!!
     * SD CARD
    Serial.print("\n*WAITING SD...*");
    while (!SD.begin(SD_PIN))
        Serial.print(".");
    Serial.print("\nSD READY");
    if (SD.exists("0.bmp"))
        SD.remove("0.bmp");
    Serial.print("\n*TAKING SCREENSHOT*");
    captureImg("0.bmp");
    Serial.print("\n*SCREENSHOT READY*");
You failed to provide a wiring diagram of your setup but at least this won't work:
Pin 11 is part of the SPI interface used for the SD card you must not use it otherwise.
Thank you very much for your help. The diagram is in the guide I used now I'll update the message.
Yes yesterday after hours of debug I understood that SD is busy while reading the cam but you gived me the missing piece. I am not an expert and I can't understand how to avoid this problem
I forgot to say that I am using Arduino Uno rev 3 + Arduino Ethernet Shield 2
I found this article so i tried to use the following setup without the external SD module and it seems to work, but the .bmp files are corrupted.
ArduDiagram
OV7670 Camera module with SD card module
on Arduino Uno.
Author: Hardik Kalasua (hardik.kalasua@gmail.com)
NOTE: Much of the code is based on insights from the
work of the user named ComputerNerd.
NOTE: OV7670 SCCB interface does't work if XCLK not provided.
** Thanks to all the android forums and stack exchange answers. :)
#include <Wire.h>
#include <SD.h>
#define YELLOW_LED 13
#define SD_PIN 4
void Init_YUV422() {
  WriteOV7670(0x12, 0x00);  //COM7
  WriteOV7670(0x8C, 0x00);  //RGB444
  WriteOV7670(0x04, 0x00);  //COM1
  WriteOV7670(0x40, 0xC0);  //COM15
  WriteOV7670(0x14, 0x1A);  //COM9
  WriteOV7670(0x3D, 0x40);  //COM13
void Init_QVGA() {
  WriteOV7670(0x0C, 0x04);  //COM3 - Enable Scaling
  WriteOV7670(0x3E, 0x19);  //COM14
  WriteOV7670(0x72, 0x11);  //
  WriteOV7670(0x73, 0xF1);  //
  WriteOV7670(0x17, 0x16);  //HSTART
  WriteOV7670(0x18, 0x04);  //HSTOP
  WriteOV7670(0x32, 0xA4);  //HREF
  WriteOV7670(0x19, 0x02);  //VSTART
  WriteOV7670(0x1A, 0x7A);  //VSTOP
  WriteOV7670(0x03, 0x0A);  //VREF
void Init_OV7670() {
  //Reset All Register Values
  WriteOV7670(0x12, 0x80);
  delay(100);
  WriteOV7670(0x3A, 0x04);  //TSLB
  WriteOV7670(0x13, 0xC0);  //COM8
  WriteOV7670(0x00, 0x00);  //GAIN
  WriteOV7670(0x10, 0x00);  //AECH
  WriteOV7670(0x0D, 0x40);  //COM4
  WriteOV7670(0x14, 0x18);  //COM9
  WriteOV7670(0x24, 0x95);  //AEW
  WriteOV7670(0x25, 0x33);  //AEB
  WriteOV7670(0x13, 0xC5);  //COM8
  WriteOV7670(0x6A, 0x40);  //GGAIN
  WriteOV7670(0x01, 0x40);  //BLUE
  WriteOV7670(0x02, 0x60);  //RED
  WriteOV7670(0x13, 0xC7);  //COM8
  WriteOV7670(0x41, 0x08);  //COM16
  WriteOV7670(0x15, 0x20);  //COM10 - PCLK does not toggle on HBLANK
void WriteOV7670(byte regID, byte regVal) {
  // Slave 7-bit address is 0x21.
  // R/W bit set automatically by Wire functions
  // dont write 0x42 or 0x43 for slave address
  Wire.beginTransmission(0x21);
  // Reset all register values
  Wire.write(regID);
  Wire.write(regVal);
  Wire.endTransmission();
  delay(1);
void ReadOV7670(byte regID) {
  // Reading from a register is done in two steps
  // Step 1: Write register address to the slave
  // from which data is to be read.
  Wire.beginTransmission(0x21);  // 7-bit Slave address
  Wire.write(regID);             // reading from register 0x11
  // Step 2: Read 1 byte from Slave
  Wire.requestFrom(0x21, 1);
  Serial.print("Read request Status:");
  Serial.println(Wire.available());
  Serial.print(regID, HEX);
  Serial.print(":");
  Serial.println(Wire.read(), HEX);
void XCLK_SETUP(void) {
  pinMode(9, OUTPUT);  //Set pin 9 to output
  //Initialize timer 1
  //WGM13, WGM12, WGM11 & WGM10 bits SET- Fast PWM mode
  //COM1A0 SET- Toggle OC1A on compare match
  TCCR1A = (1 << COM1A0) | (1 << WGM11) | (1 << WGM10);
  //SET CS10 bit for clock select with no prescaling
  TCCR1B = (1 << WGM13) | (1 << WGM12) | (1 << CS10);
  //Output Compare Register 1A(OCR1A) = 0
  //This will lead to a match on every clock cycle
  //Toggle OC1A output pin on every match instance
  //Therefore, the generated waveform will have half
  //the frequency of the driving clock i.e. 8Mhz
  //OC1A pin- PB1 (alternate functn) pin i.e. Arduino pin 9
  OCR1A = 0;
// Two Wire Interface Setup
// Sets the frequency of the SCL line
// Default is 100KHz so we won't use this function
void TWI_SETUP(void) {
  //Set prescaler bits in TWI Status Register (TWSR) to 0
  TWSR &= ~3;
  //Set SCL frequency to 100KHz
  //SCLfreq = CPUfreq/(16 + 2(TWBR) - 4^(TWPS))
  //TWBR = 72, TWPS(prescaler) = 0
  TWBR = 72;
void OV7670_PINS(void) {
  //Setup Data input pins and Interrupt pins
  //DDRC bits 3:0 = 0 =>  bits configured as Data Inputs
  //DDRC 3:0 - A3,A2,A1,A0
  DDRC &= ~15;  //low d0-d3 camera
  //~(0b11111100) = 0b00000011
  //make DDRD 7:2 = 0 => Inputs
  //d7-d4 as data inputs, d3-INT1 is VSYNC and d2-INT0 is PCLK
  DDRD &= ~252;
void QVGA_Image(String title) {
  int h, w;
  if (SD.exists(title)) {
    SD.remove(title);
  while (!(PIND & 8))
    ;  //wait for high
  while ((PIND & 8))
    ;  //wait for low
  h = 240;
  while (h--) {
    w = 320;
    while (w--) {
      while ((PIND & 4))
        ;  //wait for low
      while (!(PIND & 4))
        ;  //wait for high
      while ((PIND & 4))
        ;  //wait for low
      while (!(PIND & 4))
        ;  //wait for high
  dataFile.close();
  delay(100);
  noInterrupts();  //Disable all interrupts
  XCLK_SETUP();    //Setup 8MHz clock at pin 11
  OV7670_PINS();   // Setup Data-in and interrupt pins from camera
  TWI_SETUP();  // Setup SCL for 100KHz
  //pinMode(YELLOW_LED, OUTPUT);
  pinMode(SD_PIN, OUTPUT);
  interrupts();
  //digitalWrite(YELLOW_LED, HIGH);
  Wire.begin();
  Init_OV7670();
  Init_QVGA();
  Init_YUV422();
  WriteOV7670(0x11, 0x1F);  //Range 00-1F
  // noInterrupts();
  Serial.print("\nStart SD");
  // pinMode(SD_PIN, OUTPUT);
  while (!SD.begin(SD_PIN)) {
    Serial.print(".");
    delay(100);
  Serial.print("\nSD started");
  Serial.print("\nScreen start 1");
  QVGA_Image("TEST.bmp");
  Serial.print("\nFINISH");
  //digitalWrite(YELLOW_LED, LOW);
The Ethernet shield uses D4 as the SD card CS signal (which you have in your code too. You must not use that pin for the camera connection.
You might change D11 to D9 but you have to adapt the PWM to timer 1 (instead of 2).
The change for pin 4 is not that easy. You probably have to rewire pin 4 of the shield to another pin on the UNO. I would suggest pin 10 as you don't use the Ethernet chip on the shield anyway (and you don't have any other spare pin). You cannot get away without rewiring. I hope the OV7670 is 5V tolerant (the specification says something different) as you didn't use level converters.
Your tutorial page says:
If the UNO gives 5V output to GPIO then use Level Shifter.
The UNO always has a 5V level on it's GPIOs so the page should have level converters for all outputs.
D4 is still used for the camera connection but is the CS of the SD card.
Hi pylon, thank you again for your help.
I can not understand, UNO rev 3 has both 3v3 and 5v. I am actually using 3v3 not 5v.
There was the problem, not only D4 but D11 too. This is my actual setup:
NEWARDUGRAM
My actual code:
#include <stdint.h>
#include <avr/io.h>
#include <Wire.h>
#include <SD.h>
#define SD_PIN 4
// pin 10
#define VSYNC 10
// pin 9
#define XCLK 9
#define vga 0
#define qvga 1
#define qqvga 2
#define yuv422 0
#define rgb565 1
#define bayerRGB 2
/* Registers */
#define DBLV 0x6b
struct regval_list
    uint8_t reg_num;
    uint16_t value;
    {REG_COM14, 0x19},
    {0x72, 0x11},
    {0x73, 0xf1},
    {REG_HSTART, 0x16},
    {REG_HSTOP, 0x04},
    {REG_HREF, 0xa4},
    {REG_VSTART, 0x02},
    {REG_VSTOP, 0x7a},
    {REG_VREF, 0x0a},
    {REG_COM1, 0},
    {0x51, 0},        /* vb */
    {REG_HSTART, 0x13},
    {REG_HSTOP, 0x01},
    {REG_HREF, 0xb6},
    {REG_VSTART, 0x02},
    {REG_VSTOP, 0x7a},
    {REG_VREF, 0x0a},
    {REG_COM3, 0},
    {REG_COM14, 0},
    {0x70, 0x3a},
    {0x71, 0x35},
    {0x72, 0x11},
    {0x73, 0xf0},
    {REG_COM10, 0x0},
    {0x7a, 0x20},
    {0x7b, 0x10},
    {0x7c, 0x1e},
    {0x7d, 0x35},
    {0x7e, 0x5a},
    {0x7f, 0x69},
    {0x80, 0x76},
    {0x81, 0x80},
    {0x82, 0x88},
    {0x83, 0x8f},
    {0x84, 0x96},
    {0x85, 0xa3},
    {0x86, 0xaf},
    {0x87, 0xc4},
    {0x88, 0xd7},
    {0x89, 0xe8},
    {REG_GAIN, 0},
    {REG_AECH, 0},
    {REG_AEW, 0x95},
    {REG_AEB, 0x33},
    {REG_VPT, 0xe3},
    {REG_HAECC1, 0x78},
    {REG_HAECC2, 0x68},
    {REG_HAECC3, 0xd8},
    {REG_HAECC4, 0xd8},
    {REG_HAECC5, 0xf0},
    {REG_HAECC6, 0x90},
    {REG_HAECC7, 0x94},
    {0x30, 0},
    {REG_COM5, 0x61},
    {REG_COM6, 0x4b},
    {0x16, 0x02},
    {REG_MVFP, 0x07},
    {0x21, 0x02},
    {0x22, 0x91},
    {0x29, 0x07},
    {0x33, 0x0b},
    {0x35, 0x0b},
    {0x37, 0x1d},
    {0x38, 0x71},
    {0x39, 0x2a},
    {REG_COM12, 0x78},
    {0x4d, 0x40},
    {0x4e, 0x20},
    {REG_GFIX, 0},
    {0x8d, 0x4f},
    {0x8e, 0},
    {0x8f, 0},
    {0x90, 0},
    {0x91, 0},
    {0x96, 0},
    {0x9a, 0},
    {0xb0, 0x84},
    {0xb1, 0x0c},
    {0xb2, 0x0e},
    {0xb3, 0x82},
    {0xb8, 0x0a},
    {0x43, 0x0a},
    {0x44, 0xf0},
    {0x45, 0x34},
    {0x46, 0x58},
    {0x47, 0x28},
    {0x48, 0x3a},
    {0x59, 0x88},
    {0x5a, 0x88},
    {0x5b, 0x44},
    {0x5c, 0x67},
    {0x5d, 0x49},
    {0x5e, 0x0e},
    {0x6c, 0x0a},
    {0x6d, 0x55},
    {0x6e, 0x11},
    {0x6a, 0x40},
    {REG_BLUE, 0x40},
    {REG_RED, 0x60},
    {0x4f, 0x80},
    {0x50, 0x80},
    {0x51, 0},
    {0x52, 0x22},
    {0x53, 0x5e},
    {0x54, 0x80},
    {0x58, 0x9e},
    {REG_EDGE, 0},
    {0x75, 0x05},
    {REG_REG76, 0xe1},
    {0x4c, 0},
    {0x77, 0x01},
    {0x4b, 0x09},
    {0x56, 0x40},
    {0x34, 0x11},
    {0x96, 0},
    {0x97, 0x30},
    {0x98, 0x20},
    {0x99, 0x30},
    {0x9a, 0x84},
    {0x9b, 0x29},
    {0x9c, 0x03},
    {0x9d, 0x4c},
    {0x9e, 0x3f},
    {0x78, 0x04},
    {0x79, 0x01},
    {0xc8, 0xf0},
    {0x79, 0x0f},
    {0xc8, 0x00},
    {0x79, 0x10},
    {0xc8, 0x7e},
    {0x79, 0x0a},
    {0xc8, 0x80},
    {0x79, 0x0b},
    {0xc8, 0x01},
    {0x79, 0x0c},
    {0xc8, 0x0f},
    {0x79, 0x0d},
    {0xc8, 0x20},
    {0x79, 0x09},
    {0xc8, 0x80},
    {0x79, 0x02},
    {0xc8, 0xc0},
    {0x79, 0x03},
    {0xc8, 0x40},
    {0x79, 0x05},
    {0xc8, 0x30},
    {0x79, 0x26},
    while (1)
    {                // wait for reset
        _delay_ms(100);
void twiStart(void)
        error_led();
    TWDR = DATA;
        error_led();
        error_led();
    twiStart();
    _delay_ms(1);
    if (nack)
            error_led();
        return TWDR;
            error_led();
        return TWDR;
    uint8_t dat;
    twiStart();
    _delay_ms(1);
    twiStart();
    dat = twiRd(1);
    _delay_ms(1);
    return dat;
        next++;
void setColor(void)
void camInit(void)
    _delay_ms(100);
    cli(); // disable interrupts
    // // DDRB |= (1 << 3); // pin 11
    DDRB |= (1 << 1); // pin 9
    // // TCCR2A = (1 << COM2A0) | (1 << WGM21) | (1 << WGM20);  // pin 11
    // // TCCR2B = (1 << WGM22) | (1 << CS20);  // pin 11
    // // OCR2A = 0;   //(F_CPU)/(2*(X+1))  // pin 11
    TCCR1A = (1 << COM1A0) | (1 << WGM11) | (1 << WGM10); // pin 9
    TCCR1B = (1 << WGM13) | (1 << WGM12) | (1 << CS10);   // pin 9
    OCR1A = 0;                                            // pin 9
    // old pin4
    //// DDRD &= ~252; // d7-d4 and interrupt pins
    // pin 10
    DDRB &= ~(1 << DDB2);
    _delay_ms(3000);
    // enable serial
    UBRR0H = 0;
    do
static void captureImg(String title)
    int h, w;
        SD.remove(title);
    delay(100);
    while (!(PIND & 8))
        ; // wait for high
    while ((PIND & 8))
        ; // wait for low
    h = 240;
    while (h--)
        w = 320;
        while (w--)
            while ((PIND & 4))
                ; // wait for low
            while (!(PIND & 4))
                ; // wait for high
            while ((PIND & 4))
                ; // wait for low
            while (!(PIND & 4))
                ; // wait for high
    dataFile.flush();
    dataFile.close();
    delay(100);
    arduinoUnoInut();
    camInit();
    setResolution();
    setColor();
    interrupts();
    delay(100);
        Serial.print(".");
    Serial.print("\nWaiting cam warm up");
    delay(15000);
    // cli();
    captureImg("1.bmp");
    captureImg("2.bmp");
    captureImg("3.bmp");
    captureImg("4.bmp");
    captureImg("5.bmp");
    captureImg("6.bmp");
    // sei();
All works as expected, now there is another big problem:
the images need to be processed, so i found in the article i mentioned some python code. This is my new script:
import csv
import binascii
import os
input_dir = './'
output_dir = './output/'
temp_dir = './tmp/'
for filename in os.listdir(input_dir):
    if filename.endswith(".BMP"):
        print("Processing file " + filename)
        f = open(os.path.join(input_dir, filename), "rb")
        myhex = []
        size = 0
        mybytes = []
        try:
            byte = f.read(1)
            mybytes.append(byte)
            myhex.append(byte.hex())
            while byte != b'':
                byte = f.read(1)
                size = size + 1
                if byte != b'':
        finally:
            f.close()
        print("Total file size in bytes: " + str(size))
        print("Total Length of bytes array: " + str(len(mybytes)))
        print("Total Length of hex array: " + str(len(myhex)))
        print("Creating csv...")
        with open(os.path.join(temp_dir, 'eggs.csv'), 'w', newline='') as csvfile:
            spamwriter = csv.writer(csvfile, delimiter=' ', quotechar='|')
            spamwriter.writerow(myhex)
        print("Reading csv...")
        columnvector = []
        with open(os.path.join(temp_dir, 'eggs.csv'), 'r', newline='') as csvfile:
            csvreader = csv.reader(csvfile,delimiter=' ', quotechar='|')
            for row in csvreader:
                columnvector.append(row)
        headers =['42','4D','36','84','03','00','00','00','00','00','36','00','00','00','28','00','00','00',
        '40','01','00','00','F0','00','00','00','01','00','18','00','00','00','00','00','00','84','03','00','C5','00',
        '00','00','C5','00','00','00','00','00','00','00','00','00','00','00']
        hexArray=[]
        for i in range(0,76800):
            data = columnvector[0][i]
            hexArray.extend([data,data,data])
        output_filename = "NEW_" + filename
        print("Creating image " + output_filename + "...")
        with open(os.path.join(output_dir, output_filename), 'wb') as f:
            f.write(binascii.unhexlify(''.join(headers)))
            f.write(binascii.unhexlify(''.join(hexArray)))
        os.remove(temp_dir + 'eggs.csv')
        print("Done!")
I did the same things that the old files did:
Python_files.zip (3,1 KB)
But it's the same with a new script:
# Script that generates images from raw data of OV7670
# It finds all the .bmp in the input dir and saves it as images
# in output dir
# Author: Luca B
from PIL import Image
import os
width = 320
height = 240
input_dir = "./"
output_dir = "./"
        # Open the binary file in reading mode
        with open(os.path.join(input_dir, filename), "rb") as f:
            # Read all byte from the file
            raw_data = f.read()
        # Create a pil image with raw data
        img = Image.frombytes("L", (width, height), raw_data)
        # Save the image in JPEG format
        img.save(output_dir + "NEW_" + filename + ".jpg")
print("Done!")
And this is the result:
NEW_0
I can't understand why... The image is partially visible in all the tests
The Uno has a 3.3V pin to supply power to 3.3V devices, but has 5V on the I/O output pins.
If you do not use logic level converters, you will eventually destroy the camera, the Arduino, or both. Some damage has probably already occurred.
Oh ok, now i understand. Sorry for the confusion and thank you and pylon for his patience. I'll fix it asap and let you know if it's working after changing the OV7670 too.
The Uno has a tiny amount of memory and is a really poor choice for anything to do with images.
You will have a lot more fun with the ESP32-CAM, which is a much, much more powerful processor, and has a decent camera as well. 3.3V only! Cheaper, too.
Yes but ESP32 doesn't have ethernet and I must use it in this project. Do you think that I should burn ov7670 and replace it with esp32cam? I need ethernet to send images to an API
One possibility is to use the ESP32 WiFi to send images to something with an ethernet port. There is web server example code for the ESP32 that streams images.
I used ESP32 WIFI before and it's like going to war without shoes, even with original ESP. Sometimes it disconnects or gives problems with older routers, I must use ethernet at least for this project
Using the Uno Rev 3 for anything to do with images is also like going to war without shoes.
Now I know it... Later i have to add a PN532 NFC i hope that Arduino can handle it too
Highly unlikely. If it works, run out and buy a Lottery ticket before the magic wears off ...
FYI:
There is a process to designing a working electronic project and a microcontroller project is more complex because of something known as resources.
  • I/O pins
  • output sink/source current & port total current
  • SRAM and Flash
  • clock frequency and instruction time
  • etc. (SPI, USART, I2C) and ability of internal logic (fabric) to map peripheral signals to I/O pins without conflict
  • more...
The good designer always starts with the complete project needs often called requirements. This may be represented as connected blocks in a sketch along with a written indicator of what function of the project the block represents; example, an LCD block may be connected to an I2C block with e lines, but the LCD block also needs power and ground connections.
Once you have a statement of the project and a visual, you can start looking toward the uC board that will satisfy your total need. Often at this point I will consult the Internet for similar projects and note what uC was utilized in the solution. If a full solution is not found in one project but is partially found in 2 of more projects, be prepared for additional effort and sweat to combine the multiple projects.
Now, a more detail diagram, state logic of detailed flowchart.
Always prototype all your parts with example code to validate stuff works. If you can afford multiple sensors and uC boards, these provide a safety-net for times when parts release "magic smoke" or when you are unsure a part is good.
After all testing, draw a complete schematic ... real schematic showing everything.
The schematic should point you toward a starting point in final uC/board selection.
There is lots of guessing at this point if you have to combine sketches: always go for more SRAM and faster clock when making a decision on purchase. Ex: If 3 sketches that use UNO are going to be combined, opt for a Mega board as Uno may simply not offer the memory required.
Thank you veru much mrburnette, this is my first arduino project next time I will try to follow your instructions before starting.
However I have news, this is my new setup:
As i can see, the only pins that are used as OUTPUT are A2 and D10, so I have used the level shifter I bought as you told and changed the OV7670.
This is the result from sd card and my python script:
This is the result from the original Serial transmission method:
f
What's the problem now?.. Can't understand
This is my SD card sketch:
#include <stdint.h>
#include <avr/io.h>
#include <Wire.h>
#include <SD.h>
#define SD_PIN 4
// pin 10
#define VSYNC 10
// pin 9
#define XCLK 9
static int count = 1;
// #define F_CPU 16000000UL
#define vga 0
#define qvga 1
#define qqvga 2
#define yuv422 0
#define rgb565 1
#define bayerRGB 2
/* Registers */
#define DBLV 0x6b
struct regval_list
    uint8_t reg_num;
    uint16_t value;
    {REG_COM14, 0x19},
    {0x72, 0x11},
    {0x73, 0xf1},
    {REG_HSTART, 0x16},
    {REG_HSTOP, 0x04},
    {REG_HREF, 0xa4},
    {REG_VSTART, 0x02},
    {REG_VSTOP, 0x7a},
    {REG_VREF, 0x0a},
    {REG_COM1, 0},
    {0x51, 0},        /* vb */
    {REG_HSTART, 0x13},
    {REG_HSTOP, 0x01},
    {REG_HREF, 0xb6},
    {REG_VSTART, 0x02},
    {REG_VSTOP, 0x7a},
    {REG_VREF, 0x0a},
    {REG_COM3, 0},
    {REG_COM14, 0},
    {0x70, 0x3a},
    {0x71, 0x35},
    {0x72, 0x11},
    {0x73, 0xf0},
    {REG_COM10, 0x0},
    {0x7a, 0x20},
    {0x7b, 0x10},
    {0x7c, 0x1e},
    {0x7d, 0x35},
    {0x7e, 0x5a},
    {0x7f, 0x69},
    {0x80, 0x76},
    {0x81, 0x80},
    {0x82, 0x88},
    {0x83, 0x8f},
    {0x84, 0x96},
    {0x85, 0xa3},
    {0x86, 0xaf},
    {0x87, 0xc4},
    {0x88, 0xd7},
    {0x89, 0xe8},
    {REG_GAIN, 0},
    {REG_AECH, 0},
    {REG_AEW, 0x95},
    {REG_AEB, 0x33},
    {REG_VPT, 0xe3},
    {REG_HAECC1, 0x78},
    {REG_HAECC2, 0x68},
    {REG_HAECC3, 0xd8},
    {REG_HAECC4, 0xd8},
    {REG_HAECC5, 0xf0},
    {REG_HAECC6, 0x90},
    {REG_HAECC7, 0x94},
    {0x30, 0},
    {REG_COM5, 0x61},
    {REG_COM6, 0x4b},
    {0x16, 0x02},
    {REG_MVFP, 0x07},
    {0x21, 0x02},
    {0x22, 0x91},
    {0x29, 0x07},
    {0x33, 0x0b},
    {0x35, 0x0b},
    {0x37, 0x1d},
    {0x38, 0x71},
    {0x39, 0x2a},
    {REG_COM12, 0x78},
    {0x4d, 0x40},
    {0x4e, 0x20},
    {REG_GFIX, 0},
    {0x8d, 0x4f},
    {0x8e, 0},
    {0x8f, 0},
    {0x90, 0},
    {0x91, 0},
    {0x96, 0},
    {0x9a, 0},
    {0xb0, 0x84},
    {0xb1, 0x0c},
    {0xb2, 0x0e},
    {0xb3, 0x82},
    {0xb8, 0x0a},
    {0x43, 0x0a},
    {0x44, 0xf0},
    {0x45, 0x34},
    {0x46, 0x58},
    {0x47, 0x28},
    {0x48, 0x3a},
    {0x59, 0x88},
    {0x5a, 0x88},
    {0x5b, 0x44},
    {0x5c, 0x67},
    {0x5d, 0x49},
    {0x5e, 0x0e},
    {0x6c, 0x0a},
    {0x6d, 0x55},
    {0x6e, 0x11},
    {0x6a, 0x40},
    {REG_BLUE, 0x40},
    {REG_RED, 0x60},
    {0x4f, 0x80},
    {0x50, 0x80},
    {0x51, 0},
    {0x52, 0x22},
    {0x53, 0x5e},
    {0x54, 0x80},
    {0x58, 0x9e},
    {REG_EDGE, 0},
    {0x75, 0x05},
    {REG_REG76, 0xe1},
    {0x4c, 0},
    {0x77, 0x01},
    {0x4b, 0x09},
    {0x56, 0x40},
    {0x34, 0x11},
    {0x96, 0},
    {0x97, 0x30},
    {0x98, 0x20},
    {0x99, 0x30},
    {0x9a, 0x84},
    {0x9b, 0x29},
    {0x9c, 0x03},
    {0x9d, 0x4c},
    {0x9e, 0x3f},
    {0x78, 0x04},
    {0x79, 0x01},
    {0xc8, 0xf0},
    {0x79, 0x0f},
    {0xc8, 0x00},
    {0x79, 0x10},
    {0xc8, 0x7e},
    {0x79, 0x0a},
    {0xc8, 0x80},
    {0x79, 0x0b},
    {0xc8, 0x01},
    {0x79, 0x0c},
    {0xc8, 0x0f},
    {0x79, 0x0d},
    {0xc8, 0x20},
    {0x79, 0x09},
    {0xc8, 0x80},
    {0x79, 0x02},
    {0xc8, 0xc0},
    {0x79, 0x03},
    {0xc8, 0x40},
    {0x79, 0x05},
    {0xc8, 0x30},
    {0x79, 0x26},
    while (1)
    {                // wait for reset
        _delay_ms(100);
void twiStart(void)
        error_led();
    TWDR = DATA;
        error_led();
        error_led();
    twiStart();
    _delay_ms(1);
    if (nack)
            error_led();
        return TWDR;
            error_led();
        return TWDR;
    uint8_t dat;
    twiStart();
    _delay_ms(1);
    twiStart();
    dat = twiRd(1);
    _delay_ms(1);
    return dat;
        next++;
void setColor(void)
void camInit(void)
    _delay_ms(100);
    OCR1A = 0;                                            // pin 9
    // old pin4
    // pin 10
    _delay_ms(3000);
    // enable serial
    UBRR0H = 0;
    Serial.print("\nStart screen " + title);
    int h, w;
        SD.remove(title);
    delay(100);
    while (!(PIND & 8))
        ; // wait for high
    while ((PIND & 8))
        ; // wait for low
    h = 240;
    while (h--)
        w = 320;
        while (w--)
            while ((PIND & 4))
                ; // wait for low
            while (!(PIND & 4))
                ; // wait for high
            while ((PIND & 4))
                ; // wait for low
            while (!(PIND & 4))
                ; // wait for high
    dataFile.flush();
    dataFile.close();
    delay(100);
    Serial.print("\nFinish screen " + title);
    arduinoUnoInut();
    camInit();
    setResolution();
    setColor();
    interrupts();
    delay(100);
        Serial.print(".");
    delay(15000);
    captureImg(String(count) + ".bmp");
    count++;
    if (count > 10) {
        while(1);
This is the Serial code:
#include <stdint.h>
#include <avr/io.h>
// pin 10
#define VSYNC 10
// pin 9
#define XCLK 9
#define vga 0
#define qvga 1
#define qqvga 2
#define yuv422 0
#define rgb565 1
#define bayerRGB 2
/* Registers */
#define DBLV 0x6b
struct regval_list
    uint8_t reg_num;
    uint16_t value;
    {REG_COM14, 0x19},
    {0x72, 0x11},
    {0x73, 0xf1},
    {REG_HSTART, 0x16},
    {REG_HSTOP, 0x04},
    {REG_HREF, 0xa4},
    {REG_VSTART, 0x02},
    {REG_VSTOP, 0x7a},
    {REG_VREF, 0x0a},
    {REG_COM1, 0},
    {0x51, 0}, /* vb */
    {REG_HSTART, 0x13},
    {REG_HSTOP, 0x01},
    {REG_HREF, 0xb6},
    {REG_VSTART, 0x02},
    {REG_VSTOP, 0x7a},
    {REG_VREF, 0x0a},
    {REG_COM3, 0},
    {REG_COM14, 0},
    {0x70, 0x3a},
    {0x71, 0x35},
    {0x72, 0x11},
    {0x73, 0xf0},
    {REG_COM10, 0x0},
    {0x7a, 0x20},
    {0x7b, 0x10},
    {0x7c, 0x1e},
    {0x7d, 0x35},
    {0x7e, 0x5a},
    {0x7f, 0x69},
    {0x80, 0x76},
    {0x81, 0x80},
    {0x82, 0x88},
    {0x83, 0x8f},
    {0x84, 0x96},
    {0x85, 0xa3},
    {0x86, 0xaf},
    {0x87, 0xc4},
    {0x88, 0xd7},
    {0x89, 0xe8},
    {REG_GAIN, 0},
    {REG_AECH, 0},
    {REG_AEW, 0x95},
    {REG_AEB, 0x33},
    {REG_VPT, 0xe3},
    {REG_HAECC1, 0x78},
    {REG_HAECC2, 0x68},
    {REG_HAECC3, 0xd8},
    {REG_HAECC4, 0xd8},
    {REG_HAECC5, 0xf0},
    {REG_HAECC6, 0x90},
    {REG_HAECC7, 0x94},
    {0x30, 0},
    {REG_COM5, 0x61},
    {REG_COM6, 0x4b},
    {0x16, 0x02},
    {REG_MVFP, 0x07},
    {0x21, 0x02},
    {0x22, 0x91},
    {0x29, 0x07},
    {0x33, 0x0b},
    {0x35, 0x0b},
    {0x37, 0x1d},
    {0x38, 0x71},
    {0x39, 0x2a},
    {REG_COM12, 0x78},
    {0x4d, 0x40},
    {0x4e, 0x20},
    {REG_GFIX, 0},
    {0x8d, 0x4f},
    {0x8e, 0},
    {0x8f, 0},
    {0x90, 0},
    {0x91, 0},
    {0x96, 0},
    {0x9a, 0},
    {0xb0, 0x84},
    {0xb1, 0x0c},
    {0xb2, 0x0e},
    {0xb3, 0x82},
    {0xb8, 0x0a},
    {0x43, 0x0a},
    {0x44, 0xf0},
    {0x45, 0x34},
    {0x46, 0x58},
    {0x47, 0x28},
    {0x48, 0x3a},
    {0x59, 0x88},
    {0x5a, 0x88},
    {0x5b, 0x44},
    {0x5c, 0x67},
    {0x5d, 0x49},
    {0x5e, 0x0e},
    {0x6c, 0x0a},
    {0x6d, 0x55},
    {0x6e, 0x11},
    {0x6a, 0x40},
    {REG_BLUE, 0x40},
    {REG_RED, 0x60},
    {0x4f, 0x80},
    {0x50, 0x80},
    {0x51, 0},
    {0x52, 0x22},
    {0x53, 0x5e},
    {0x54, 0x80},
    {0x58, 0x9e},
    {REG_EDGE, 0},
    {0x75, 0x05},
    {REG_REG76, 0xe1},
    {0x4c, 0},
    {0x77, 0x01},
    {0x4b, 0x09},
    {0x56, 0x40},
    {0x34, 0x11},
    {0x96, 0},
    {0x97, 0x30},
    {0x98, 0x20},
    {0x99, 0x30},
    {0x9a, 0x84},
    {0x9b, 0x29},
    {0x9c, 0x03},
    {0x9d, 0x4c},
    {0x9e, 0x3f},
    {0x78, 0x04},
    {0x79, 0x01},
    {0xc8, 0xf0},
    {0x79, 0x0f},
    {0xc8, 0x00},
    {0x79, 0x10},
    {0xc8, 0x7e},
    {0x79, 0x0a},
    {0xc8, 0x80},
    {0x79, 0x0b},
    {0xc8, 0x01},
    {0x79, 0x0c},
    {0xc8, 0x0f},
    {0x79, 0x0d},
    {0xc8, 0x20},
    {0x79, 0x09},
    {0xc8, 0x80},
    {0x79, 0x02},
    {0xc8, 0xc0},
    {0x79, 0x03},
    {0xc8, 0x40},
    {0x79, 0x05},
    {0xc8, 0x30},
    {0x79, 0x26},
    while (1)
    { // wait for reset
        _delay_ms(100);
void twiStart(void)
        error_led();
    TWDR = DATA;
        error_led();
        error_led();
    twiStart();
    _delay_ms(1);
    if (nack)
            error_led();
        return TWDR;
            error_led();
        return TWDR;
    uint8_t dat;
    twiStart();
    _delay_ms(1);
    twiStart();
    dat = twiRd(1);
    _delay_ms(1);
    return dat;
        next++;
void setColor(void)
void camInit(void)
    _delay_ms(100);
    OCR1A = 0;                                            // pin 9
    // old pin4
    // pin 10
    _delay_ms(3000);
    // enable serial
    UBRR0H = 0;
    do
static void captureImg(uint16_t wg, uint16_t hg)
    uint16_t y, x;
    StringPgm(PSTR("*RDY*"));
    while (!(PIND & 8))
        ; // wait for high
    while ((PIND & 8))
        ; // wait for low
    y = hg;
    while (y--)
        x = wg;
        // while (!(PIND & 256));//wait for high
        while (x--)
            while ((PIND & 4))
                ; // wait for low
            UDR0 = (PINC & 15) | (PIND & 240);
            while (!(PIND & 4))
                ; // wait for high
            while ((PIND & 4))
                ; // wait for low
            while (!(PIND & 4))
                ; // wait for high
        //  while ((PIND & 256));//wait for low
    _delay_ms(100);
    arduinoUnoInut();
    camInit();
    setResolution();
    setColor();
    captureImg(320, 240);
I count 2 inputs and 1 bi-directional.
But, I an unfamiliar with the camera module used with an Uno; which is to say my guess is code (or timing in the code.)
A forum search lead me to:
OV7670 with both arduino uno and now mega - Using Arduino / Sensors - Arduino Forum
Which indicates success: start with that codebase is my suggestion.
At this juncture, having used the Uno directly connected to the camera, I can not know if the camera module is still "good." Only wiring correctly with known working code will provide you with confidence your hardware is working correctly.
Arducam OV7670 0.3 Megapixel Camera Module for Arduino Boards - Arducam
