Hello,
I am trying to install the PLC tools and get the following error: Arduino PLC IE Tools setup wizard ended prematurely.
Can someone please help?
Here is my MSI log:
=== Verbose logging started: 12/1/2023 9:42:20 Build type: SHIP UNICODE 5.00.10011.00 Calling process: C:\Windows\system32\msiexec.exe ===
MSI (c) (38:B8) [09:42:20:386]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (38:E8) [09:42:20:403]: Resetting cached policy values
MSI (c) (38:E8) [09:42:20:404]: Machine policy value 'Debug' is 0
MSI (c) (38:E8) [09:42:20:404]: ******* RunEngine:
******* Product: Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi
******* Action:
******* CommandLine: **********
MSI (c) (38:E8) [09:42:20:405]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (38:E8) [09:42:20:585]: Access database with Impersonation
MSI (c) (38:E8) [09:42:20:585]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi' against software restriction policy
MSI (c) (38:E8) [09:42:20:585]: SOFTWARE RESTRICTION POLICY: c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi has a digital signature
MSI (c) (38:E8) [09:42:20:704]: SOFTWARE RESTRICTION POLICY: c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (38:E8) [09:42:20:712]: Cloaking enabled.
MSI (c) (38:E8) [09:42:20:712]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (38:E8) [09:42:20:716]: End dialog not enabled
MSI (c) (38:E8) [09:42:20:716]: Original package ==> c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi
MSI (c) (38:E8) [09:42:20:716]: Package we're running from ==> c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi
MSI (c) (38:E8) [09:42:20:717]: APPCOMPAT: Compatibility mode property overrides found.
MSI (c) (38:E8) [09:42:20:718]: APPCOMPAT: looking for appcompat database entry with ProductCode '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}'.
MSI (c) (38:E8) [09:42:20:718]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (38:E8) [09:42:20:724]: MSCOREE not loaded loading copy from system32
MSI (c) (38:E8) [09:42:20:728]: Machine policy value 'TransformsSecure' is 0
MSI (c) (38:E8) [09:42:20:728]: User policy value 'TransformsAtSource' is 0
MSI (c) (38:E8) [09:42:20:728]: Machine policy value 'DisablePatch' is 0
MSI (c) (38:E8) [09:42:20:728]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (38:E8) [09:42:20:728]: Machine policy value 'DisableMsi' is 0
MSI (c) (38:E8) [09:42:20:728]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (38:E8) [09:42:20:729]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (38:E8) [09:42:20:729]: Running product '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}' with user privileges: It's not assigned.
MSI (c) (38:E8) [09:42:20:729]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (38:E8) [09:42:20:729]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (38:E8) [09:42:20:729]: APPCOMPAT: looking for appcompat database entry with ProductCode '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}'.
MSI (c) (38:E8) [09:42:20:729]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (38:E8) [09:42:20:729]: Transforms are not secure.
MSI (c) (38:E8) [09:42:20:729]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'c:\temp\log.txt'.
MSI (c) (38:E8) [09:42:20:729]: Command Line: CURRENTDIRECTORY=c:\Users\crouxel\Downloads CLIENTUILEVEL=0 CLIENTPROCESSID=37688
MSI (c) (38:E8) [09:42:20:729]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{65AF645C-F762-4063-B5D8-409D543D4022}'.
MSI (c) (38:E8) [09:42:20:729]: Product Code passed to Engine.Initialize: ''
MSI (c) (38:E8) [09:42:20:729]: Product Code from property table before transforms: '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}'
MSI (c) (38:E8) [09:42:20:729]: Product Code from property table after transforms: '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}'
MSI (c) (38:E8) [09:42:20:729]: Product not registered: beginning first-time install
MSI (c) (38:E8) [09:42:20:729]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (c) (38:E8) [09:42:20:729]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (38:E8) [09:42:20:729]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (38:E8) [09:42:20:729]: Adding new sources is allowed.
MSI (c) (38:E8) [09:42:20:730]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (c) (38:E8) [09:42:20:730]: Package name extracted from package path: 'Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi'
MSI (c) (38:E8) [09:42:20:730]: Package to be registered: 'Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi'
MSI (c) (38:E8) [09:42:20:730]: Note: 1: 2205 2: 3: Error
MSI (c) (38:E8) [09:42:20:730]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (38:E8) [09:42:20:730]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (38:E8) [09:42:20:730]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (38:E8) [09:42:20:730]: Running product '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}' with user privileges: It's not assigned.
MSI (c) (38:E8) [09:42:20:730]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'c:\Users\crouxel\Downloads'.
MSI (c) (38:E8) [09:42:20:730]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (c) (38:E8) [09:42:20:730]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '37688'.
MSI (c) (38:E8) [09:42:20:731]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (c) (38:E8) [09:42:20:731]: TRANSFORMS property is now:
MSI (c) (38:E8) [09:42:20:731]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (c) (38:E8) [09:42:20:731]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming
MSI (c) (38:E8) [09:42:20:731]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\Favorites
MSI (c) (38:E8) [09:42:20:731]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (38:E8) [09:42:20:732]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Documents
MSI (c) (38:E8) [09:42:20:732]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (38:E8) [09:42:20:732]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (38:E8) [09:42:20:732]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (38:E8) [09:42:20:732]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (38:E8) [09:42:20:733]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (38:E8) [09:42:20:733]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Local
MSI (c) (38:E8) [09:42:20:733]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\Pictures
MSI (c) (38:E8) [09:42:20:733]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (38:E8) [09:42:20:734]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (38:E8) [09:42:20:734]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (38:E8) [09:42:20:734]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (38:E8) [09:42:20:735]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (38:E8) [09:42:20:735]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\Desktop
MSI (c) (38:E8) [09:42:20:736]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (38:E8) [09:42:20:736]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (c) (38:E8) [09:42:20:737]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (c) (38:E8) [09:42:20:745]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI (c) (38:E8) [09:42:20:745]: PROPERTY CHANGE: Adding AdminUser property. Its value is '1'.
MSI (c) (38:E8) [09:42:20:745]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (38:E8) [09:42:20:745]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (38:E8) [09:42:20:745]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Windows User'.
MSI (c) (38:E8) [09:42:20:745]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi'.
MSI (c) (38:E8) [09:42:20:745]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi'.
MSI (c) (38:E8) [09:42:20:745]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (38:E8) [09:42:20:745]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'c:\Users\crouxel\Downloads\'.
MSI (c) (38:E8) [09:42:20:745]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'c:\Users\crouxel\Downloads\'.
MSI (c) (38:B8) [09:42:20:746]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== Logging started: 12/1/2023 9:42:20 ===
MSI (c) (38:E8) [09:42:20:759]: Note: 1: 2205 2: 3: PatchPackage
MSI (c) (38:E8) [09:42:20:759]: Machine policy value 'DisableRollback' is 0
MSI (c) (38:E8) [09:42:20:760]: User policy value 'DisableRollback' is 0
MSI (c) (38:E8) [09:42:20:760]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (38:E8) [09:42:20:761]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (c) (38:E8) [09:42:20:761]: APPCOMPAT: [DetectVersionLaunchCondition] Launch condition already passes.
MSI (c) (38:E8) [09:42:20:763]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (c) (38:E8) [09:42:20:763]: Doing action: INSTALL
Action start 9:42:20: INSTALL.
MSI (c) (38:E8) [09:42:20:763]: UI Sequence table 'InstallUISequence' is present and populated.
MSI (c) (38:E8) [09:42:20:763]: Running UISequence
MSI (c) (38:E8) [09:42:20:763]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (c) (38:E8) [09:42:20:763]: Doing action: FindRelatedProducts
Action start 9:42:20: FindRelatedProducts.
Action ended 9:42:20: FindRelatedProducts. Return value 1.
MSI (c) (38:E8) [09:42:20:764]: Doing action: PrepareDlg
Action start 9:42:20: PrepareDlg.
MSI (c) (38:B8) [09:42:20:769]: Note: 1: 2205 2: 3: Error
MSI (c) (38:B8) [09:42:20:769]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 2898
Info 2898.For WixUI_Font_Normal textstyle, the system created a 'Tahoma' font, in 0 character set, of 13 pixels height.
MSI (c) (38:B8) [09:42:20:771]: Note: 1: 2205 2: 3: Error
MSI (c) (38:B8) [09:42:20:771]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 2898
Info 2898.For WixUI_Font_Bigger textstyle, the system created a 'Tahoma' font, in 0 character set, of 19 pixels height.
Action ended 9:42:20: PrepareDlg. Return value 1.
MSI (c) (38:E8) [09:42:20:809]: Doing action: AppSearch
Action start 9:42:20: AppSearch.
MSI (c) (38:E8) [09:42:20:813]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (c) (38:E8) [09:42:20:813]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Arduino PLC IDE Tools 3: 2
Action ended 9:42:20: AppSearch. Return value 1.
MSI (c) (38:E8) [09:42:20:813]: Doing action: LaunchConditions
Action start 9:42:20: LaunchConditions.
Action ended 9:42:20: LaunchConditions. Return value 1.
MSI (c) (38:E8) [09:42:20:817]: Doing action: ValidateProductID
Action start 9:42:20: ValidateProductID.
Action ended 9:42:20: ValidateProductID. Return value 1.
MSI (c) (38:E8) [09:42:20:820]: Doing action: CostInitialize
Action start 9:42:20: CostInitialize.
MSI (c) (38:E8) [09:42:20:822]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (c) (38:E8) [09:42:20:823]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'c:\'.
MSI (c) (38:E8) [09:42:20:823]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
Action ended 9:42:20: CostInitialize. Return value 1.
MSI (c) (38:E8) [09:42:20:823]: Doing action: FileCost
Action start 9:42:20: FileCost.
MSI (c) (38:E8) [09:42:20:826]: Note: 1: 2205 2: 3: MsiAssembly
MSI (c) (38:E8) [09:42:20:826]: Note: 1: 2205 2: 3: Class
MSI (c) (38:E8) [09:42:20:826]: Note: 1: 2205 2: 3: Extension
MSI (c) (38:E8) [09:42:20:826]: Note: 1: 2205 2: 3: TypeLib
Action ended 9:42:20: FileCost. Return value 1.
MSI (c) (38:E8) [09:42:20:826]: Doing action: CostFinalize
Action start 9:42:20: CostFinalize.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (c) (38:E8) [09:42:20:829]: Note: 1: 2205 2: 3: Patch
MSI (c) (38:E8) [09:42:20:829]: Note: 1: 2205 2: 3: Condition
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'c:\'.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Modifying WindowsFolder property. Its current value is 'C:\WINDOWS\'. Its new value: 'c:\WINDOWS\'.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Modifying LocalAppDataFolder property. Its current value is 'C:\Users\crouxel\AppData\Local\'. Its new value: 'c:\Users\crouxel\AppData\Local\'.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Adding APITDIR property. Its value is 'c:\Users\crouxel\AppData\Local\T\'.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Adding APIT_USER property. Its value is 'c:\Users\crouxel\AppData\Local\T\U\'.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Adding APIT_ARDUINO15 property. Its value is 'c:\Users\crouxel\AppData\Local\T\A\'.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Modifying ProgramFiles64Folder property. Its current value is 'C:\Program Files\'. Its new value: 'c:\Program Files\'.
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'c:\Program Files\Arduino PLC IDE Tools\'.
MSI (c) (38:E8) [09:42:20:829]: Target path resolution complete. Dumping Directory table...
MSI (c) (38:E8) [09:42:20:829]: Note: target paths subject to change (via custom actions or browsing)
MSI (c) (38:E8) [09:42:20:829]: Dir (target): Key: TARGETDIR , Object: c:\
MSI (c) (38:E8) [09:42:20:829]: Dir (target): Key: WindowsFolder , Object: c:\WINDOWS\
MSI (c) (38:E8) [09:42:20:829]: Dir (target): Key: LocalAppDataFolder , Object: c:\Users\crouxel\AppData\Local\
MSI (c) (38:E8) [09:42:20:829]: Dir (target): Key: APITDIR , Object: c:\Users\crouxel\AppData\Local\T\
MSI (c) (38:E8) [09:42:20:829]: Dir (target): Key: APIT_USER , Object: c:\Users\crouxel\AppData\Local\T\U\
MSI (c) (38:E8) [09:42:20:829]: Dir (target): Key: APIT_ARDUINO15 , Object: c:\Users\crouxel\AppData\Local\T\A\
MSI (c) (38:E8) [09:42:20:829]: Dir (target): Key: ProgramFiles64Folder , Object: c:\Program Files\
MSI (c) (38:E8) [09:42:20:829]: Dir (target): Key: INSTALLDIR , Object: c:\Program Files\Arduino PLC IDE Tools\
MSI (c) (38:E8) [09:42:20:829]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI (c) (38:E8) [09:42:20:829]: Note: 1: 2205 2: 3: MsiAssembly
MSI (c) (38:E8) [09:42:20:829]: Note: 1: 2228 2: 3: MsiAssembly 4: SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`, `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
Action ended 9:42:20: CostFinalize. Return value 1.
MSI (c) (38:E8) [09:42:20:829]: Doing action: MigrateFeatureStates
Action start 9:42:20: MigrateFeatureStates.
Action ended 9:42:20: MigrateFeatureStates. Return value 0.
MSI (c) (38:E8) [09:42:20:833]: Skipping action: MaintenanceWelcomeDlg (condition is false)
MSI (c) (38:E8) [09:42:20:833]: Skipping action: ResumeDlg (condition is false)
MSI (c) (38:E8) [09:42:20:833]: Doing action: WelcomeDlg
Action start 9:42:20: WelcomeDlg.
MSI (c) (38:A0) [09:42:20:867]: Note: 1: 2205 2: 3: _RemoveFilePath
MSI (c) (38:A0) [09:42:20:869]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (c) (38:A0) [09:42:20:869]: Note: 1: 2205 2: 3: BindImage
MSI (c) (38:A0) [09:42:20:869]: Note: 1: 2205 2: 3: ProgId
MSI (c) (38:A0) [09:42:20:869]: Note: 1: 2205 2: 3: PublishComponent
MSI (c) (38:A0) [09:42:20:869]: Note: 1: 2205 2: 3: SelfReg
MSI (c) (38:A0) [09:42:20:869]: Note: 1: 2205 2: 3: Extension
MSI (c) (38:A0) [09:42:20:869]: Note: 1: 2205 2: 3: Font
MSI (c) (38:A0) [09:42:20:869]: Note: 1: 2205 2: 3: Shortcut
MSI (c) (38:A0) [09:42:20:869]: Note: 1: 2205 2: 3: Class
MSI (c) (38:A0) [09:42:20:869]: Note: 1: 2205 2: 3: Icon
MSI (c) (38:A0) [09:42:20:869]: Note: 1: 2205 2: 3: TypeLib
MSI (c) (38:A0) [09:42:20:869]: Note: 1: 2727 2:
MSI (c) (38:B8) [09:42:23:727]: Note: 1: 2205 2: 3: Error
MSI (c) (38:B8) [09:42:23:727]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 2898
Info 2898.For WixUI_Font_Title textstyle, the system created a 'Tahoma' font, in 0 character set, of 14 pixels height.
MSI (c) (38:B8) [09:42:25:470]: Doing action: WixUIValidatePath
Action start 9:42:25: WixUIValidatePath.
MSI (c) (38:48) [09:42:25:502]: Invoking remote custom action. DLL: C:\Users\crouxel\AppData\Local\Temp\MSICBC1.tmp, Entrypoint: ValidatePath
MSI (c) (38:F4) [09:42:25:503]: Cloaking enabled.
MSI (c) (38:F4) [09:42:25:503]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (38:F4) [09:42:25:503]: Connected to service for CA interface.
MSI (c) (38!18) [09:42:25:548]: PROPERTY CHANGE: Adding WIXUI_INSTALLDIR_VALID property. Its value is '1'.
Action ended 9:42:25: WixUIValidatePath. Return value 1.
MSI (c) (38:B8) [09:42:26:080]: Note: 1: 2727 2:
MSI (c) (38:B8) [09:42:26:568]: Note: 1: 2727 2:
Action ended 9:42:26: WelcomeDlg. Return value 1.
MSI (c) (38:E8) [09:42:26:815]: Doing action: ProgressDlg
Action start 9:42:26: ProgressDlg.
Action ended 9:42:26: ProgressDlg. Return value 1.
MSI (c) (38:E8) [09:42:26:863]: Doing action: ExecuteAction
Action start 9:42:26: ExecuteAction.
MSI (c) (38:E8) [09:42:26:866]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
MSI (c) (38:E8) [09:42:26:866]: Grabbed execution mutex.
MSI (c) (38:E8) [09:42:26:866]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (c) (38:E8) [09:42:26:866]: Switching to server: INSTALLDIR="c:\Program Files\Arduino PLC IDE Tools\" APITDIR="c:\Users\crouxel\AppData\Local\T\" APIT_ARDUINO15="c:\Users\crouxel\AppData\Local\T\A\" APIT_USER="c:\Users\crouxel\AppData\Local\T\U\" TARGETDIR="c:\" CURRENTDIRECTORY="c:\Users\crouxel\Downloads" CLIENTUILEVEL="0" CLIENTPROCESSID="37688" USERNAME="Windows User" SOURCEDIR="c:\Users\crouxel\Downloads\" ACTION="INSTALL" EXECUTEACTION="INSTALL" ROOTDRIVE="c:\" INSTALLLEVEL="1" WIXUI_INSTALLDIR_VALID="1" SECONDSEQUENCE="1" ADDLOCAL=DefaultFeature
MSI (s) (00:A8) [09:42:26:881]: Running installation inside multi-package transaction c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi
MSI (s) (00:A8) [09:42:26:881]: Grabbed execution mutex.
MSI (s) (00:34) [09:42:26:882]: Resetting cached policy values
MSI (s) (00:34) [09:42:26:882]: Machine policy value 'Debug' is 0
MSI (s) (00:34) [09:42:26:882]: ******* RunEngine:
******* Product: c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi
******* Action: INSTALL
MSI (s) (00:34) [09:42:26:883]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (00:34) [09:42:27:013]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (s) (00:34) [09:42:27:014]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
MSI (s) (00:34) [09:42:27:014]: Note: 1: 1715 2: Arduino PLC IDE Tools
MSI (s) (00:34) [09:42:27:014]: Note: 1: 2205 2: 3: Error
MSI (s) (00:34) [09:42:27:014]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1715
MSI (s) (00:34) [09:42:27:014]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed Arduino PLC IDE Tools".
MSI (s) (00:34) [09:42:27:080]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 246.
MSI (s) (00:34) [09:42:27:080]: Access database with Impersonation
MSI (s) (00:34) [09:42:27:081]: File will have security applied from OpCode.
MSI (s) (00:34) [09:42:27:260]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi' against software restriction policy
MSI (s) (00:34) [09:42:27:260]: SOFTWARE RESTRICTION POLICY: c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi has a digital signature
MSI (s) (00:34) [09:42:27:331]: SOFTWARE RESTRICTION POLICY: c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (00:34) [09:42:27:331]: MSCOREE not loaded loading copy from system32
MSI (s) (00:34) [09:42:27:334]: End dialog not enabled
MSI (s) (00:34) [09:42:27:334]: Original package ==> c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi
MSI (s) (00:34) [09:42:27:334]: Package we're running from ==> C:\WINDOWS\Installer\8e96fc0.msi
MSI (s) (00:34) [09:42:27:335]: APPCOMPAT: Compatibility mode property overrides found.
MSI (s) (00:34) [09:42:27:335]: APPCOMPAT: looking for appcompat database entry with ProductCode '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}'.
MSI (s) (00:34) [09:42:27:335]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (00:34) [09:42:27:338]: Machine policy value 'TransformsSecure' is 0
MSI (s) (00:34) [09:42:27:338]: User policy value 'TransformsAtSource' is 0
MSI (s) (00:34) [09:42:27:339]: Machine policy value 'DisablePatch' is 0
MSI (s) (00:34) [09:42:27:339]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (00:34) [09:42:27:339]: Machine policy value 'DisableMsi' is 0
MSI (s) (00:34) [09:42:27:339]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (00:34) [09:42:27:339]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (00:34) [09:42:27:339]: Running product '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}' with user privileges: It's not assigned.
MSI (s) (00:34) [09:42:27:339]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (00:34) [09:42:27:339]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (00:34) [09:42:27:340]: APPCOMPAT: looking for appcompat database entry with ProductCode '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}'.
MSI (s) (00:34) [09:42:27:340]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (00:34) [09:42:27:340]: Transforms are not secure.
MSI (s) (00:34) [09:42:27:340]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'c:\temp\log.txt'.
MSI (s) (00:34) [09:42:27:340]: Command Line: INSTALLDIR=c:\Program Files\Arduino PLC IDE Tools\ APITDIR=c:\Users\crouxel\AppData\Local\T\ APIT_ARDUINO15=c:\Users\crouxel\AppData\Local\T\A\ APIT_USER=c:\Users\crouxel\AppData\Local\T\U\ TARGETDIR=c:\ CURRENTDIRECTORY=c:\Users\crouxel\Downloads CLIENTUILEVEL=0 CLIENTPROCESSID=37688 USERNAME=Windows User SOURCEDIR=c:\Users\crouxel\Downloads\ ACTION=INSTALL EXECUTEACTION=INSTALL ROOTDRIVE=c:\ INSTALLLEVEL=1 WIXUI_INSTALLDIR_VALID=1 SECONDSEQUENCE=1 ADDLOCAL=DefaultFeature ACTION=INSTALL
MSI (s) (00:34) [09:42:27:340]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{65AF645C-F762-4063-B5D8-409D543D4022}'.
MSI (s) (00:34) [09:42:27:340]: Product Code passed to Engine.Initialize: ''
MSI (s) (00:34) [09:42:27:340]: Product Code from property table before transforms: '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}'
MSI (s) (00:34) [09:42:27:340]: Product Code from property table after transforms: '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}'
MSI (s) (00:34) [09:42:27:340]: Product not registered: beginning first-time install
MSI (s) (00:34) [09:42:27:340]: Product {003FD1AF-576E-4F8F-8967-0BC8019AE1A3} is not managed.
MSI (s) (00:34) [09:42:27:340]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (00:34) [09:42:27:340]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (00:34) [09:42:27:340]: MSI_LUA: Elevation required to install product, will prompt for credentials
MSI (s) (00:34) [09:42:29:274]: MSI_LUA: Credential Request return = 0x0
MSI (s) (00:34) [09:42:29:274]: MSI_LUA: Elevated credential consent provided. Install will run elevated
MSI (s) (00:34) [09:42:29:274]: Note: 1: 2205 2: 3: MsiPackageCertificate
MSI (s) (00:34) [09:42:29:274]: Note: 1: 2205 2: 3: MsiDigitalCertificate
MSI (s) (00:34) [09:42:29:274]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (s) (00:34) [09:42:29:274]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (00:34) [09:42:29:274]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (00:34) [09:42:29:274]: Adding new sources is allowed.
MSI (s) (00:34) [09:42:29:274]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (s) (00:34) [09:42:29:274]: Package name extracted from package path: 'Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi'
MSI (s) (00:34) [09:42:29:275]: Package to be registered: 'Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi'
MSI (s) (00:34) [09:42:29:275]: Note: 1: 2205 2: 3: Error
MSI (s) (00:34) [09:42:29:276]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (00:34) [09:42:29:276]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (00:34) [09:42:29:276]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (00:34) [09:42:29:276]: Product installation will be elevated because user provided elevated credentials and product is being installed per-machine.
MSI (s) (00:34) [09:42:29:276]: Running product '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}' with elevated privileges: Product is assigned.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'c:\Program Files\Arduino PLC IDE Tools\'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding APITDIR property. Its value is 'c:\Users\crouxel\AppData\Local\T\'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding APIT_ARDUINO15 property. Its value is 'c:\Users\crouxel\AppData\Local\T\A\'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding APIT_USER property. Its value is 'c:\Users\crouxel\AppData\Local\T\U\'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'c:\'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'c:\Users\crouxel\Downloads'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '37688'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Windows User'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'c:\Users\crouxel\Downloads\'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'c:\'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding WIXUI_INSTALLDIR_VALID property. Its value is '1'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'DefaultFeature'.
MSI (s) (00:34) [09:42:29:276]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (00:34) [09:42:29:276]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'c83c2c29f0dbcb4f868c7b52c7eddaf8'.
MSI (s) (00:34) [09:42:29:277]: RESTART MANAGER: Session opened.
MSI (s) (00:34) [09:42:29:277]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (s) (00:34) [09:42:29:277]: Engine has iefSecondSequence set to true.
MSI (s) (00:34) [09:42:29:277]: TRANSFORMS property is now:
MSI (s) (00:34) [09:42:29:277]: PROPERTY CHANGE: Deleting SOURCEDIR property. Its current value is 'c:\Users\crouxel\Downloads\'.
MSI (s) (00:34) [09:42:29:277]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (00:34) [09:42:29:279]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming
MSI (s) (00:34) [09:42:29:281]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\Favorites
MSI (s) (00:34) [09:42:29:282]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (00:34) [09:42:29:284]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Documents
MSI (s) (00:34) [09:42:29:286]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (00:34) [09:42:29:288]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (00:34) [09:42:29:290]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (00:34) [09:42:29:292]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (00:34) [09:42:29:292]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (00:34) [09:42:29:294]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Local
MSI (s) (00:34) [09:42:29:296]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\Pictures
MSI (s) (00:34) [09:42:29:299]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (00:34) [09:42:29:300]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (00:34) [09:42:29:302]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
MSI (s) (00:34) [09:42:29:304]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu
MSI (s) (00:34) [09:42:29:306]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (00:34) [09:42:29:309]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (00:34) [09:42:29:311]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (00:34) [09:42:29:313]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
MSI (s) (00:34) [09:42:29:315]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\AppData\Roaming\Microsoft\Windows\Start Menu
MSI (s) (00:34) [09:42:29:317]: SHELL32::SHGetFolderPath returned: C:\Users\crouxel\Desktop
MSI (s) (00:34) [09:42:29:319]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (s) (00:34) [09:42:29:319]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (s) (00:34) [09:42:29:320]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (00:34) [09:42:29:323]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI (s) (00:34) [09:42:29:323]: PROPERTY CHANGE: Adding AdminUser property. Its value is '1'.
MSI (s) (00:34) [09:42:29:323]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (00:34) [09:42:29:323]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (s) (00:34) [09:42:29:323]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (00:34) [09:42:29:323]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (00:34) [09:42:29:323]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\WINDOWS\Installer\8e96fc0.msi'.
MSI (s) (00:34) [09:42:29:323]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'c:\Users\crouxel\Downloads\Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi'.
MSI (s) (00:34) [09:42:29:323]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (s) (00:34) [09:42:29:323]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
MSI (s) (00:34) [09:42:29:323]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (00:34) [09:42:29:323]: Machine policy value 'DisableRollback' is 0
MSI (s) (00:34) [09:42:29:323]: User policy value 'DisableRollback' is 0
MSI (s) (00:34) [09:42:29:323]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (s) (00:34) [09:42:29:324]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
MSI (s) (00:34) [09:42:29:324]: APPCOMPAT: [DetectVersionLaunchCondition] Launch condition already passes.
MSI (s) (00:34) [09:42:29:324]: Doing action: INSTALL
Action start 9:42:29: INSTALL.
MSI (s) (00:34) [09:42:29:326]: Running ExecuteSequence
MSI (s) (00:34) [09:42:29:326]: Doing action: FindRelatedProducts
Action start 9:42:29: FindRelatedProducts.
MSI (s) (00:34) [09:42:29:328]: Skipping FindRelatedProducts action: already done on client side
Action ended 9:42:29: FindRelatedProducts. Return value 0.
MSI (s) (00:34) [09:42:29:329]: Doing action: AppSearch
Action start 9:42:29: AppSearch.
MSI (s) (00:34) [09:42:29:331]: Skipping AppSearch action: already done on client side
Action ended 9:42:29: AppSearch. Return value 0.
MSI (s) (00:34) [09:42:29:331]: Doing action: LaunchConditions
Action start 9:42:29: LaunchConditions.
Action ended 9:42:29: LaunchConditions. Return value 1.
MSI (s) (00:34) [09:42:29:333]: Doing action: ValidateProductID
Action start 9:42:29: ValidateProductID.
Action ended 9:42:29: ValidateProductID. Return value 1.
MSI (s) (00:34) [09:42:29:336]: Doing action: CostInitialize
Action start 9:42:29: CostInitialize.
MSI (s) (00:34) [09:42:29:337]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (s) (00:34) [09:42:29:338]: PROPERTY CHANGE: Modifying ROOTDRIVE property. Its current value is 'c:\'. Its new value: 'C:\'.
MSI (s) (00:34) [09:42:29:338]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (00:34) [09:42:29:338]: Note: 1: 2205 2: 3: Patch
MSI (s) (00:34) [09:42:29:338]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (00:34) [09:42:29:338]: Note: 1: 2205 2: 3: MsiPatchHeaders
MSI (s) (00:34) [09:42:29:338]: Note: 1: 2205 2: 3: __MsiPatchFileList
MSI (s) (00:34) [09:42:29:338]: Note: 1: 2228 2: 3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
Action ended 9:42:29: CostInitialize. Return value 1.
MSI (s) (00:34) [09:42:29:338]: Doing action: FileCost
Action start 9:42:29: FileCost.
MSI (s) (00:34) [09:42:29:340]: Note: 1: 2205 2: 3: MsiAssembly
MSI (s) (00:34) [09:42:29:340]: Note: 1: 2205 2: 3: Class
MSI (s) (00:34) [09:42:29:340]: Note: 1: 2205 2: 3: Extension
MSI (s) (00:34) [09:42:29:340]: Note: 1: 2205 2: 3: TypeLib
Action ended 9:42:29: FileCost. Return value 1.
MSI (s) (00:34) [09:42:29:340]: Doing action: CostFinalize
Action start 9:42:29: CostFinalize.
MSI (s) (00:34) [09:42:29:342]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (00:34) [09:42:29:342]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (00:34) [09:42:29:342]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (00:34) [09:42:29:342]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (00:34) [09:42:29:342]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (00:34) [09:42:29:342]: Note: 1: 2205 2: 3: Patch
MSI (s) (00:34) [09:42:29:342]: Note: 1: 2205 2: 3: Condition
MSI (s) (00:34) [09:42:29:342]: PROPERTY CHANGE: Modifying TARGETDIR property. Its current value is 'c:\'. Its new value: 'C:\'.
MSI (s) (00:34) [09:42:29:342]: PROPERTY CHANGE: Modifying APITDIR property. Its current value is 'c:\Users\crouxel\AppData\Local\T\'. Its new value: 'C:\Users\crouxel\AppData\Local\T\'.
MSI (s) (00:34) [09:42:29:342]: PROPERTY CHANGE: Modifying APIT_USER property. Its current value is 'c:\Users\crouxel\AppData\Local\T\U\'. Its new value: 'C:\Users\crouxel\AppData\Local\T\U\'.
MSI (s) (00:34) [09:42:29:342]: PROPERTY CHANGE: Modifying APIT_ARDUINO15 property. Its current value is 'c:\Users\crouxel\AppData\Local\T\A\'. Its new value: 'C:\Users\crouxel\AppData\Local\T\A\'.
MSI (s) (00:34) [09:42:29:343]: PROPERTY CHANGE: Modifying INSTALLDIR property. Its current value is 'c:\Program Files\Arduino PLC IDE Tools\'. Its new value: 'C:\Program Files\Arduino PLC IDE Tools\'.
MSI (s) (00:34) [09:42:29:343]: Target path resolution complete. Dumping Directory table...
MSI (s) (00:34) [09:42:29:343]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (00:34) [09:42:29:343]: Dir (target): Key: TARGETDIR , Object: C:\
MSI (s) (00:34) [09:42:29:343]: Dir (target): Key: WindowsFolder , Object: C:\WINDOWS\
MSI (s) (00:34) [09:42:29:343]: Dir (target): Key: LocalAppDataFolder , Object: C:\Users\crouxel\AppData\Local\
MSI (s) (00:34) [09:42:29:343]: Dir (target): Key: APITDIR , Object: C:\Users\crouxel\AppData\Local\T\
MSI (s) (00:34) [09:42:29:343]: Dir (target): Key: APIT_USER , Object: C:\Users\crouxel\AppData\Local\T\U\
MSI (s) (00:34) [09:42:29:343]: Dir (target): Key: APIT_ARDUINO15 , Object: C:\Users\crouxel\AppData\Local\T\A\
MSI (s) (00:34) [09:42:29:343]: Dir (target): Key: ProgramFiles64Folder , Object: C:\Program Files\
MSI (s) (00:34) [09:42:29:343]: Dir (target): Key: INSTALLDIR , Object: C:\Program Files\Arduino PLC IDE Tools\
MSI (s) (00:34) [09:42:29:343]: Note: 1: 2205 2: 3: MsiAssembly
MSI (s) (00:34) [09:42:29:343]: Note: 1: 2228 2: 3: MsiAssembly 4: SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`, `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
Action ended 9:42:29: CostFinalize. Return value 1.
MSI (s) (00:34) [09:42:29:343]: Doing action: MigrateFeatureStates
Action start 9:42:29: MigrateFeatureStates.
MSI (s) (00:34) [09:42:29:345]: Skipping MigrateFeatureStates action: already done on client side
Action ended 9:42:29: MigrateFeatureStates. Return value 0.
MSI (s) (00:34) [09:42:29:345]: Doing action: InstallValidate
Action start 9:42:29: InstallValidate.
MSI (s) (00:34) [09:42:29:347]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'c83c2c29f0dbcb4f868c7b52c7eddaf8'.
MSI (s) (00:34) [09:42:29:347]: Feature: DefaultFeature; Installed: Absent; Request: Local; Action: Local
MSI (s) (00:34) [09:42:29:347]: Component: arduino_cli.exe; Installed: Absent; Request: Local; Action: Local
MSI (s) (00:34) [09:42:29:347]: Component: reg7D6C70699246B8CDE8D5647B831CA834; Installed: Absent; Request: Local; Action: Local
MSI (s) (00:34) [09:42:29:347]: Component: regC05D8716AD0F32473A504134A9836E05; Installed: Absent; Request: Local; Action: Local
MSI (s) (00:34) [09:42:29:347]: Component: reg9443337434255EAD72E148AAD65147FC; Installed: Absent; Request: Local; Action: Local
MSI (s) (00:34) [09:42:29:347]: Component: reg85C2B8DE37F4E17F7AD46EDAF3BBBACD; Installed: Absent; Request: Local; Action: Local
MSI (s) (00:34) [09:42:29:347]: Component: __arduino_cli.exe65; Installed: Null; Request: Local; Action: Local
MSI (s) (00:34) [09:42:29:347]: Component: __reg7D6C70699246B8CDE8D5647B831CA83465; Installed: Null; Request: Local; Action: Local
MSI (s) (00:34) [09:42:29:347]: Component: __regC05D8716AD0F32473A504134A9836E0565; Installed: Null; Request: Local; Action: Local
MSI (s) (00:34) [09:42:29:347]: Component: __reg9443337434255EAD72E148AAD65147FC65; Installed: Null; Request: Local; Action: Local
MSI (s) (00:34) [09:42:29:347]: Component: __reg85C2B8DE37F4E17F7AD46EDAF3BBBACD65; Installed: Null; Request: Local; Action: Local
MSI (s) (00:34) [09:42:29:347]: Note: 1: 2205 2: 3: BindImage
MSI (s) (00:34) [09:42:29:347]: Note: 1: 2205 2: 3: ProgId
MSI (s) (00:34) [09:42:29:347]: Note: 1: 2205 2: 3: PublishComponent
MSI (s) (00:34) [09:42:29:347]: Note: 1: 2205 2: 3: SelfReg
MSI (s) (00:34) [09:42:29:347]: Note: 1: 2205 2: 3: Extension
MSI (s) (00:34) [09:42:29:347]: Note: 1: 2205 2: 3: Font
MSI (s) (00:34) [09:42:29:347]: Note: 1: 2205 2: 3: Shortcut
MSI (s) (00:34) [09:42:29:347]: Note: 1: 2205 2: 3: Class
MSI (s) (00:34) [09:42:29:347]: Note: 1: 2205 2: 3: Icon
MSI (s) (00:34) [09:42:29:347]: Note: 1: 2205 2: 3: TypeLib
MSI (s) (00:34) [09:42:29:348]: Note: 1: 2205 2: 3: _RemoveFilePath
MSI (s) (00:34) [09:42:29:351]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (00:34) [09:42:29:351]: Note: 1: 2205 2: 3: BindImage
MSI (s) (00:34) [09:42:29:351]: Note: 1: 2205 2: 3: ProgId
MSI (s) (00:34) [09:42:29:351]: Note: 1: 2205 2: 3: PublishComponent
MSI (s) (00:34) [09:42:29:351]: Note: 1: 2205 2: 3: SelfReg
MSI (s) (00:34) [09:42:29:351]: Note: 1: 2205 2: 3: Extension
MSI (s) (00:34) [09:42:29:351]: Note: 1: 2205 2: 3: Font
MSI (s) (00:34) [09:42:29:351]: Note: 1: 2205 2: 3: Shortcut
MSI (s) (00:34) [09:42:29:351]: Note: 1: 2205 2: 3: Class
MSI (s) (00:34) [09:42:29:351]: Note: 1: 2205 2: 3: Icon
MSI (s) (00:34) [09:42:29:351]: Note: 1: 2205 2: 3: TypeLib
MSI (s) (00:34) [09:42:29:352]: Note: 1: 2727 2:
MSI (s) (00:34) [09:42:29:352]: Note: 1: 2205 2: 3: FilesInUse
MSI (s) (00:34) [09:42:29:370]: Note: 1: 2727 2:
Action ended 9:42:29: InstallValidate. Return value 1.
MSI (s) (00:34) [09:42:29:370]: Doing action: RemoveExistingProducts
Action start 9:42:29: RemoveExistingProducts.
MSI (s) (00:34) [09:42:29:372]: Note: 1: 2205 2: 3: Error
MSI (s) (00:34) [09:42:29:372]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 22
MSI (s) (00:34) [09:42:29:372]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 23
MSI (s) (00:34) [09:42:29:373]: Note: 1: 2205 2: 3: Error
MSI (s) (00:34) [09:42:29:373]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 16
MSI (s) (00:34) [09:42:29:373]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 21
Action ended 9:42:29: RemoveExistingProducts. Return value 1.
MSI (s) (00:34) [09:42:29:373]: Doing action: InstallInitialize
Action start 9:42:29: InstallInitialize.
MSI (s) (00:34) [09:42:29:375]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (00:34) [09:42:29:375]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (00:34) [09:42:29:375]: BeginTransaction: Locking Server
MSI (s) (00:34) [09:42:29:375]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (s) (00:34) [09:42:29:375]: Server not locked: locking for product {003FD1AF-576E-4F8F-8967-0BC8019AE1A3}
Action ended 9:42:29: InstallInitialize. Return value 1.
MSI (s) (00:34) [09:42:29:378]: Doing action: ProcessComponents
Action start 9:42:29: ProcessComponents.
MSI (s) (00:34) [09:42:29:380]: Note: 1: 2205 2: 3: MsiPatchCertificate
MSI (s) (00:34) [09:42:29:380]: LUA patching is disabled: missing MsiPatchCertificate table
MSI (s) (00:34) [09:42:29:380]: Resolving source.
MSI (s) (00:34) [09:42:29:380]: Resolving source to launched-from source.
MSI (s) (00:34) [09:42:29:380]: Setting launched-from source as last-used.
MSI (s) (00:34) [09:42:29:380]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'c:\Users\crouxel\Downloads\'.
MSI (s) (00:34) [09:42:29:380]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'c:\Users\crouxel\Downloads\'.
MSI (s) (00:34) [09:42:29:380]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}'.
MSI (s) (00:34) [09:42:29:380]: SOURCEDIR ==> c:\Users\crouxel\Downloads\
MSI (s) (00:34) [09:42:29:380]: SOURCEDIR product ==> {003FD1AF-576E-4F8F-8967-0BC8019AE1A3}
MSI (s) (00:34) [09:42:29:380]: Determining source type
MSI (s) (00:34) [09:42:29:381]: Source type from package 'Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi': 2
MSI (s) (00:34) [09:42:29:381]: SECREPAIR: Re-Create hashes
MSI (s) (00:34) [09:42:29:381]: SECREPAIR: Hash Database: C:\WINDOWS\Installer\SourceHash{003FD1AF-576E-4F8F-8967-0BC8019AE1A3}
MSI (s) (00:34) [09:42:29:382]: Note: 1: 2262 2: SourceHash 3: -2147287038
MSI (s) (00:34) [09:42:29:383]: SECREPAIR: New Hash Database creation complete.
MSI (s) (00:34) [09:42:29:454]: Source path resolution complete. Dumping Directory table...
MSI (s) (00:34) [09:42:29:454]: Dir (source): Key: TARGETDIR , Object: C:\Users\crouxel\Downloads\ , LongSubPath: , ShortSubPath:
MSI (s) (00:34) [09:42:29:454]: Dir (source): Key: WindowsFolder , Object: C:\Users\crouxel\Downloads\ , LongSubPath: , ShortSubPath:
MSI (s) (00:34) [09:42:29:454]: Dir (source): Key: LocalAppDataFolder , Object: C:\Users\crouxel\Downloads\ , LongSubPath: Local App Data\ , ShortSubPath: 61ir65dn\
MSI (s) (00:34) [09:42:29:454]: Dir (source): Key: APITDIR , Object: C:\Users\crouxel\Downloads\ , LongSubPath: Local App Data\T\ , ShortSubPath: 61ir65dn\T\
MSI (s) (00:34) [09:42:29:454]: Dir (source): Key: APIT_USER , Object: C:\Users\crouxel\Downloads\ , LongSubPath: Local App Data\T\U\ , ShortSubPath: 61ir65dn\T\U\
MSI (s) (00:34) [09:42:29:454]: Dir (source): Key: APIT_ARDUINO15 , Object: C:\Users\crouxel\Downloads\ , LongSubPath: Local App Data\T\A\ , ShortSubPath: 61ir65dn\T\A\
MSI (s) (00:34) [09:42:29:454]: Dir (source): Key: ProgramFiles64Folder , Object: C:\Users\crouxel\Downloads\ , LongSubPath: Program Files\ , ShortSubPath: xlqr-nev\
MSI (s) (00:34) [09:42:29:454]: Dir (source): Key: INSTALLDIR , Object: C:\Users\crouxel\Downloads\ , LongSubPath: Program Files\Arduino PLC IDE Tools\ , ShortSubPath: xlqr-nev\qrbb4suh\
Action ended 9:42:29: ProcessComponents. Return value 1.
MSI (s) (00:34) [09:42:29:461]: Doing action: UnpublishFeatures
Action start 9:42:29: UnpublishFeatures.
Action ended 9:42:29: UnpublishFeatures. Return value 1.
MSI (s) (00:34) [09:42:29:464]: Doing action: RemoveRegistryValues
Action start 9:42:29: RemoveRegistryValues.
Action ended 9:42:29: RemoveRegistryValues. Return value 1.
MSI (s) (00:34) [09:42:29:466]: Doing action: RemoveEnvironmentStrings
Action start 9:42:29: RemoveEnvironmentStrings.
Action ended 9:42:29: RemoveEnvironmentStrings. Return value 1.
MSI (s) (00:34) [09:42:29:468]: Doing action: RemoveDuplicateFiles
Action start 9:42:29: RemoveDuplicateFiles.
Action ended 9:42:29: RemoveDuplicateFiles. Return value 1.
MSI (s) (00:34) [09:42:29:470]: Doing action: RemoveFiles
Action start 9:42:29: RemoveFiles.
Action ended 9:42:29: RemoveFiles. Return value 1.
MSI (s) (00:34) [09:42:29:472]: Doing action: InstallFiles
Action start 9:42:29: InstallFiles.
MSI (s) (00:34) [09:42:29:475]: Note: 1: 2205 2: 3: Patch
MSI (s) (00:34) [09:42:29:475]: Note: 1: 2228 2: 3: Patch 4: SELECT `Patch`.`File_`, `Patch`.`Header`, `Patch`.`Attributes`, `Patch`.`Sequence`, `Patch`.`StreamRef_` FROM `Patch` WHERE `Patch`.`File_` = ? AND `Patch`.`#_MsiActive`=? ORDER BY `Patch`.`Sequence`
MSI (s) (00:34) [09:42:29:475]: Note: 1: 2205 2: 3: Error
MSI (s) (00:34) [09:42:29:475]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1302
MSI (s) (00:34) [09:42:29:475]: Note: 1: 2205 2: 3: MsiSFCBypass
MSI (s) (00:34) [09:42:29:475]: Note: 1: 2228 2: 3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
MSI (s) (00:34) [09:42:29:475]: Note: 1: 2205 2: 3: MsiPatchHeaders
MSI (s) (00:34) [09:42:29:475]: Note: 1: 2228 2: 3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
MSI (s) (00:34) [09:42:29:475]: Note: 1: 2205 2: 3: PatchPackage
Action ended 9:42:29: InstallFiles. Return value 1.
MSI (s) (00:34) [09:42:29:477]: Doing action: Set_PLC_IDE_APPDATA
Action start 9:42:29: Set_PLC_IDE_APPDATA.
MSI (s) (00:34) [09:42:29:478]: PROPERTY CHANGE: Modifying PLC_IDE_APPDATA property. Its current value is ' '. Its new value: 'C:\Users\crouxel\AppData\Local\T'.
Action ended 9:42:29: Set_PLC_IDE_APPDATA. Return value 1.
MSI (s) (00:34) [09:42:29:479]: Doing action: Set_PLC_IDE_DATA
Action start 9:42:29: Set_PLC_IDE_DATA.
MSI (s) (00:34) [09:42:29:480]: PROPERTY CHANGE: Modifying PLC_IDE_DATA property. Its current value is ' '. Its new value: 'C:\Users\crouxel\AppData\Local\T\A'.
Action ended 9:42:29: Set_PLC_IDE_DATA. Return value 1.
MSI (s) (00:34) [09:42:29:480]: Doing action: Set_PLC_IDE_DOWNLOADS
Action start 9:42:29: Set_PLC_IDE_DOWNLOADS.
MSI (s) (00:34) [09:42:29:482]: PROPERTY CHANGE: Modifying PLC_IDE_DOWNLOADS property. Its current value is ' '. Its new value: 'C:\Users\crouxel\AppData\Local\T\D'.
Action ended 9:42:29: Set_PLC_IDE_DOWNLOADS. Return value 1.
MSI (s) (00:34) [09:42:29:482]: Doing action: Set_PLC_IDE_USER
Action start 9:42:29: Set_PLC_IDE_USER.
MSI (s) (00:34) [09:42:29:484]: PROPERTY CHANGE: Modifying PLC_IDE_USER property. Its current value is ' '. Its new value: 'C:\Users\crouxel\AppData\Local\T\U'.
Action ended 9:42:29: Set_PLC_IDE_USER. Return value 1.
MSI (s) (00:34) [09:42:29:484]: Doing action: Set_PLC_IDE_ARDUINO_CLI_YAML
Action start 9:42:29: Set_PLC_IDE_ARDUINO_CLI_YAML.
MSI (s) (00:34) [09:42:29:485]: PROPERTY CHANGE: Modifying PLC_IDE_ARDUINO_CLI_YAML property. Its current value is ' '. Its new value: 'C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml'.
Action ended 9:42:29: Set_PLC_IDE_ARDUINO_CLI_YAML. Return value 1.
MSI (s) (00:34) [09:42:29:485]: Doing action: SetCreateConfig
Action start 9:42:29: SetCreateConfig.
MSI (s) (00:34) [09:42:29:487]: PROPERTY CHANGE: Adding CreateConfig property. Its value is '"C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" config init --overwrite --dest-dir "C:\Users\crouxel\AppData\Local\T"'.
Action ended 9:42:29: SetCreateConfig. Return value 1.
MSI (s) (00:34) [09:42:29:487]: Doing action: CreateConfig
Action start 9:42:29: CreateConfig.
Action ended 9:42:29: CreateConfig. Return value 1.
MSI (s) (00:34) [09:42:29:490]: Doing action: SetSetConfigDirectoriesData
Action start 9:42:29: SetSetConfigDirectoriesData.
MSI (s) (00:34) [09:42:29:491]: PROPERTY CHANGE: Adding SetConfigDirectoriesData property. Its value is '"C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" config set directories.data "C:\Users\crouxel\AppData\Local\T\A"'.
Action ended 9:42:29: SetSetConfigDirectoriesData. Return value 1.
MSI (s) (00:34) [09:42:29:491]: Doing action: SetConfigDirectoriesData
Action start 9:42:29: SetConfigDirectoriesData.
Action ended 9:42:29: SetConfigDirectoriesData. Return value 1.
MSI (s) (00:34) [09:42:29:495]: Doing action: SetSetConfigDirectoriesDownloads
Action start 9:42:29: SetSetConfigDirectoriesDownloads.
MSI (s) (00:34) [09:42:29:497]: PROPERTY CHANGE: Adding SetConfigDirectoriesDownloads property. Its value is '"C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" config set directories.downloads "C:\Users\crouxel\AppData\Local\T\D"'.
Action ended 9:42:29: SetSetConfigDirectoriesDownloads. Return value 1.
MSI (s) (00:34) [09:42:29:497]: Doing action: SetConfigDirectoriesDownloads
Action start 9:42:29: SetConfigDirectoriesDownloads.
Action ended 9:42:29: SetConfigDirectoriesDownloads. Return value 1.
MSI (s) (00:34) [09:42:29:500]: Doing action: SetSetConfigDirectoriesUser
Action start 9:42:29: SetSetConfigDirectoriesUser.
MSI (s) (00:34) [09:42:29:502]: PROPERTY CHANGE: Adding SetConfigDirectoriesUser property. Its value is '"C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" config set directories.user "C:\Users\crouxel\AppData\Local\T\U"'.
Action ended 9:42:29: SetSetConfigDirectoriesUser. Return value 1.
MSI (s) (00:34) [09:42:29:502]: Doing action: SetConfigDirectoriesUser
Action start 9:42:29: SetConfigDirectoriesUser.
Action ended 9:42:29: SetConfigDirectoriesUser. Return value 1.
MSI (s) (00:34) [09:42:29:505]: Doing action: SetSetOutputNoColor
Action start 9:42:29: SetSetOutputNoColor.
MSI (s) (00:34) [09:42:29:506]: PROPERTY CHANGE: Adding SetOutputNoColor property. Its value is '"C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" config set output.no_color true'.
Action ended 9:42:29: SetSetOutputNoColor. Return value 1.
MSI (s) (00:34) [09:42:29:507]: Doing action: SetOutputNoColor
Action start 9:42:29: SetOutputNoColor.
Action ended 9:42:29: SetOutputNoColor. Return value 1.
MSI (s) (00:34) [09:42:29:512]: Doing action: SetUpdateBoardIndex
Action start 9:42:29: SetUpdateBoardIndex.
MSI (s) (00:34) [09:42:29:513]: PROPERTY CHANGE: Adding UpdateBoardIndex property. Its value is '"C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" core update-index'.
Action ended 9:42:29: SetUpdateBoardIndex. Return value 1.
MSI (s) (00:34) [09:42:29:514]: Doing action: UpdateBoardIndex
Action start 9:42:29: UpdateBoardIndex.
Action ended 9:42:29: UpdateBoardIndex. Return value 1.
MSI (s) (00:34) [09:42:29:517]: Doing action: SetDownloadCoreMbedPortenta
Action start 9:42:29: SetDownloadCoreMbedPortenta.
MSI (s) (00:34) [09:42:29:519]: PROPERTY CHANGE: Adding DownloadCoreMbedPortenta property. Its value is '"C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" core download "arduino:mbed_portenta@3.5.4"'.
Action ended 9:42:29: SetDownloadCoreMbedPortenta. Return value 1.
MSI (s) (00:34) [09:42:29:519]: Doing action: DownloadCoreMbedPortenta
Action start 9:42:29: DownloadCoreMbedPortenta.
Action ended 9:42:29: DownloadCoreMbedPortenta. Return value 1.
MSI (s) (00:34) [09:42:29:523]: Doing action: SetDownloadCoreMbedOpta
Action start 9:42:29: SetDownloadCoreMbedOpta.
MSI (s) (00:34) [09:42:29:524]: PROPERTY CHANGE: Adding DownloadCoreMbedOpta property. Its value is '"C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" core download "arduino:mbed_opta@3.5.4"'.
Action ended 9:42:29: SetDownloadCoreMbedOpta. Return value 1.
MSI (s) (00:34) [09:42:29:525]: Doing action: DownloadCoreMbedOpta
Action start 9:42:29: DownloadCoreMbedOpta.
Action ended 9:42:29: DownloadCoreMbedOpta. Return value 1.
MSI (s) (00:34) [09:42:29:528]: Doing action: SetUpdateLibraryIndex
Action start 9:42:29: SetUpdateLibraryIndex.
MSI (s) (00:34) [09:42:29:529]: PROPERTY CHANGE: Adding UpdateLibraryIndex property. Its value is '"C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" lib update-index'.
Action ended 9:42:29: SetUpdateLibraryIndex. Return value 1.
MSI (s) (00:34) [09:42:29:530]: Doing action: UpdateLibraryIndex
Action start 9:42:29: UpdateLibraryIndex.
Action ended 9:42:29: UpdateLibraryIndex. Return value 1.
MSI (s) (00:34) [09:42:29:533]: Doing action: DuplicateFiles
Action start 9:42:29: DuplicateFiles.
Action ended 9:42:29: DuplicateFiles. Return value 1.
MSI (s) (00:34) [09:42:29:536]: Doing action: WriteRegistryValues
Action start 9:42:29: WriteRegistryValues.
Action ended 9:42:29: WriteRegistryValues. Return value 1.
MSI (s) (00:34) [09:42:29:541]: Doing action: WriteEnvironmentStrings
Action start 9:42:29: WriteEnvironmentStrings.
Action ended 9:42:29: WriteEnvironmentStrings. Return value 1.
MSI (s) (00:34) [09:42:29:544]: Doing action: RegisterUser
Action start 9:42:29: RegisterUser.
Action ended 9:42:29: RegisterUser. Return value 1.
MSI (s) (00:34) [09:42:29:546]: Doing action: RegisterProduct
Action start 9:42:29: RegisterProduct.
MSI (s) (00:34) [09:42:29:549]: Note: 1: 2205 2: 3: Error
MSI (s) (00:34) [09:42:29:549]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1302
MSI (s) (00:34) [09:42:29:550]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
Action ended 9:42:29: RegisterProduct. Return value 1.
MSI (s) (00:34) [09:42:29:550]: Doing action: PublishFeatures
Action start 9:42:29: PublishFeatures.
Action ended 9:42:29: PublishFeatures. Return value 1.
MSI (s) (00:34) [09:42:29:553]: Doing action: PublishProduct
Action start 9:42:29: PublishProduct.
MSI (s) (00:34) [09:42:29:555]: Note: 1: 2205 2: 3: Icon
MSI (s) (00:34) [09:42:29:555]: Note: 1: 2228 2: 3: Icon 4: SELECT `Name`, `Data` FROM `Icon`
Action ended 9:42:29: PublishProduct. Return value 1.
MSI (s) (00:34) [09:42:29:558]: Doing action: InstallFinalize
Action start 9:42:29: InstallFinalize.
MSI (s) (00:34) [09:42:29:559]: Running Script: C:\WINDOWS\Installer\MSIDB69.tmp
MSI (s) (00:34) [09:42:29:559]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (00:34) [09:42:29:568]: Note: 1: 2265 2: 3: -2147287035
MSI (s) (00:34) [09:42:29:569]: Machine policy value 'DisableRollback' is 0
MSI (s) (00:34) [09:42:29:574]: Note: 1: 2318 2:
MSI (s) (00:34) [09:42:29:576]: Note: 1: 2318 2:
MSI (s) (00:34) [09:42:29:576]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (00:34) [09:42:29:576]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1468091727,LangId=1033,Platform=589824,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (00:34) [09:42:29:577]: Executing op: ProductInfo(ProductKey={003FD1AF-576E-4F8F-8967-0BC8019AE1A3},ProductName=Arduino PLC IDE Tools,PackageName=Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi,Language=1033,Version=16777219,Assignment=1,ObsoleteArg=0,,,PackageCode={65AF645C-F762-4063-B5D8-409D543D4022},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=2)
MSI (s) (00:34) [09:42:29:577]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (00:34) [09:42:29:578]: Executing op: DialogInfo(Type=1,Argument=Arduino PLC IDE Tools)
MSI (s) (00:34) [09:42:29:578]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (00:34) [09:42:29:578]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (00:34) [09:42:29:578]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (00:34) [09:42:29:578]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (00:34) [09:42:29:580]: Executing op: ProgressTotal(Total=5,Type=1,ByteEquivalent=24000)
MSI (s) (00:34) [09:42:29:580]: Executing op: ComponentRegister(ComponentId={0C407434-5D0F-428A-A855-D823F6ACCE8D},KeyPath=C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
MSI (s) (00:34) [09:42:29:582]: Executing op: ComponentRegister(ComponentId={F5643927-BB6C-5E1C-9C7F-9A31DF35D301},KeyPath=22:\SOFTWARE\Arduino PLC IDE\InstallDir,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
MSI (s) (00:34) [09:42:29:583]: Executing op: ComponentRegister(ComponentId={B527EB58-8B1F-54F9-867F-9D50F19E59D1},KeyPath=21:\SOFTWARE\Arduino PLC IDE Tools\ApitDir,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
MSI (s) (00:34) [09:42:29:584]: Executing op: ComponentRegister(ComponentId={A0A2DB79-4050-5DE7-B33C-149F273D8A49},KeyPath=21:\SOFTWARE\Arduino PLC IDE Tools\Arduino 15\ApitArduino15,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
MSI (s) (00:34) [09:42:29:585]: Executing op: ComponentRegister(ComponentId={1370D655-F98C-5F5C-BF22-1D5D14FD97FD},KeyPath=21:\SOFTWARE\Arduino PLC IDE Tools\Arduino\ApitArduino,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
MSI (s) (00:34) [09:42:29:585]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1], Directory: [9], Size: [6])
MSI (s) (00:34) [09:42:29:587]: Executing op: ProgressTotal(Total=28760015,Type=0,ByteEquivalent=1)
MSI (s) (00:34) [09:42:29:587]: Executing op: SetTargetFolder(Folder=C:\Program Files\Arduino PLC IDE Tools\)
MSI (s) (00:34) [09:42:29:587]: Executing op: SetSourceFolder(Folder=1\xlqr-nev\qrbb4suh\|Program Files\Arduino PLC IDE Tools\)
MSI (s) (00:34) [09:42:29:587]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=cab1.cab,BytesPerTick=65536,CopierType=2,ModuleFileName=C:\WINDOWS\Installer\8e96fc0.msi,,,,,IsFirstPhysicalMedia=1)
MSI (s) (00:34) [09:42:29:587]: Executing op: FileCopy(SourceName=-rhcc4s-.exe|arduino-cli.exe,SourceCabKey=arduino_cli.exe,DestName=arduino-cli.exe,Attributes=512,FileSize=28759552,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=-1137943905,HashPart2=2018118786,HashPart3=-1573705734,HashPart4=865554841,,)
MSI (s) (00:34) [09:42:29:587]: File: C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe; To be installed; Won't patch; No existing file
MSI (s) (00:34) [09:42:29:588]: Source for file 'arduino_cli.exe' is compressed
MSI (s) (00:34) [09:42:29:759]: Executing op: FileCopy(SourceName=oj7vgeom.yam|sketch.yaml,SourceCabKey=sketch.yaml,DestName=sketch.yaml,Attributes=512,FileSize=463,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=1285269420,HashPart2=961780341,HashPart3=-1151590207,HashPart4=-238153843,,)
MSI (s) (00:34) [09:42:29:759]: File: C:\Program Files\Arduino PLC IDE Tools\sketch.yaml; To be installed; Won't patch; No existing file
MSI (s) (00:34) [09:42:29:760]: Source for file 'sketch.yaml' is compressed
MSI (s) (00:34) [09:42:29:761]: Executing op: CacheSizeFlush(,)
MSI (s) (00:34) [09:42:29:761]: Executing op: ActionStart(Name=CreateConfig,,)
MSI (s) (00:34) [09:42:29:764]: Executing op: CustomActionSchedule(Action=CreateConfig,ActionType=3073,Source=BinaryData,Target=WixQuietExec,CustomActionData="C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" config init --overwrite --dest-dir "C:\Users\crouxel\AppData\Local\T")
MSI (s) (00:10) [09:42:29:767]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIDCA3.tmp, Entrypoint: WixQuietExec
MSI (s) (00:88) [09:42:29:767]: Generating random cookie.
MSI (s) (00:88) [09:42:29:768]: System Environment : Client has accepted UAC prompt
MSI (s) (00:88) [09:42:29:769]: Created Custom Action Server with PID 30656 (0x77C0).
MSI (s) (00:64) [09:42:29:797]: Running as a service.
MSI (s) (00:64) [09:42:29:800]: Hello, I'm your 32bit Elevated Non-remapped custom action server.
WixQuietExec: Config file written to: C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml
MSI (s) (00:34) [09:42:30:456]: Executing op: ActionStart(Name=SetConfigDirectoriesData,,)
MSI (s) (00:34) [09:42:30:458]: Executing op: CustomActionSchedule(Action=SetConfigDirectoriesData,ActionType=1025,Source=BinaryData,Target=WixQuietExec,CustomActionData="C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" config set directories.data "C:\Users\crouxel\AppData\Local\T\A")
MSI (s) (00:58) [09:42:30:461]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIDF63.tmp, Entrypoint: WixQuietExec
MSI (s) (00:88) [09:42:30:461]: Generating random cookie.
MSI (s) (00:88) [09:42:30:463]: Created Custom Action Server with PID 11444 (0x2CB4).
MSI (s) (00:64) [09:42:30:492]: Running as a service.
MSI (s) (00:64) [09:42:30:495]: Hello, I'm your 32bit Impersonated custom action server.
MSI (s) (00:34) [09:42:30:580]: Executing op: ActionStart(Name=SetConfigDirectoriesDownloads,,)
MSI (s) (00:34) [09:42:30:582]: Executing op: CustomActionSchedule(Action=SetConfigDirectoriesDownloads,ActionType=1025,Source=BinaryData,Target=WixQuietExec,CustomActionData="C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" config set directories.downloads "C:\Users\crouxel\AppData\Local\T\D")
MSI (s) (00:10) [09:42:30:585]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIDFD1.tmp, Entrypoint: WixQuietExec
MSI (s) (00:34) [09:42:30:668]: Executing op: ActionStart(Name=SetConfigDirectoriesUser,,)
MSI (s) (00:34) [09:42:30:670]: Executing op: CustomActionSchedule(Action=SetConfigDirectoriesUser,ActionType=1025,Source=BinaryData,Target=WixQuietExec,CustomActionData="C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" config set directories.user "C:\Users\crouxel\AppData\Local\T\U")
MSI (s) (00:64) [09:42:30:674]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIE030.tmp, Entrypoint: WixQuietExec
MSI (s) (00:34) [09:42:30:758]: Executing op: ActionStart(Name=SetOutputNoColor,,)
MSI (s) (00:34) [09:42:30:760]: Executing op: CustomActionSchedule(Action=SetOutputNoColor,ActionType=1025,Source=BinaryData,Target=WixQuietExec,CustomActionData="C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" config set output.no_color true)
MSI (s) (00:44) [09:42:30:764]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIE08F.tmp, Entrypoint: WixQuietExec
MSI (s) (00:34) [09:42:30:849]: Executing op: ActionStart(Name=UpdateBoardIndex,,)
MSI (s) (00:34) [09:42:30:851]: Executing op: CustomActionSchedule(Action=UpdateBoardIndex,ActionType=1025,Source=BinaryData,Target=WixQuietExec,CustomActionData="C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" core update-index)
MSI (s) (00:A8) [09:42:30:854]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIE0ED.tmp, Entrypoint: WixQuietExec
WixQuietExec:
WixQuietExec: Downloading index: package_index.tar.bz2 0 B / 56.91 KiB 0.00%
WixQuietExec: Downloading index: package_index.tar.bz2 downloaded
MSI (s) (00:34) [09:42:31:335]: Executing op: ActionStart(Name=DownloadCoreMbedPortenta,Description=Downloading the Arduino Core for Portenta Machine Control. Please, wait...,)
MSI (s) (00:34) [09:42:31:337]: Executing op: CustomActionSchedule(Action=DownloadCoreMbedPortenta,ActionType=1025,Source=BinaryData,Target=WixQuietExec,CustomActionData="C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe" --config-file "C:\Users\crouxel\AppData\Local\T\arduino-cli.yaml" core download "arduino:mbed_portenta@3.5.4")
MSI (s) (00:FC) [09:42:31:340]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIE2D3.tmp, Entrypoint: WixQuietExec
WixQuietExec: arduino:mbed_portenta@3.5.4 arduino:mbed_portenta@3.5.4 already downloaded
WixQuietExec: arduino:openocd@0.11.0-arduino2 arduino:openocd@0.11.0-arduino2 already downloaded
WixQuietExec:
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 0 B / 125.66 MiB 0.00%
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 640.55 KiB / 125.66 MiB 0.50% 00m39s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 1.76 MiB / 125.66 MiB 1.40% 00m28s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 3.07 MiB / 125.66 MiB 2.44% 00m24s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 4.47 MiB / 125.66 MiB 3.56% 00m21s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 5.90 MiB / 125.66 MiB 4.69% 00m20s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 7.34 MiB / 125.66 MiB 5.84% 00m22s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 8.90 MiB / 125.66 MiB 7.08% 00m20s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 10.48 MiB / 125.66 MiB 8.34% 00m19s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 12.31 MiB / 125.66 MiB 9.80% 00m18s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 13.37 MiB / 125.66 MiB 10.64% 00m20s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 13.38 MiB / 125.66 MiB 10.65% 00m21s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 13.80 MiB / 125.66 MiB 10.98% 00m22s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 15.53 MiB / 125.66 MiB 12.36% 00m21s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 16.58 MiB / 125.66 MiB 13.20% 00m22s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 18.39 MiB / 125.66 MiB 14.64% 00m21s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 19.32 MiB / 125.66 MiB 15.37% 00m21s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 20.48 MiB / 125.66 MiB 16.29% 00m20s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 21.93 MiB / 125.66 MiB 17.45% 00m20s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 21.93 MiB / 125.66 MiB 17.45% 00m19s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 23.29 MiB / 125.66 MiB 18.53% 00m20s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 24.65 MiB / 125.66 MiB 19.62% 00m19s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 26.01 MiB / 125.66 MiB 20.70% 00m19s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 27.37 MiB / 125.66 MiB 21.78% 00m18s
WixQuietExec: arduino:arm-none-eabi-gcc@7-2017q4 read tcp 10.12.141.25:61247->172.64.155.55:80: wsarecv: An existing connection was forcibly closed by the remote host.
WixQuietExec: Error downloading arduino:mbed_portenta@3.5.4: read tcp 10.12.141.25:61247->172.64.155.55:80: wsarecv: An existing connection was forcibly closed by the remote host.
WixQuietExec: Error 0x80070005: Command line returned an error.
WixQuietExec: Error 0x80070005: QuietExec Failed
WixQuietExec: Error 0x80070005: Failed in ExecCommon method
CustomAction DownloadCoreMbedPortenta returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 9:42:37: InstallFinalize. Return value 3.
MSI (s) (00:34) [09:42:37:819]: Note: 1: 2265 2: 3: -2147287035
MSI (s) (00:34) [09:42:37:820]: User policy value 'DisableRollback' is 0
MSI (s) (00:34) [09:42:37:820]: Machine policy value 'DisableRollback' is 0
MSI (s) (00:34) [09:42:37:823]: Note: 1: 2318 2:
MSI (s) (00:34) [09:42:37:826]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1468091727,LangId=1033,Platform=589824,ScriptType=2,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (00:34) [09:42:37:826]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (00:34) [09:42:37:826]: Executing op: DialogInfo(Type=1,Argument=Arduino PLC IDE Tools)
MSI (s) (00:34) [09:42:37:826]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (00:34) [09:42:37:829]: Executing op: ActionStart(Name=DownloadCoreMbedPortenta,Description=Downloading the Arduino Core for Portenta Machine Control. Please, wait...,)
MSI (s) (00:34) [09:42:37:829]: Executing op: ProductInfo(ProductKey={003FD1AF-576E-4F8F-8967-0BC8019AE1A3},ProductName=Arduino PLC IDE Tools,PackageName=Arduino-PLC-IDE-Tools_1.0.3_Windows_64bit.msi,Language=1033,Version=16777219,Assignment=1,ObsoleteArg=0,,,PackageCode={65AF645C-F762-4063-B5D8-409D543D4022},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=2)
MSI (s) (00:34) [09:42:37:830]: Executing op: ActionStart(Name=UpdateBoardIndex,,)
MSI (s) (00:34) [09:42:37:831]: Executing op: ActionStart(Name=SetOutputNoColor,,)
MSI (s) (00:34) [09:42:37:831]: Executing op: ActionStart(Name=SetConfigDirectoriesUser,,)
MSI (s) (00:34) [09:42:37:832]: Executing op: ActionStart(Name=SetConfigDirectoriesDownloads,,)
MSI (s) (00:34) [09:42:37:832]: Executing op: ActionStart(Name=SetConfigDirectoriesData,,)
MSI (s) (00:34) [09:42:37:833]: Executing op: ActionStart(Name=CreateConfig,,)
MSI (s) (00:34) [09:42:37:833]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1], Directory: [9], Size: [6])
MSI (s) (00:34) [09:42:37:833]: Executing op: SetTargetFolder(Folder=C:\Program Files\Arduino PLC IDE Tools\)
MSI (s) (00:34) [09:42:37:834]: Executing op: FileRemove(,FileName=C:\Program Files\Arduino PLC IDE Tools\sketch.yaml,,)
MSI (s) (00:34) [09:42:37:837]: Note: 1: 2318 2:
MSI (s) (00:34) [09:42:37:838]: Executing op: FileRemove(,FileName=C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe,,)
MSI (s) (00:34) [09:42:37:844]: Note: 1: 2318 2:
MSI (s) (00:34) [09:42:37:848]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (00:34) [09:42:37:849]: Executing op: ComponentUnregister(ComponentId={1370D655-F98C-5F5C-BF22-1D5D14FD97FD},ProductKey={003FD1AF-576E-4F8F-8967-0BC8019AE1A3},BinaryType=1,)
MSI (s) (00:34) [09:42:37:849]: Executing op: ComponentUnregister(ComponentId={A0A2DB79-4050-5DE7-B33C-149F273D8A49},ProductKey={003FD1AF-576E-4F8F-8967-0BC8019AE1A3},BinaryType=1,)
MSI (s) (00:34) [09:42:37:850]: Executing op: ComponentUnregister(ComponentId={B527EB58-8B1F-54F9-867F-9D50F19E59D1},ProductKey={003FD1AF-576E-4F8F-8967-0BC8019AE1A3},BinaryType=1,)
MSI (s) (00:34) [09:42:37:851]: Executing op: ComponentUnregister(ComponentId={F5643927-BB6C-5E1C-9C7F-9A31DF35D301},ProductKey={003FD1AF-576E-4F8F-8967-0BC8019AE1A3},BinaryType=1,)
MSI (s) (00:34) [09:42:37:851]: Executing op: ComponentUnregister(ComponentId={0C407434-5D0F-428A-A855-D823F6ACCE8D},ProductKey={003FD1AF-576E-4F8F-8967-0BC8019AE1A3},BinaryType=1,)
MSI (s) (00:34) [09:42:37:851]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=0)
MSI (s) (00:34) [09:42:37:851]: Error in rollback skipped. Return: 5
MSI (s) (00:34) [09:42:37:854]: Note: 1: 2318 2:
MSI (s) (00:34) [09:42:37:856]: Note: 1: 2318 2:
MSI (s) (00:34) [09:42:37:857]: Calling SRSetRestorePoint API. dwRestorePtType: 13, dwEventType: 103, llSequenceNumber: 246, szDescription: "".
MSI (s) (00:34) [09:42:37:858]: The call to SRSetRestorePoint API succeeded. Returned status: 0.
MSI (s) (00:34) [09:42:37:858]: Unlocking Server
MSI (s) (00:34) [09:42:37:859]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
Action ended 9:42:37: INSTALL. Return value 3.
MSI (s) (00:34) [09:42:37:863]: MainEngineThread is returning 1603
MSI (s) (00:A8) [09:42:37:865]: RESTART MANAGER: Session closed.
MSI (s) (00:A8) [09:42:37:877]: User policy value 'DisableRollback' is 0
MSI (s) (00:A8) [09:42:37:878]: Machine policy value 'DisableRollback' is 0
MSI (s) (00:A8) [09:42:37:878]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (00:A8) [09:42:37:878]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (00:A8) [09:42:37:880]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (00:A8) [09:42:37:881]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (00:A8) [09:42:37:881]: Destroying RemoteAPI object.
MSI (s) (00:88) [09:42:37:882]: Custom Action Manager thread ending.
MSI (c) (38:E8) [09:42:37:883]: Back from server. Return value: 1603
MSI (c) (38:E8) [09:42:37:883]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (38:E8) [09:42:37:884]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'.
Action ended 9:42:37: ExecuteAction. Return value 3.
MSI (c) (38:E8) [09:42:37:884]: Doing action: FatalError
Action start 9:42:37: FatalError.
Action ended 9:42:40: FatalError. Return value 2.
Action ended 9:42:40: INSTALL. Return value 3.
MSI (c) (38:E8) [09:42:40:018]: Destroying RemoteAPI object.
MSI (c) (38:F4) [09:42:40:019]: Custom Action Manager thread ending.
=== Logging stopped: 12/1/2023 9:42:40 ===
MSI (c) (38:E8) [09:42:40:022]: Note: 1: 1708
MSI (c) (38:E8) [09:42:40:023]: Note: 1: 2205 2: 3: Error
MSI (c) (38:E8) [09:42:40:023]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1708
MSI (c) (38:E8) [09:42:40:023]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (c) (38:E8) [09:42:40:023]: Product: Arduino PLC IDE Tools -- Installation failed.
MSI (c) (38:E8) [09:42:40:023]: Windows Installer installed the product. Product Name: Arduino PLC IDE Tools. Product Version: 1.0.3. Product Language: 1033. Manufacturer: Arduino SRL. Installation success or error status: 1603.
MSI (c) (38:E8) [09:42:40:024]: Grabbed execution mutex.
MSI (c) (38:E8) [09:42:40:024]: Cleaning up uninstalled install packages, if any exist
MSI (c) (38:E8) [09:42:40:025]: MainEngineThread is returning 1603
=== Verbose logging stopped: 12/1/2023 9:42:40 ===
