Arduino PLC IDE
Hello, I hope this is the right forum for this.
I'm having an issue changing the IP address on my Arduino. I used the sketch at the bottom to set it. But now whenever I try and change the IP address to something else, I get a "path not found" error when I try to compile.
Please help !
Hi @mattcowie31.
Arduino Forum is definitely the right place to request assistance with anything Arduino-related.
However, it is not certain whether you chose an appropriate category for your topic.
You chose the Development Tools > IDE 1.x forum category, which is used for discussions related to the 1.x versions of Arduino IDE. However, the title of your topic "Arduino PLC IDE" indicates that your question is related to Arduino PLC IDE, not Arduino IDE. These are two completely separate software products with very significant technical differences.
Please add a reply here to tell us whether you are using Arduino IDE 1.x, Arduino PLC IDE, or something else.
Please provide a detailed explanation of what you mean by "sketch at the bottom".
Please provide the full and exact text of the error.
If you make a stronger effort at communication, you will get better results here on the forum.
