Arduino pro micro 3.3V 8Mhz + NRF24 Any external AVR recommendation
Hello,
I have been using NRF24 modules with Arduino Uno for a long time, powering the NRF24 through a small DC5V-DC3.3V YL-105 regulator connected to the +5V pin of the Uno. This setup works perfectly.
For a new project, I am using an Arduino Pro Micro 3.3V 8MHz, and the NRF24 needs to be powered separately.
I have performed several tests:
  • Using an LM2596 regulator set to +5V to power the Arduino (RAW pin) and the YL-105.
  • Using an LM2596 regulator set to +3.3V to power the NRF24 module directly, with a separate +5V regulator for the Arduino.
However, the radio.isChipConnected() command always returns NO.
The entire project is powered by a 12V DC 6Ah battery, and all grounds are properly connected.
Do you have any recommendations for a reliable 3.3V power supply for the NRF24?
I also suspect that the timing of power delivery might be an issue. Should the NRF24 be powered before the Arduino? Since I also use the USB port to monitor the serial output, the Arduino Micro might power up before the NRF24...
Thank you for your advice and support.
If you are using the nRF24 without the PA, you can power it from the pro micro Vcc output which is 3.3V
Why not regulate the main 12V down to 3.3V for the NrF?
Hello, I will use the NRF with radio.setPALevel( RF24_PA_MAX ) so I need a external regulator.
I already tried to regulate the main 12V down to 5V with LM2596 regulator and they use YL-105 to get consistent 3.3V but the radio.isChipConnected() command returns NO .
Do you have any recommendation of regulator (from 12V to 3.3V) to be used to power the NRF?
Many thanks for your support
As already suggested by @JCA34F , adjust your LM2596 to output 3.3V and power the nRF and the Pro Micro through their Vcc pins.
I would use something like this or similar to power Arduino AND NrF:
https://www.pololu.com/product/4891
