I accidentally "yanked" the micro usb connector of my Arduino pro micro clone while doing some project. I have successfully powered the board with attaching the GND and VCC wires to the external pins of the board. The problem is, I cannot get the computer to recognize the board... I have tried to connect the data pins on the pads but I think the pads came with the connector. I have also tried to connect the data pins in the resistor on the bottom left of the board. Any help is appreciated
There are also other sources and methods too.
But without much detail such as keyboard stroke direction PC> Ardi or Ardi >PC it is hard to tell you where to begin.
connect to usb RX,TX,5V,GND to the corresponding pins on the board, then you should be able to connect it to computer like usual. you just won't have a neat connector which is simple to use.
I forgot to mention that you'll need a usb to serial breakout board.
Just make sure that whatever you get has both the CTR and CTS pins and preferably a 5V/3V switch as you could very well find more use for that down the road !
