juffin
March 21, 2021, 11:29pm
#1
Hello. I try to connect my Arduino pro mini to ESP32 via Serial port. My code:
SoftwareSerial EspSerial(10, 11); // RX, TX
void setup(void) {
EspSerial.begin(115200);
if (EspSerial.available() > 0) {
String EspSerialRead = EspSerial.readString();
Serial.print("EspSerialRead: ");
Serial.println(EspSerialRead);
EspSerial.write(10);
But I have some trouble: Arduino get message from ESP32 but not send any to it. I test it via USB port and get the same result - get message from terminal but not any send. Please, help, what could be the problem? Thanks!
The highest baud rate that SoftwareSerial can reliably operate is 38400.
juffin
March 22, 2021, 5:59am
#3
I change it to 9600 but it's the same - read ok, but can not send
Do you have an Oscilloscope or a second Arduino to run a test?
juffin
March 22, 2021, 11:08am
#5
no, I don't have oscilloscope...
I connect ESP32 to PC via usb and all work fine, then connect my Arduino and not get any data in port...
At least you answer half a question, I'm out!!!!!!!
system
Closed
July 20, 2021, 11:13am
#7
