LarryD:
What do you mean by flicker?
I am seeing the light switching from on to off to on at a high frequency from when it starts the "sunrise" till the "sunset".
JohnRob:
Question regarding flickering:
Is the flickering continuous (like looking at a bulb through a fan)?
Or is it more random like a loose wire? (not suggesting your problem is a loose wire.)
Flickering is continuous from the sunset till sunrise and yes exactly like looking at a bulb through a fan.
JohnRob:
LarryD is of course correct regarding the IRF520 but if you have a light enough load you can usually get by. A good test would be to change the "PWM signal to the MOSFET module" to a pin on the arduino that is always 5V. If the LED's stay on all the time then you have a good chance you can get by with the 4.? volts the arduino is able to supply. I say good chance because depending on your PWM frequency and desired dutycycle you may have some dynamic issues.
Two other questions:
- Can you better explain your statement "on the other MOSFET I am using the 5V, pin6 for pwm and ground"?
I am trying an IRF520 and an AOD4184A MOSFET. The IRF520 has 3 inputs. 1 5V, 1 Ground and 1 PWM signal. The AOD4184A has 2 inputs. 1 Ground and 1 PWM.
I tried using the AOD4184A and used 5V and a ground, and the light did not flicker.
Data sheet of AOD4184A: http://www.aosmd.com/pdfs/datasheet/AOD4184A.pdf
Code I am using:
/* Aquarium Light Controller
Written by John Dimo
Sets turn on time, turn off time, power loss failsafe, adjustable sunset/sunrise
times, smooth fading LED on/off, override button, max brightness control,etc.
Arduino Pin 6 is the output for lights.
Arduino Pin 12 is for the override button.
Arduino Pins A0 and A1 are for the RTC module.
Version 1.0 - Initial Version. Basic light timer, with adjustable
ramp up/down and total running time.
Version 1.1 - Added code for LCD display to show diagnostic messages.
Version 1.2 - Added adjustable max brightness control.
Version 1.3 - Removed all the delays so that code can loop through and do other
stuff during sunrise and sunset timing code.
Version 1.4 - Added Override Button to turn lights on and off.
Version 1.5 - Added RTC module. Now has daily adjustable start time.
Version 1.6 - Added alarm for daily adjustable off time. Added failsafe to restart
lights in the event of power loss.
Version 1.7 - Added smooth on/off for the lights when using override button or
when recovering from power loss.
// user adjustable timing
int rampTime = 5; //Time in minutes to turn on/off the lights
int maxBrightness = 100; //Brightness in percentage
byte alarmOn[] = {12, 00}; // set the hour and minutes to start and stop the
byte alarmOff[] = {19, 00}; // timer, must use 24 hour time format
/////// Change nothing below here !!! ////////////////////////////
#include <Time.h>
#include <Wire.h>
#include <DS1307RTC.h>
// global variables
int stage = 0; // set initial timing stage
int buttonState;
int lastbuttonState = HIGH;
unsigned long oldButtontime = 0;
unsigned long oldRamptime = 0;
int lightOutput = 0;
int lightSetpoint = 0;
int overridelights = LOW;
//setup loop
// Setup some pins to power the RTC. Will not be needed when building the board
//pinMode(A3, OUTPUT);
//digitalWrite(A3, HIGH);
//pinMode(A2, OUTPUT);
//digitalWrite(A2, LOW);
setSyncProvider(RTC.get); // tell code to get the time from RTC
pinMode(6, OUTPUT); //setup the output pin
pinMode(12, INPUT); // setup the input button
pinMode(13, OUTPUT); //temp diagnostic LED
maxBrightness = map(maxBrightness,0,100,0,255); // Map percentage to output range.
rampTime = rampTime * 60000 / maxBrightness; // Setup ramptime delay based on max brightness setting
//setup fail safe to restart lights during lights ON stage.
if (word(hour(), minute()) >= word(alarmOn[0],alarmOn[1])) {
if (word(hour(), minute()) <= word(alarmOff[0],alarmOff[1])){
lightSetpoint = maxBrightness;
stage = 2;
//main program loop
unsigned long currentTime = millis(); //set current time
//override button code. ignores if you hold button down. handles hardware debounce
int reading = digitalRead(12);
if (reading != lastbuttonState) {
oldButtontime = currentTime;
if (currentTime - oldButtontime > 50) {
if (reading != buttonState) {
buttonState = reading;
if (buttonState == LOW) {
//This is the part of code that does something when button is pressed
overridelights = !overridelights; // toggle the override
lastbuttonState = reading; // update the state of the button
//Diagnostic LED to if we're in manual override mode or not.
if (overridelights == HIGH) digitalWrite(13, HIGH);
if (overridelights == LOW) digitalWrite(13, LOW);
// Stage 0. Waiting for alarm that starts lighting cycle
if (stage == 0 && (hour() == alarmOn[0]) && (minute() == alarmOn[1])) stage = 1;
// Stage 1. Sunrise Code.
if (stage == 1 && currentTime - oldRamptime > rampTime) {
oldRamptime = currentTime;
lightSetpoint++;
if (lightSetpoint == maxBrightness) stage = 2;
// Stage 2. Waiting for alarm that stops lighting cycle.
if (stage == 2 && (hour() == alarmOff[0]) && (minute() == alarmOff[1])) {
stage = 3;
// Stage 3. Sunset Code.
if (stage == 3 && currentTime - oldRamptime > rampTime) {
lightSetpoint--;
if (lightSetpoint == 0) stage = 0;
//During lights ON stages, override turns off lights
if (stage != 0 && overridelights == HIGH) {
for(lightOutput; lightOutput >= 0; lightOutput--) {
analogWrite(6, lightOutput);
delay(4);
lightOutput = 0;
//During lights ON stages, set lights to current setpoint
if (stage != 0 && overridelights == LOW) {
if(lightOutput < lightSetpoint) {
for(lightOutput; lightOutput <= lightSetpoint; lightOutput++) {
delay(4);
if(lightOutput > lightSetpoint) {
for(lightOutput; lightOutput >= lightSetpoint; lightOutput--) {
delay(4);
// During lights OFF stage, overries will turn on the lights.
if (stage == 0 && overridelights == HIGH) {
for(lightOutput; lightOutput <= maxBrightness; lightOutput++) {
delay(4);
// During lights OFF stage, turn off lights.
if (stage == 0 && overridelights == LOW) {
delay(4);
lightOutput = 0;
