Hi, so I'm trying to build this project... but when I upload the code to the Arduino and the correct code to the processing ide, and fill in the correct port that my Arduino is connected to, I get this error:
RuntimeException: Error opening serial port /dev/cu.usbmodem14101: Port busy
I don't know for sure but my guess would be because the Arduino IDE is still connected to the serial port, which would prevent any other application using it. Try closing the Arduino IDE.
hmm... just tried that. now I'm getting this error:
java.lang.NullPointerException: Cannot invoke "java.io.InputStream.read()" because "[this.in]" is null
at java.base/java.io.DataInputStream.readInt(DataInputStream.java:393)
at processing.core.PFont.(PFont.java:354)
at processing.core.PApplet.loadFont(PApplet.java:5838)
at RADAR_PROJECT_process.setup(RADAR_PROJECT_process.java:55)
at processing.core.PApplet.handleDraw(PApplet.java:2088)
at processing.awt.PSurfaceAWT$9.callDraw(PSurfaceAWT.java:1386)
at processing.core.PSurfaceNone$AnimationThread.run(PSurfaceNone.java:356)
RuntimeException: Could not load font OCRAExtended-30.vlw. Make sure that the font has been copied to the data folder of your sketch.
