A push button and led should have been added with this sketch. When the button is pressed once the led should turn on and off for a certain period of time
please help
#define relayPin 8 // the pin relay is connected
#define potPin A0 // the pin potentiometer is connected
#define resetPin 3 // the pin where rest switch is connected
#define startPin 2 // the pin where start switch is connected
#define relayType 'L' // Relay trigger type. L for low and H for high
//because the time below is in millisecond, 1000ms=1 second, 1000x60=60000 is 1 minuets. 60x60x1000=3600000 is 1 hour
const long maxTime = 30000;// maximum timer time in milliseconds. for one minute =60000, 1 hours =3600000
const long minTime = 3000; // miniimum timer time in milliseconds
// do not change anything bellow here
long duration;
int potValue;
long rememTime;
int relayState =0;
pinMode(relayPin, OUTPUT);// define relayPin as output
pinMode(resetPin, INPUT_PULLUP);// define input pin with pullup (watch video)
pinMode(startPin, INPUT_PULLUP);// define input pin with pullup (watch video)
attachInterrupt(digitalPinToInterrupt(resetPin), reset, LOW);
Serial.begin(9600);// initialize serial monitor with 9600 baud
if(relayType == 'L')
digitalWrite(relayPin, HIGH);// turn the relay OFF and keep it OFF
Serial.println("......");
Serial.println("Relay Type: LOW Trigger");
}else{
digitalWrite(relayPin, LOW);// turn the relay OFF and keep it OFF
Serial.println("Relay Type: HIGH Trigger");
potValue = analogRead(potPin)/10;// reads the value of the potentiometer (value between 0 and 1023)
duration = map(potValue, 0, 102, minTime, maxTime);// convert A0 value to time set at minTime and maxTime
if(digitalRead(startPin) ==LOW)
rememTime = millis();
relayState = 1;
controlRelay();// send command to turn the relay ON
if( (millis()- rememTime) > duration )
relayState = 0;
controlRelay();
Serial.print("Time: ");
Serial.print(duration/1000);
Serial.println(" Seconds");
delay(200); // wait for 200 milliseconds
}// loop end
* @brief Turns the relay ON or OFF
* @param none
* @return no return value
void controlRelay()
if(relayState == 1)
digitalWrite(relayPin, LOW);// Turn ON relay
Serial.print("LT-Relay ON for ");
Serial.print(duration/1000);// display in seconds
}else{
digitalWrite(relayPin, HIGH); // turn OFF
Serial.println("====Relay is OFF");
}else{
if(relayState == 1)
Serial.print("HT-Relay ON for ");
}else{
Serial.println("==Relay OFF");
}//controlRelay end
void reset()
duration =0;
digitalWrite(relayPin, HIGH);// turn OFF High trigger relay
}else{
digitalWrite(relayPin, LOW);// turn OFF Low trigger relay
Serial.println("Relay OFF");
}//reset()
Hello ash2002
It seems to be a school assigment, isn´t it?
Post your sketch, well formated, with comments and in so called code tags "</>" and schematic to see how we can help.
const byte triggerInputPin = 2; // your start-pin
// reset is done by the code: a monoflop resets ITSELF
const byte triggerIsActive = LOW; // shall triggering happen if trigger-input is LOW or HIGH?
const byte PinToSwitch = 8; // your relay-pin
const byte OutPutOn = HIGH; // is output "active" with IO-pin beeing LOW or HIGH?
// the attention-mark ! is the not-operator which inverts the value
// !true = false !false = true !HIGH = LOW !LOW = HIGH
const byte OutPutOff = !OutPutOn;
// set InitialWaitTime to 0 if you don't want a delay between triggering and switching output
unsigned long InitialWaitTime = 2000; // set to zero if you don't want an initial wait
unsigned long ActiveTime = 3000;
unsigned long LockedTime = 10000; // set to zero if you don't want a lock-time
unsigned long MonoFlopTimer; // variable used for non-blocking timing
// constants of the state-machine
const byte sm_Idling = 0;
const byte sm_InitialWait = 1;
const byte sm_Activated = 2;
const byte sm_Locked = 3;
byte MonoFlopState = sm_Idling; // state-variable of the state-machine
void PrintFileNameDateTime() {
Serial.println( F("Code running comes from file ") );
Serial.println( F(__FILE__) );
Serial.print( F(" compiled ") );
Serial.print( F(__DATE__) );
Serial.print( F(" ") );
Serial.println( F(__TIME__) );
// easy to use helper-function for non-blocking timing
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
if ( currentMillis - startOfPeriod >= TimePeriod ) {
// more time than TimePeriod has elapsed since last time if-condition was true
startOfPeriod = currentMillis; // a new period starts right here so set new starttime
return true;
else return false; // actual TimePeriod is NOT yet over
unsigned long MyTestTimer = 0; // Timer-variables MUST be of type unsigned long
const byte OnBoard_LED = 13;
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
static unsigned long MyBlinkTimer;
pinMode(IO_Pin, OUTPUT);
if ( TimePeriodIsOver(MyBlinkTimer, BlinkPeriod) ) {
digitalWrite(IO_Pin, !digitalRead(IO_Pin) );
Serial.println("Setup-Start");
PrintFileNameDateTime();
pinMode(triggerInputPin,INPUT_PULLUP); // INPUT_PULLUP
digitalWrite(PinToSwitch,OutPutOff);
pinMode(PinToSwitch,OUTPUT);
void MonoFlopStateMachine() {
switch (MonoFlopState) {
case sm_Idling:
// check if trigger-input reads triggering signal
if (digitalRead(triggerInputPin) == triggerIsActive) {
MonoFlopTimer = millis(); // make snapshot of time
MonoFlopState = sm_InitialWait; // set next state of state-machine
Serial.println( F("trigger-signal detected start inital wait") );
break; // IMMIDIATELY jump down to END OF SWITCH
case sm_InitialWait:
// wait until initial waittime has passed by
if ( TimePeriodIsOver(MonoFlopTimer,InitialWaitTime) ) {
// if waittime HAS passed by
MonoFlopTimer = millis(); // make new snapshot of time
digitalWrite(PinToSwitch,OutPutOn); // switch IO-Pin to activated state
MonoFlopState = sm_Activated; // set next state of state-machine
Serial.println( F("InitialWaitTime is over switching output to ACTIVE") );
case sm_Activated:
// check if time the IO-pin shall be active is over
if ( TimePeriodIsOver(MonoFlopTimer,ActiveTime) ){
// if activetime of IO-pin IS over
digitalWrite(PinToSwitch,OutPutOff); // switch IO-pin to DE-activated state
MonoFlopState = sm_Locked; // set next state of state-machine
Serial.println( F("Activetime is over switching output to IN-active") );
Serial.println( F("and starting locktime") );
case sm_Locked:
// check if time the logic shall be locked against too early re-triggering is over
if ( TimePeriodIsOver(MonoFlopTimer,LockedTime) ){
// if locked time IS over
Serial.println( F("locktime is over change state to idling") );
MonoFlopState = sm_Idling; // set state-machine to idle-mode
} // END OF SWITCH
BlinkHeartBeatLED(OnBoard_LED, 250);
// run down code of state-machine over and over again
// all the logic for reading in sensor-signal and switching output ON/OFF
// is inside the function
MonoFlopStateMachine();
