Arduino REV3 and potentiometers
Hi everybody,
I'm having problems trying to control a digital potentiometer MCP4151 with my Arduino.
I've tried and checked everything, the card is OK, I tested a hundred different codes, but the resistance on the wire just won't change. I tested the voltage on the POW pin and it gets stuck at 0,025V or 2,5V or 0,71V (depending on his mood I guess because I don't change the program).
here's the datasheet of the chip https://cdn-reichelt.de/documents/datenblatt/A200/MCP4151_MIC.pdf
and you can find my code and schematic view of electronique assembly.
Thanks a lot for your Help ! You're my last hope !
test_SPI.ino (552 Bytes)
How to post images.
#include "SPI.h" // necessary library
const int ss = 10; // using digital pin 10 for SPI slave select
  SPI.begin();    //Begins the SPI commnuication
  pinMode(ss, OUTPUT); // we use this for SS pin
  SPI.setClockDivider(SPI_CLOCK_DIV64);    //Sets clock for SPI communication at 8 (16/64=0.25Mhz)
  digitalWrite(ss, LOW);
  SPI.transfer(0x11);
  SPI.transfer(255);
  digitalWrite(10, HIGH);
How to post code and advice on how to use the forum.
Clickable link to data sheet.
