I am interested in using some of the Arduino Atmega2560 schematics to build my own PCB which will later be used in commercial use for profit. I am basically using the exact same design, but I will be adding external RAM to my board.
Could someone let me know if I would need to get FCC or any other licensing approval? The product will only be available in Canada though. Since it is built for a client that only intends to use the product in Canada.
I notice the Arduino Atmega2560 already has FCC and CE stamps on them if I am not changing the design does that mean I don't need to get FCC or CE certificate.
Also what copyright notice would I have to use, do I just attach the notice to my design or is there a filing process?
Thanks for the reply. I have spoken to multiple person that work in industry many of them said I don't have to bother to approval in Canada with my deisign. I will look into this more
Also I notice much of the Arduino board design is what is in the Atmel datasheet. If I just use the Atmel datasheet to make the board why could I have to use there copyright notice.
There design takes exactly what the Atmel says and dumps it on the board with very little changes.
Even if you use the exact schematic your board design will be different and therefore radiate differently, so I would assume that certifications like FCC have to be done for your exact product, assuming of course they have to be done at all with a given country and product type.
you ARE changing the design. as soon as you swap one carbon resistor for a metal one, you changed the design.
Regards
Depends what the client does, there are exemptions in the uk.
Public sale requires approval.
In the U.S. you need FCC Part 15B certification. To obtain a certification certificate, you must send your finished product to a testing lab. Cheapest Part 15B testing I've ever had done cost about $4000.
In Canada you need "Industry Canada" certification.
Computer devises are required to be tested as "unintentional radiators". Meaning any creation of an RF signal, which
is what the CPU local oscillator does, must be tested and certified the RF level is below a certain level to prevent
interference to other devises.
Selling or marketing an unapproved, non certified product, can result in FCC fines of up to $15,000 per devise.
