Arduino sending data through bluetooth to multiple phones--possible?
All,
I have a project where my Arduino and HC-05 sends data to an Andriod phone--it works fine. Can additional phones be paired to the HC-05? The phones will only receive data.
If not is there any way to get this to work?
Thanks in advance.
From my tests and what I've been reading, it looks like phones are Master only--so I can't pair multiple phones to the same HC-05. I guess I need them to be slaves, but that doesn't look possible. I can't pair more that one phone to my HC-05 device and if I set my HC-05 to master, I can't pair it to the phone--apparently you can't pair a master to a master.
Basically I need to send small amounts of data to several cell phones every few seconds for around 90 minutes.
Anyone seen any alternatives? Maybe I can set up one "master" phone to the HC-05, then have it host data to the web for other phones to pull? I don't know, kinda stumped here....
Thanks in advance.
KrisKasprzak:
I think that's nonsense. You are implying that a master can only only pair with a slave - which is surely nonsense. I suspect the only thing that counts is that a master initiates the connection, and it neither knows nor cares if the other party is a master or not. In this case, the HC-05 does the connecting, even if the phone has to do the pairing, which is essentially a formality. I also suspect you don't understand the difference between pairing and connecting.
I'm not sure how good an idea it is but I believe you might be able to it, The problems are entirely at the Android end, as you will need a terminal that can auto-connect. As far as Arduino is concerned, it is just a matter turning Bluetooth power off and on, and allowing only connection to a specific Android each time you do so. This is rather like what your car does each time you turn the radio on.
