Arduino servos (Spanish and English language)
Guys how can i action a servo with only one button.
The servo move 90° and after 1 second go back to the original state.
Srry if my english is bad, my original lenguaje is spanish.
Chicos como puedo accionar un servomotor con un pulsador o boton,el servomotor se mueve 90 grados y despues retrocede y vuelve al estado original.
(Could anyone send me a schematic that matches with this code)
#include <Servo.h>
Servo myservo;
const int buttonPin = 2;
int val;
int buttonState = 0;
  myservo.attach(9);
  pinMode(buttonPin, INPUT);
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
    val = 90;
  else {
    val = 0;
  myservo.write(val);
  delay(15);
Hello @nounlag - Tu codigo necesita algunos cambios para hacer el boton y hacer un temporizador. Aquí está el código con los cambios:
(I made a mistake before... here is the better sketch)
#include <Servo.h>
Servo myservo;
const int servoPin = 9;
int val;
unsigned long currentMillis; // "now" time
unsigned long previousMillis = 0; // "last" time
const long interval = 1000; // one second
  myservo.attach(servoPin);
  myservo.write(0); // move servo to 0
  buttonState = digitalRead(buttonPin); // read the button
  if (buttonState == HIGH) { // button was pushed
    myservo.write(90); // tell servo to move
    previousMillis = millis(); // set button press time
  currentMillis = millis(); // now!
  if (currentMillis - previousMillis >= interval) { // difference of now and button press
    myservo.write(0); // move servo home
And here is a simulation link. Press green "play" button to start, then red button to move servo.
Do you have a 10k pulldown resistor connected from pin 2 to GND?
