ELECROW Arduino Automatic Smart Plant Watering Kit:
This kit is based on Arduino Leonardo which has been integrated into the mainboard. They add an RTC to set timing watering and a 0.96-inch OLED to show the time and the soil moisture status. The kit includes a pump, capacitive soil moisture sensors, a water switch to redirect the water to up to 4 plants, and pipes for the water to go through. Compared with the resistance moisture sensor, the soil moisture sensor is made of a corrosion-resistant material, which will provide a long service life. The Smart Watering Kit allows you to provide all your own smart plant monitoring systems with ease of use and unlimited options!
Features of the Automatic Smart Plant Watering Kit:
- The kit includes a Smart Pump Board with an integrated control board (Arduino Leonardo), eliminating the need for an external control board.
- The water pump in the kit operates at a very low noise level, measuring less than 65 dB. This is significantly quieter than a desktop fan operating in high mode, which typically produces around 70 dB of noise.
- The kit is equipped with long-life Soil Humidity Sensors that accurately measure the moisture content in the soil.
- The components of the kit are designed for easy installation and use, following a plug and play approach. No more dealing with messy jumpers and wires. Anyone can assemble the kit effortlessly.
- With just one kit, you can control the watering process for up to 4 plants simultaneously.
- The kit features a single power supply that efficiently powers all the components.
- A 1.3" OLED screen is included, displaying the humidity percentage for each plant, providing you with real-time information.
- The kit incorporates a Real-Time Clock (RTC) with battery backup. The RTC not only keeps track of the current time but also allows you to program specific actions at desired times. It enables you to set the watering frequency for your plants and displays the watering time on the OLED screen.
These features make the Automatic Smart Plant Watering Kit a comprehensive and user-friendly solution for maintaining healthy plants with minimal effort.
