I try to write on the display the contents of a variable. This variable receives information from the Data Base. The problem is that I can not write the contents of the variable (rcv) on the display.
If you are not getting anything at all displayed on the LCD, then try first with a minimal sketch which tests only the LCD without any other logic. If that does not work, post a wiring diagram.
OP's code
#include <SPI.h>
#include <Ethernet.h>
#include <LiquidCrystal.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192,168,1,216};
byte servidor[] = { 192,168,1,185};
EthernetClient cliente;
float sensor1 = 0;
float sensor2 = 0;
float sensor3 = 0;
int pinSensorPIRDireita = 8;
int led = 9;
int valorSensorPIRDireita = 0;
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
String rcv="";
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("Hello World!");
Ethernet.begin(mac, ip);
// servidor.begin();
pinMode(pinSensorPIRDireita,INPUT);
pinMode(led,OUTPUT);
void httpRequest()
if (cliente.connect(servidor, 8095))
//Serial.println("Connection established 1");
cliente.print(String("GET ") + "/arduino/lerdados.php/" +"\r\n\r\n"); //GET request for server response.
unsigned long timeout = millis();
while (cliente.available() == 0)
if (millis() - timeout > 25000) //If nothing is available on server for 25 seconds, close the connection.
return;
while(cliente.available())
String line = cliente.readStringUntil('\r'); //Read the server response line by line..
rcv+=line; //And store it in rcv.
cliente.stop(); // Close the connection.
Serial.println("Connection failed 1");
Serial.println("Received string: ");
Serial.println(rcv); //Display the server response.
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(0,1);
lcd.print("Hello");
rcv = "";
char comando = Serial.read();
sensor1 = 5;
sensor2 = 10;
sensor3 = 15;
httpRequest();
delay(20000);
if (comando == 'a')
if(cliente.connect(servidor, 8095))
Serial.println("ligado ao servidor");
cliente.print("GET /arduino/guardardados.php?");
cliente.print("sensor1=");
cliente.print(sensor1);
cliente.print("&sensor2=");
cliente.print(sensor2);
cliente.print("&sensor3=");
cliente.println(sensor3);
Serial.println("Sensor1 = ");
Serial.println(sensor1);
Serial.println("Sensor2 = ");
Serial.println(sensor2);
Serial.println("Sensor3 = ");
Serial.println(sensor3);
cliente.stop();
Serial.println("erro ao ligar ao servidor");
