Arduino stop working or automatic reset
Hello everyone, I have the project to calculate RPM and set specific the RPM to run motor. I already watched video in Youtube that how to calculate RPM, but I have a problem with program. I used Arduino UNO R3 and Motor DC 12V with XY-160D Motor Driver to run, When I does not supply voltage for motor, Arduino is working correct and I am using my hand to push encoder that Arduino response. But when I supply 12V into Motor, Arduino print out many strange character and stopped or auto reset. Some one can help me ?
#include <util/atomic.h>
#include <PinChangeInterrupt.h>
#define ENCODEROUTPUT_MOTOR 48
#define EN_MOTOR 3
#define IN1_MOTOR 2
#define IN2_MOTOR 4
#define ENCA_MOTOR 10
#define ENCB_MOTOR 11
unsigned long prevT = 0;
unsigned long currT = 0;
int posPrev = 0;
volatile long pos_i = 0;
  // delay(5000);
  pinMode(EN_MOTOR, OUTPUT);
  pinMode(IN1_MOTOR, OUTPUT);
  pinMode(IN2_MOTOR, OUTPUT);
  pinMode(ENCA_MOTOR, INPUT_PULLUP);
  pinMode(ENCB_MOTOR, INPUT_PULLUP);
  attachPCINT(digitalPinToPCINT(ENCA_MOTOR), readEncoderMotor, RISING);
  prevT = micros();
  long pos;
  ATOMIC_BLOCK(ATOMIC_RESTORESTATE) {
    pos = pos_i;
  currT = micros();
  // update after 100ms
  if (currT - prevT >= 100000) {  // 100000 us = 100 ms
    float deltaT = (currT - prevT) / 1.0e6;
    long deltaPos = pos - posPrev;
    if (deltaT > 0.0001) {
      float velocity = deltaPos / deltaT; //pulse/s
      float v = velocity / ENCODEROUTPUT_MOTOR * 60.0; // RPM
      Serial.print("RPM:");
      Serial.println(v);
    prevT = currT;
    posPrev = pos;
  setMotor(1, 15, EN_MOTOR, IN1_MOTOR, IN2_MOTOR);
void setMotor(int dir, int pwmVal, int EN, int IN1, int IN2) {
  analogWrite(EN, pwmVal);
  if (dir == 1) {
    digitalWrite(IN1, HIGH);
    digitalWrite(IN2, LOW);
  } else if (dir == -1) {
    digitalWrite(IN1, LOW);
    digitalWrite(IN2, HIGH);
void readEncoderMotor() {
  if (digitalRead(ENCB_MOTOR) == HIGH) {
    pos_i++;
    pos_i--;
Serial print out:
15:41:18.023 -> RPM:0.00
15:41:18.154 -> RPM:25.00
15:41:18.232 -> RPM:62.50
15:41:18.338 -> RPM:37.49
15:41:18.410 -> RPM:0.00
15:41:18.531 -> RPM:0.00
15:41:18.610 -> RPM:0.00
15:41:18.730 -> RPM:0.00
15:41:18.810 -> RPM:0.00
15:41:18.948 -> RPM:12.50
15:41:19.031 -> RPM:50.00
15:41:19.031 -> 7RPM:0.00
15:41:52.084 -> ��
Please show your schematic - for example, a photo of hand driven picture will be enough.
Please post a schematic of your project showing how all components are connected and powered
Here is my schematic.
I reply below this comment.
I have this image in the below
Where is the Arduino power, is it USB?
Yes, I am using USB to supply Arduino
Hi @dainoso ,
I have ported your sketch to Wokwi and added a function that simulates the encoder pulses (more or less).
You can check it out on Wokwi
https://wokwi.com/projects/440279150495983617
Feel free to find and read also some comments regarding your code that might be of interest for you:
   Forum: https://forum.arduino.cc/t/arduino-stop-working-or-automatic-reset/1404103
   Wokwi: https://wokwi.com/projects/440279150495983617
  2025/08/25
  ec2021
  The function simulateRPM() was added to simulate the encoder pulses that usually come from
  a motor encoder.
  This is a commented version
// As #defines can be redefined during the code without notice
// it is recommended to use const or constexpr variables instead
// of #define
#define EN_MOTOR 3
#define IN1_MOTOR 2
#define IN2_MOTOR 4
int posPrev = 0;        // posPrev is ment to hold the previous value of long pos_i
// therefore it must have the same type!
// The code runs into trouble as the following lines show
// when posPrev overflows:
  RPM:599.98
  RPM:600.00
  RPM:587.45
  RPM:599.95
  RPM:819603.25
  RPM:819701.68
  RPM:819787.50
  RPM:819800.00
volatile long pos_i = 0;// In the Arduino environment volatile is only required for hardware registers
// where the compiler cannot see any reason that the variable would change
// and its "optimization" would remove the variable access.
// The ATOMIC_BLOCK macro is exactly what's relevant here for two reasons:
// - It makes sure that the variable is read from memory (not from a procesor register)
// - Interrupts are disabled while reading the variable so that no other access can
//   interfere with its content and interrupts are safely enabled again at the end of
//   the macro
  // Today Serial communication to a PC is better done with 115200 Bd
  // delay(5000);
  prevT = micros();
  simulateRPM(600);
  // As the value of pos_i is only relevant inside the function
  // if (currT - prevT >= 100000) {}
  // It does not make sense to copy pos_i here with each loop
  // It is sufficient to call the ATOMIC_BLOCK copy function inside the following
  // if-statement only every 100 ms
  long pos;
    pos = pos_i;
  currT = micros();
    // currT - prevT must be always(!) greater or equal to 100000 at this line
    // due to the if-statement above
    // Therefore deltaT = (currT - prevT) / 1.0e6 = 100000/ 1.0e6 =  1.0e5/1.0e6 = 0.1
    // 0.1 is always larger then 0.0001
    // As the following if-statement will always be true (unless one reduces the timing interval)
    // it could be removed
      Serial.println(v);
    prevT = currT;
    posPrev = pos;
  // Calling the following function in every loop is wasting controller time
  // as the data and therefore the behaviour of the motors do not change
  // It would save valuable processor time if it was only called
  // - once in the beginning (e.g. in setup())
  // - once everytime when either direction or speed or both are changing
  if (dir == 1) {
  // This function is called on a RISING edge on pin ENCA_MOTOR but
  // reads the state of ENCB_MOTOR
  // There is no(!) synchronisation with ENCB_MOTOR!
  // It would be pure coincidence if both encoders work synchronized
  // If you change from ENCB_MOTOR to ENCA_MOTOR then
  // ENCA_MOTOR must always be HIGH when this ISR function
  // is called on a RISING edge. It would be different if it was called on FALLING or
  // - for both possibilities - with CHANGE mode however than pos_i would
  // count 1 up and down and always return zero
    pos_i++;
    pos_i--;
/* The following function creates pulses in pulseOutPin that */
/* simulate the encoder pulses of a given motor              */
void simulateRPM(uint16_t RPM) {
  constexpr byte pulseOutPin {5};
  static unsigned long lastPulse = 0;
  if (lastPulse == 0) {
    pinMode(pulseOutPin, OUTPUT);
    digitalWrite(pulseOutPin, HIGH);
  unsigned long noOfPulses = ENCODEROUTPUT_MOTOR * RPM / 60;
  unsigned long microsInterval = 1000000UL / noOfPulses;
  if (micros() - lastPulse >= microsInterval) {
    lastPulse = micros();
    digitalWrite(pulseOutPin, LOW);
    delayMicroseconds(5);
There is also a modified version of your sketch that includes the changes which I recommended.
See here https://wokwi.com/projects/440281601942207489
Modified Sketch
   Wokwi: https://wokwi.com/projects/440281601942207489
  2025/08/25
  ec2021
  a motor encoder.
  This is a version where the commented parts of
  have been changed.
constexpr uint16_t ENCODEROUTPUT_MOTOR {48};
constexpr uint8_t EN_MOTOR {3};
constexpr uint8_t IN1_MOTOR {2};
constexpr uint8_t IN2_MOTOR {4};
constexpr uint8_t ENCA_MOTOR {10};
constexpr uint8_t ENCB_MOTOR {11};
long posPrev = 0;
long pos_i = 0;
  prevT = micros();
  simulateRPM(600);
  currT = micros();
    long pos;
      pos = pos_i;
    Serial.println(v);
    prevT = currT;
    posPrev = pos;
  if (dir == 1) {
  pos_i++;
Hope that it is of assistance!
ec2021
BTW: Be aware that the function simulateRPM() has only a limited RPM range as it is called inside loop and therefore depends on the loop timing. However it should work as a cheap and simple means for basic testing ... And you can get a more stable RPM measurement by increasing the measurement interval from 100 ms to 250 ms, 500 ms or 1 s.
On the XY-160D motor driver, what voltage is output from the MOTOR1 and MOTOR2 pins?
It is below 12V for two PINS.
After I change my code which following your comment, my code is working correctly. But when I want to set RPM which is limited my motor to run by PID, my Arduino stopped again. I tried change Baud Rate into 115200 but it did not work. How do I fix it?
#include <PID_v1.h>
#define EN_MOTOR 3
#define IN1_MOTOR 2
#define IN2_MOTOR 4
float vFilt = 0;
float vPrev = 0;
long posPrev = 0;
long pos_i = 0;
// PID variables
double Setpoint, Input, Output;
double Kp = 1.0, Ki = 0.5, Kd = 0.1;  // Tune these values
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
  // delay(5000);
  prevT = micros();
  // PID setup
  Setpoint = 500;  // initial target RPM
  myPID.SetMode(AUTOMATIC);
  myPID.SetSampleTime(50);  // ms, must match RPM update interval
  myPID.SetOutputLimits(5, 20); // PWM range
  currT = micros();
  setMotor(1, (int)Output, EN_MOTOR, IN1_MOTOR, IN2_MOTOR);
    long pos;
      pos = pos_i;
    long deltaPos = (pos - posPrev);
    long velocity = deltaPos / deltaT; // pulse/s
    float v = velocity / ENCODEROUTPUT_MOTOR * 60; // RPM
    vFilt = 0.854*vFilt + 0.0728*v + 0.0728*vPrev;
    vPrev = v;
    // PID control
    Input = fabs(vFilt);
    myPID.Compute();
    Serial.print(fabs(v));
    Serial.print(",");
    Serial.println(Setpoint);
    prevT = currT;
    posPrev = pos_i;
  if (dir == 1) {
    pos_i++;
    pos_i--;
Just a few remarks:
  • The function simulateRPM() can be removed from your code, it's only required for testing in Wokwi.
  • The ISR function is called on a rising edge of ENCA_MOTOR, but it still reads the state of ENCB_MOTOR which is not synchronized at all to ENCA_MOTOR. See my comments above ... [in the code!]
  • setMotor() is still called once every loop although its parameters may only change every 100 ms. Why not moving setMotor() after the line myPID.Compute() ? That's where a new value would be calculated, correct?
You say, your Arduino stopped again. Could you explain a little bit more specific what happens?
I'm at the moment typing on my smartphone, so there's only limited support ...
while the RPM update rate in loop() is 100 ms.
Your motor power leads should be connected to terminals OUT3 and OUT4 on the XY-160D, is that what you have?
https://github.com/gramaziokohler/clamp_electronics/blob/master/doc/motor_driver/XY160D_7A_160W_MotorDriver.pdf
