Arduino to read Prius spark plug to play subwoofer
Okay. I'm sure I've already messed up. Sorry.
I want to build a project in my prius.
I got the amp/sound system working. looking at adding a little bit of fun.
Here is a microsoft paint drawing to help illustrate my idea.
Now I am very new, but I am pretty good at googling if you can start pointing me in the right direction.
Thank you for your time.
Jace
Arduinos are all digital. Music and woofers are all analog AC. They don't mix very well.
Paul
Not even close.
The frequency range of your subwoofer is?
The frequency output expected from that spark plug is?
How much overlap is there?
The engine RPM is going to be exactly the same as the spark plug fire rate. Well, divided by 2 for a four stroke engine. Have you considered just using the engine RPM? I suspect that would be a less electronics intensive project.
Oh, I was unaware of this. Would you have a recommendation of a board that may work?
I appear to of not explained this very well.
So spark plug would go off at a consistent timing if the engine is holding RPM. and we'll have this play at something like 30hz with a variation of 5hz to give it a little life/not be monotone and at 25db.
Then when accelerating as the RPM increases they just multiply the hz and db. so it'd go up to around 400hz (maybe the variation ratio changes, maybe keep it at 5... that'd be something to play with to get the right sound) and 80db
So basically I want to use a board to do an equation along with audio passthrough.
so switch ON:
RPM x .1 = hz
hz with some controlled randomized = hz out
RPM x .05 = db out
(And I have no idea how to turn that ^^^ into an audio signal... This is very much new territory for me.)
switch OFF:
just audio passthrough from the speaker wire to the amp...
