Arduino type swap possible?
So, i have designed a pcb with a boards mounted Arduino pro mini on it.
I reaoised in my haste i bought Arduino Nano's. Luckily i havent had the pcb made yet and wondered if there was any pertormance or programming difference between a pro mini and nano?
Ignore piniut as i can adjust that. Just code and performance.
Thanks
These are nearly identical.
The NANO has an onboard USB chip so you will not need the external FTDI that the ProMini needs.
The NANO might draw a bit more current than the ProMini.
Suggest you buy some ProMinis to use (don’t finalize your PCB until you receive them) and keep the NANOs for later.
The specs are here:
You can see that they're both ATmega328P.
Sounds like really good advice, and make sure the pin pattern matches the PCB layout.
I have build several boards where I plug in the Nano. Works nicely and with the USB setup debugging is much easier. I also put a SMPS on the board to generate the needed 5V. For me the Nano is about one of the most inexpensive Arduino's I can purchase.
Thanks for all the advice chaps. Ill get some pro mini aswell but investigate a dual footprint or similar.
BTW
I have 4 different ProMinis, each has a slightly different foot print.
Settle on one supplier.
There are 3V3 and 5V ProMini too?
Tom.. :grinning: :+1: :coffee: :australia:
Correction, I have 4 5 different ProMinis (including the one 3V3), each has a slightly different foot print.
Or design your board so you could use either
