Hi this is my firs post on these forums but i have made arduino obstacle avoidance robot car code that is pretty simple. I haven't tested it yet but it should work and I thought that I would share it in here because every code i have seen in the internet has been for servos not for motor controllers. So if anyone could give their opinion or help me with it and sorry for my bad english ![]()
/*#####Parts#####
* Motor Shield (L298N)
* Ultrasonic sensor (HC-SR04)
*#####Pins#####
* 5 --> ENA
* 6 --> ENB
* 2 --> IN1
* 3 --> IN2
* 4 --> IN3
* 7 --> IN4
* 8 --> Trig
* 9 --> Echo
#include <Servo.h>
Servo servo1; // Create object servo1
const int TrigPin=8; //trigger pin for the sensor
const int ReciPin=9; // echo pin for data recive from the sensor
const int DangerT=10; // min distange to the wall
// Left side
int ENA=5; //ENA anf ENB controlls speed of the motors
int IN1=2;
int IN2=3;
/*Here is the controlls for the motors
* IN1: HIGH; IN2: LOW --> Direction1 (Left side forward)
* IN1: LOW; IN2: HIGH --> Direction2 (left side backward
* IN3: HIGH; IN4: LOW --> Direction1 (right side forward)
* IN3: LOW; IN4: HIGH --> Direction2 (right side backward)
//right side
int IN3=4;
int IN4=7;
int ENB=6;
int Rdis; //variable for right side sensor value
int Ldis; //variable for left side sensor value
long duration; //distange to wall in centimetres
int motorSpeed=80; // speed for going forward
int motorTurnSpeed=110; // speed for turning
servo1.attach(10);
servo1.write(90);
pinMode(ENA,OUTPUT); //set pin modes
pinMode(IN1,OUTPUT);
pinMode(IN2,OUTPUT);
pinMode(ENB,OUTPUT);
pinMode(IN3,OUTPUT);
pinMode(IN4,OUTPUT);
pinMode(TrigPin,OUTPUT);
pinMode(ReciPin,INPUT);
int distange = ping();
if(distange>DangerT)// go forward if there isn't wall in front of the car
void forward();
else //if there is wall
void motorStop();
servo1.write(0); //turn the servo to right
delay(500); // wait for the servo to turn
Rdis = ping(); //ping right and save it to var Rdis
delay(100); // wait for the sensor to ping
servo1.write(180); // turn servo left
delay(700); //wait longer because the servo has to turn 180 degrees
Ldis = ping(); //ping left and save it to var Ldis
servo1.write(90); // senter the servo
delay(500); //wait for the servo to senter
cdis(); // goto compare distange
void cdis()
if(Ldis>DangerT) // if left is more than DangerT (10)
left(); // turn left
delay(500); // wait for the car to turn (you might need to adjust these timings for tunrnig)
motorStop(); // stop
else if(Rdis>DangerT) // if left where less than DangerT (10) check if right is less than DangerT (10)
right(); // turn right
delay(500); //wait for the car to turn
else // if right and left where less than DangerT turn around
left(); //turn left
delay(1000); //wait for the car to turn around
motorStop();//stop
long ping()
digitalWrite(TrigPin,LOW);//set the pn to low just in case
delayMicroseconds(2); //wait for it to turn
digitalWrite(TrigPin,HIGH); //set it high for 5 microseconds
delayMicroseconds(5);
digitalWrite(TrigPin,LOW);//and back to low again
duration = pulseIn(ReciPin,HIGH); // measure the time it took the sound to bounce back
return duration / 29 / 2; // calculate the distange (in centimetres)
void forward() // from here starts the motor controlls at the start if this sketch there where instructions on how to control the motors
digitalWrite(IN1,HIGH);
digitalWrite(IN2,LOW);
analogWrite(ENA,motorSpeed);
digitalWrite(IN3,HIGH);
digitalWrite(IN4,LOW);
analogWrite(ENB,motorSpeed);
void backward()
digitalWrite(IN1,LOW);
digitalWrite(IN2,HIGH);
digitalWrite(IN3,LOW);
digitalWrite(IN4,HIGH);
void left()
analogWrite(ENA,motorTurnSpeed);
analogWrite(ENB,motorTurnSpeed);
void right()
void motorStop()
analogWrite(ENA,0);
analogWrite(ENB,0);
