Hey Forumuser,
hab mich nun endlich mal an das Thema Datenlogger rangetraut und konnte auch schnell was im Internet finden, ich bin auf die SD-Karte gestoßen.
Nun kaufte ich mir sofort ein Shield, das hier http://www.ebay.de/itm/121208974870?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Anschlussplan sah zunächst sehr einfach aus :
GND ---- GND
MISO---- MISO
SCK ---- SCK
MOSI---- MOSI
CS ----- D10
+5V ----- +5V
Nun habe ich SCK und MOSI über einen Spannungsteiler auf den 3,3V Pegel angeschlossen.
Nun uploade ich auf mein Atmega168 das Beispielprogramm SD/CardInfo
SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
Pin 4 used here for consistency with other Arduino examples
created 28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
// include the SD library:
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = 10;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("\nInitializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT); // change this to 53 on a mega
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card is inserted?");
Serial.println("* Is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
return;
Serial.println("Wiring is correct and a card is present.");
// print the type of card
Serial.print("\nCard type: ");
switch(card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
default:
Serial.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
return;
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print("\nVolume type is FAT");
Serial.println(volume.fatType(), DEC);
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
volumesize *= 512; // SD card blocks are always 512 bytes
Serial.print("Volume size (bytes): ");
Serial.println(volumesize);
Serial.print("Volume size (Kbytes): ");
volumesize /= 1024;
Serial.print("Volume size (Mbytes): ");
volumesize /= 1024;
Serial.println("\nFiles found on the card (name, date and size in bytes): ");
root.openRoot(volume);
// list all files in the card with date and size
root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
Nur irgendwas muss ich falsch gemacht haben, öffne ich nun den Serial Monitor bewegt sich zwar die Leiste rechts ziemlich schnell, nur Text ist keiner zu sehen.
Selbst wenn ich die Karte nicht einstecke, bleibt die Fehlermeldung Serial.println("initialization failed. Things to check:");
auch aus.
Habe schon sogut wie alle Formate ausprobiert, die SD zu formatieren. In der Anleitung wurde auf das FAT16 hingewiesen.
Vielleicht kann mir jemand einen entscheidenen Tipp geben, bin kurz vor dem verzweifeln.
Danke schonmal für jede Mühe.
