system
December 18, 2012, 7:40pm
1
Hello electricfriends
I have a problem!
i want programm my AtTiny45 wit hmy arduino uno, all is ok. I uploaded the ArduinoISP file and then i want upload the example - blink. I setup all things like board and so on, but when i upload, the led on the testpin from the attiny45 (pin 0) blink for a micrsecond and then she is off. btw, followed error shows me the arduino ide:
Binäre Sketchgröße: 754 Bytes (von einem Maximum von 4.096 Bytes)
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny45
avrdude: Yikes! Invalid device signature.
** Double check connections and try again, or use -F to override**
** this check.**
PLEASE HELP ME, thx
Erni
December 18, 2012, 8:02pm
2
This error message can be ignored.
Try triplecheck your connections, or move the Attiny to another spot on your breadboard.
I have made a litlle recipe here:
http://www.ernstc.dk/arduino/attiny85.html
Edit: and the pinout are the same for Attiny45 and Attiny85
system
December 18, 2012, 8:46pm
3
the connection from your image have i. i have the same pins for each pin, all the same, what now? what is the "use -F ..." in the error?
pls help a second time, thx
Erni
December 18, 2012, 9:03pm
4
Did you connect the capacitor from reset to ground?
To be able to troubleshoot it would be easyer if you connected the 3 LED's mentioned in the ISP sketch, and tell us how they behave
And:
What core are you using
Which arduino version
system
December 18, 2012, 9:12pm
5
i have installed the led's, the green is on, and i use the arduino version 1.0.2
the cor, i have this one : Google Code Archive - Long-term storage for Google Code Project Hosting.
Erni
December 18, 2012, 9:27pm
6
the green is on
Do you mean the LED connected to pin9, it should fade up and down, known as heartbeat.
I still think you have some connection problems, try ton wriggle the tiny in the breadboard and do the same with your jumperwires.
I hav not tried version 1.02, maybe others can comment whether there are some changes that affect the ArduinoISP.
system
December 19, 2012, 5:59am
7
thx for help, but 1.: what do you mean with try ton wriggle?
2.: what does the use -F in the error mean?
TCWORLD
December 19, 2012, 2:24pm
8
-F is an avrdude flag. Basically you cant set it with arduino, only from command line. But you don't need or want to set it, all it tells avrdude to do is to ignore any verification error and continue on regarless - this will NOT help as whatever the current problem is will still be there and you will just end up with a corrupted chip.
Could you post a picture of your wiring so we can check it. It sounds like there is a loose connection somewhere or you have connected something up to the wrong place.
Also could you go to File->Preferences, and then check the box for 'upload' next to 'show verbose output during'. Then try programming again and copy and paste here what the messages you get in the black window at the bottm.
Also, check you have the correct programmer selected (Tools->Programmer->Arduino as ISP) and the correct Serial port (Tools->Serial Port). Finally, make sure you have selected ATTiny45 as the board (Tools->Board), and that you are using 'Upload Using Programmer' (File->Upload using programmer).
system
December 19, 2012, 2:35pm
9
the led dont blink!
here my code:
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 0;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
have i define the right pin for the var led ? (pin 0)
here my construction:
[picture in description!]
TCWORLD
December 19, 2012, 2:46pm
10
You need a 10k pullup resistor on the reset pin of the ATTiny (10k resistor from pin1 of ATTiny45 to +5v)
system
December 19, 2012, 2:52pm
11
it dont work. at uploading the code, it is the text in the black box:
D:\arduino-1.0.2\hardware/tools/avr/bin/avrdude -CD:\arduino-1.0.2\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -pattiny45 -cstk500v1 -P\\.\COM3 -b19200 -Uflash:w:C:\Users\Martin\AppData\Local\Temp\build4479880285862118345.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "D:\arduino-1.0.2\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM3
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATtiny45
Chip Erase delay : 4500 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 6 4 0 no 256 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 4096 64 64 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98] [20]
avrdude: Recv: . [00]
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Send: B [42] . [14] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] @ [40] . [01] . [00] . [00] . [00] . [10] . [00] [20]
avrdude: Send: P [50] [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00] [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00] [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00] [20]
################################## | 100% 0.06s
avrdude: Device signature = 0x000000
this check.
avrdude: Send: Q [51] [20]
avrdude done. Thank you.
my programcode is following:
Blink
// give it a name:
int led = 0;
TCWORLD
December 19, 2012, 2:59pm
12
Could you try disconnecting the LED from the attiny and upload again just to see if that is interfering with programming.
system
December 19, 2012, 3:01pm
13
it doesnt work, error:
D:\arduino-1.0.2\hardware/tools/avr/bin/avrdude -CD:\arduino-1.0.2\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -pattiny45 -cstk500v1 -P\\.\COM3 -b19200 -Uflash:w:C:\Users\Martin\AppData\Local\Temp\build8037476049004880033.tmp\Blink.cpp.hex:i
AVR Part : ATtiny45
PAGEL : P00
BS2 : P00
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
this check.
do you have skye? when yes, add marfi_98 for a chat between us (only write)
then i have an idea how u can help me
system
December 19, 2012, 3:09pm
14
do you have skype?
add marfi_98
i have an idea!
TCWORLD
December 19, 2012, 3:11pm
15
Post your idea here, I'm not available outside the forum.
system
December 19, 2012, 3:13pm
16
if u have teamviewer, u could test on my pc, and do it for me, pls^^
my teamviewer id is: 328 641 878
password is: 2471
system
17
password is: 2471
Erni
December 19, 2012, 3:30pm
18
As far as I can see on your picture the orange wire is going from the negative strip top to the postive in the buttom, and to pin 8 of the tiny ??
system
December 19, 2012, 3:32pm
19
no
here a new picture, pls someone come teamviewer
Erni
December 19, 2012, 3:38pm
20
Note that on all my attiny's there is a small dot in the plastic, this is pin 1
When I have that kind of errors I find that the easyist way to check that the programmer (Arduino in this case) is communicating with the Attiny, is to use a avrdude on a commandline
Try this:
Open a command prompt and type
avrdude -pattiny45 -Pcom20 -b19200 -carduino -v
Or show the verbose output that Tom Carpenter asked you about
