I have a UNO SMD ( not sure if its genuine) I used it several months and it worked perfectly, but now when i plug it in my computer the ATmega starts to heat up , I cant upload any code. Any idea what should I do??
I have a UNO SMD ( not sure if its genuine) I used it several months and it worked perfectly, but now when i plug it in my computer the ATmega starts ho heat up , I cant upload any code. Any idea what should I do??
Your topic has been moved. Please do not post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum.
also Your two topics on the same or similar subject have been merged.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum. It will help you get the best out of the forum in the future.
Thank you.
It gets hot with everything disconnected?
Just replace it.
And, @coding_boss, the second time you've been told. Do not cross-post again.
If the ATmega chip on your UNO SMD is heating up when plugged into your computer and you're unable to upload code, it could indicate a potential short circuit or hardware failure. Consider checking for any visible damage on the board, ensuring proper connections, and trying a different USB cable or port. If the issue persists, seeking assistance from technical support or considering a replacement may be necessary.
