I have been trying to install drivers for the arduino uno in win 7, but I got the error ‘This device cannot start. (Code 10)’ . So I am not able to upload any of my codes onto the board. It would be great if someone could help me with this issue. I have searched a lot in this forum for the similar posts; but they were slightly different from my problem.
Here is the log file 'setupapi.dvi’ (is attached along with the post) after the installation.
[Device Install (DiInstallDevice) - ROOT\PORTS\0000]
>>> Section start 2014/04/02 20:33:14.170
cmd: "C:\Windows\system32\mmc.exe" C:\Windows\system32\devmgmt.msc
dvi: Selected driver installs from section [DriverInstall] in 'c:\windows\system32\driverstore\filerepository\arduino.inf_amd64_neutral_844213a156728dfe\arduino.inf'.
dvi: Set selected driver complete.
inf: {SetupCopyOEMInf: C:\Windows\INF\oem77.inf} 20:33:14.174
inf: Opened PNF: 'C:\Windows\INF\oem77.inf' ([strings])
inf: Installing catalog arduino.cat as: oem77.CAT
! inf: Failed to install catalog - error ignored
! inf: Error 2: The system cannot find the file specified.
inf: {SetupCopyOEMInf exit (0x00000000)} 20:33:14.250
inf: Opened PNF: 'C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_neutral_844213a156728dfe\arduino.inf' ([strings])
sig: {_VERIFY_FILE_SIGNATURE} 20:33:14.258
sig: Key = arduino.inf
sig: FilePath = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_neutral_844213a156728dfe\arduino.inf
sig: Catalog = C:\Windows\System32\DriverStore\FileRepository\arduino.inf_amd64_neutral_844213a156728dfe\arduino.cat
! sig: Verifying file against specific (valid) catalog failed! (0x800b0109)
! sig: Error 0x800b0109: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider.
sig: {_VERIFY_FILE_SIGNATURE exit(0x800b0109)} 20:33:14.270
sig: {_VERIFY_FILE_SIGNATURE} 20:33:14.270
sig: Success: File is signed in Authenticode(tm) catalog.
sig: Error 0xe0000241: The INF was signed with an Authenticode(tm) catalog from a trusted publisher.
{Install Inf Section [DriverInstall.Services]}
inf: AddService=usbser,0x00000002,DriverService (arduino.inf line 138)
inf: ServiceType=1 (arduino.inf line 142)
inf: StartType=3 (arduino.inf line 143)
inf: ErrorControl=1 (arduino.inf line 144)
inf: ServiceBinary=C:\Windows\system32\DRIVERS\usbser.sys (arduino.inf line 145)
inf: DisplayName="USB RS-232 Emulation Driver" (arduino.inf line 141)
inf: LoadOrderGroup=Base (arduino.inf line 146)
dvi: Add Service: Modified existing service 'usbser'.
inf: {Install Inf Section [DriverInstall.Services] exit(0x00000000)}
dvi: Updated reflected section names for: oem77.inf
dvi: {Install DEVICE exit (0x00000000)}
dvi: Writing common driver property settings.
dvi: DriverDescription=Arduino Uno
dvi: DeviceDisplayName=Arduino Uno
dvi: Install Device: Restarting device. 20:33:15.600
dvi: Install Device: Restarting device completed. 20:33:15.618
!!! dvi: Device not started: Device has problem: 0x0a: CM_PROB_FAILED_START.
dvi: Class installer: Exit
setupapi.dev.log (72.4 KB)
