Arduino UNO R3 error: "avrdude: stk500_recv(): programmer is not responding"
hello i have the similar problem my error message is
 Sketch uses 4228 bytes (13%) of program storage space. Maximum is 32256 bytes.
Global variables use 567 bytes (27%) of dynamic memory, leaving 1481 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x15
Failed uploading: uploading error: exit status 1`
Use code tags to format code for the forum`
Hi @swalahudheen. Please add a reply here on this forum thread to tell us which Arduino board you are using.
Please be as specific as possible, as some Arduino boards with similar names have significant differences and the forum helpers can only provide effective assistance if we are aware of which one is being used.
If you aren't sure how to describe which board you are using, you can provide the link to the online product listing you bought the board from and we'll proceed based on the information found there.
@swalahudheen
Although I applaud you for researching your problem, it's preferred that you start your own topic; you can always refer to topics that you did find.
I've split your question to a new topic.
