Upload fails: "avrdude: stk500_recv(): programmer is not responding"
Continuing the discussion from Having problem uploading to board Arduino UNO R3:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
Sketch uses 3480 bytes (10%) of program storage space. Maximum is 32256 bytes.
Global variables use 252 bytes (12%) of dynamic memory, leaving 1796 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\pc\AppData\Local\Temp\arduino_build_804491/coding_motor.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf8
avrdude done.  Thank you.
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
option enabled in File -> Preferences.
@manroy
Please provide a link to the exact board that you're using. There are to many boards with Uno in their name.
Does COM4 disappear from the IDE (and from Windows device manager) when you disconnect the board?
What is the history of the board? Did it ever work? If yes, what was the last project that you were working on when it starter failing?
Please make sure to select the correct board!
