So i started getting the stk500_getsync(): not in sync: resp=0x00/0x30 error when i try to upload a sketch to Arduino Uno R3. I looked online and I checked the com ports and tried other one, swapped out the USB cable and reinstalled the drivers to no avail.
The loop back test sent back any text i sent it under the serial monitor.
Led 13 lights up
Power LED lights up
LED 13 flashes when I press reset?
Did i damage the voltage regulator or something else?
Can someone please help me troubleshoot this?
below i included the verbose text for the failed upload from the arduino program
Binary sketch size: 1,084 bytes (of a 32,256 byte maximum)
C:\Program Files\Arduino\hardware/tools/avr/bin/avrdude -CC:\Program Files\Arduino\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\.\COM1 -b115200 -D -Uflash:w:C:\Users\Yigiter\AppData\Local\Temp\build6756113867830342185.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files\Arduino\hardware/tools/avr/etc/avrdude.conf"
Using Port : \.\COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done. Thank you.
