Arduino UNO R4 interrpts do not work
This code does not work on the UNO R4
const byte ledPin = 13;
const byte interruptPin = 2;
volatile byte state = LOW;
  // initialize serial communication
  Serial.begin(57600);
  // while (!Serial); //
  pinMode(ledPin, OUTPUT);
  pinMode(interruptPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin), blink, CHANGE);
  digitalWrite(ledPin, state);
  Serial.print("State = ");
  Serial.println(state);
void blink() {
  state = !state;
The state never is set to 1.
I have two UNO R4's and both fail to fire interrupt.
I had been trying to use the GY-86 with interrupt, however, interrupt never happens.
Can someone help me with this?
Worked for me on my R4 minima once I took out all the duplicates of the code. Ground pin 2, state switches to HIGH, disconnect, back to LOW.
Try this slight modification which only prints when the state changes:
volatile bool state = LOW;
   static bool oldState = LOW;
   if( state != oldState ) {
      oldState = state;
      digitalWrite(ledPin, oldState);
      Serial.println(oldState);
      delay(20);
void blink() {
   state = !state;
Please look at the code that you posted. Did you make a mistake when posting it as it seems to be repeated multiple times
Thank you for your response.
I tried your code, however, seems the interrupt does not fire as there is no output to the serial console.
Not sure what else to check.
Thank you, I did not notice the double copy of the code.
I have to disagree.
Hi, once again thank you.
I should have read your reply more carefully.
If I ground pin 2 , I see the text in the console.
Many thanks, now I can concentrate on the GY-86 to determine why it is not firing its interrupt.
Now that your question has been answered, please take the time to mark the topic as solved by clicking the :ballot_box_with_check: Solution button at the bottom of the reply that answered your question, as shown in How to get the best out of this forum.
Good, so now please edit your first post and get rid of the duplicates... :wink:
done, thank you.
Not yet... :wink: You still have twice the same code (two setup, two loop, and two blink): remove everything after the first blink function and you're done! :slight_smile:
Thank you. I have cleaned up the code to remove the duplicates.
