Arduino UNO R4 WiFi LED Matrix Animation Helper (Excel Tool)
Hi Everyone,
I just got an R4 WiFi and played with the LED matrix after firing it up yesterday.
I geeked out a lot on the ArduinoLEDMatrix.loadSequence method and I created an Excel Spreadsheet with VBA that builds animation code from frames "drawn" in the Excel sheet. In each drawn frame, entering a "1" turns the cell red (the actual LED color) and entering a "0" or blank in each cell leaves it white.
I'm still working on it (perfecting it) but will share publicly once it's good enough.
Here's a couple of notes so far:
1.) It uses VBA (.xlsm) to update the code in real time (every time there is a change to any cell in the sheet).
2.) Copy->Paste from Excel to the Arduino IDE puts quotes around the whole code and additional quotes around "Arduino_LED_Matrix.h" (probably just going to live with that).
Best Regards,
Jordan Kerr
I've done somewhat similar things in Excel. It's generally possible to do this without using any VBA, which makes things a little easier to distribute. All it takes is a little creativity with existing excel functions.
Hi Rsmls - Yeah I might try for that later version or even before publishing (thought the same thing). It works now but still a bit to kludgy to share.
Cheers,
Jordan
Mind you,the VBA code may end up being easier to read and maintain than the function-based approach.
Hello everyone,
I also looked into this topic and posted a solution in Excel in the forum.
Take a look at the German forum under the topic 'arduino-uno-r4-wifi-matrix-bild-und-animation-erstellen'
The language can be changed to English...
Maybe it's what you have in mind or you can just use a few code snippets as inspiration for your project.
Greetings ewu
