Arduino Uno R4 Wifi RA4M1 USB bypass by soldering USB bridge pads
I soldered the USB bridge pads (RA4M1 USB) to program the RA4M1. However, the arduino completely does not show up when I connected it to my computer. May I know what should I do to make it work? Thanks for helping.
Welcome to the forum
Why do you want to do this ?
This might help https://docs.arduino.cc/tutorials/uno-r4-wifi/cheat-sheet/#usb-bridge
A while ago, when I was playing with the Arduino UNO Wifi (and Minima), I experimented
with a setup like this. However instead of soldering the connection I soldered a switch
across it.
At the time I created a Variant of the WiFi, to setup to use the Native USB on the
RA4M1, which is similar at that point to the Minima.
There are a few threads on it, including:
I personally preferred running in that mode, as USB is faster. Does not require the board to copy the USB data over a non-fifo UART to/from the ESP32, which then did the USB transfer.
It also allowed the more complete Serial USB interface to work... Not sure if I still have that
variant sitting around here... Most likely way out of date
Good luck
Hi if you have soldered the USB bridge pad , ground MD pin (1st unmarked pin next to IOREF) and connect USB cable and you should see Arduino come up in IDE. This is bootloader mode.
Hi, thanks for helping. I have tried connecting the pin next to IOREF pin to the GND pin but it didn't shows up when I connected with USB cable.
Thanks for helping out. I will try to do it, but not sure if I can do it correctly as I'm just a beginner
Hi @jinyuan219. Please answer @UKHeliBob's question:
My Arduino board seems not working with the esp32 because it shows as Device Description Failed at my device manager when I connected to my computer. I tried many ways but can't still resolve the issue. So I decided to try connecting the USB directly to the RA4M1.
