It will work directly, that sdcard reader have a 3.3v regulator included (AMS1117), so you don't need to care about voltages.
Just put 5v or the 3.3v from arduino directly in the corresponding pin 3v3 or 5v.
gordonpt:
That is not correct. If it was, the OP would not have a problem. On that SD card, there is no level converter. It may work with your SD card, but it may not on others.
Mine have level conversion with a resistors, if this one doesn't have it will be very strange.
If they care about powering with 3v3 why they leave it without level conversion for communication?
Anyway CPalha, I can't guarantee that. make sure that resistors are a tensor divisor.
Then it is very strange! Those resistors you see on that board are 10K pullups, not voltage dividers. They do nothing for the voltage levels. Putting 5 volts into a 3.3v input can damage both devices.
