Hello,
I am not able to format my SD card SanDisk ultra 64GB for unknown reasons.
Regardless, I have the SD card module and arduino uno setup as follows:
SCK PIN 13
MOSI PIN11
MISO PIN12
VCC -> Vin
GND-> GND
This is my code which runs initialization done but does not return true if the file exists and I can't open my file either in SD card:
#include <SD.h>
#include <SPI.h>
File myFile;
while (!Serial){
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
//Serial.println("initialization failed!");
Serial.println("initialization done.");
File myFile = SD.open("example.txt", FILE_WRITE);
myFile.print("hello");
Serial.println("hello");
myFile.close();
if(SD.exists("example.txt")){
//while(myFile.available()){
Serial.println("file exists");
else{
Serial.println("no file found..");
//Serial.print(myFile.read());
// nothing happens after setup finishes.
Any help is appreciated. Thank you.
