i made sketch on an UNO board wich work fine and i tried to move it to a NANO.
The Nano died...
Before trying an other (i know it is cheap, but..), can any one confirm they are pin compatibles.
my sketch drive a Servo and a 4 relay board. the comand relay board is connected to 5v from the arduino 5V source out, relays's power is external and not coonected.
the servo supply is connected to an external power suply (grounded all together).
any idea? tks
jym
Pin compatible as in "you can stick both in the same socket" then definiltely no, and that's because the Uno has female headers and the Nano has male headers.
Pin compatible as in "they have the same number and designations at their pins" then yes.
I do believe there is also some trouble using pins 4 and 5 for some things on the nano. nut in my experience which is limited. I have used a lot of sketch for both with simple pin changes
