Please help me for can not connect to any network by script but used the terminal control is connect.
I buy this board never to work connect any network.
#include <SPI.h> #include <WiFi.h>
char ssid = “ASUS”; // your network SSID (name)
char pass = “0894547578”; // your network password
int status = WL_IDLE_STATUS;
char servername=“google.com”; // remote server we will connect to
WiFiClient client;
Serial.println(“Attempting to connect to WPA network…”);
Serial.print("SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
if ( status != WL_CONNECTED) {
Serial.println(“Couldn’t get a wifi connection”);
// don’t do anything else:
while(true);
else {
Serial.println(“Connected to wifi”);
Serial.println("\nStarting connection…");
// if you get a connection, report back via serial:
if (client.connect(servername, 80)) {
Serial.println(“connected”);
// Make a HTTP request:
client.println(“GET /search?q=arduino HTTP/1.0”);
client.println();
It does appear from your first post the you Arduino WiFi board already has a wlan connection (192.168.1.252).
The web client example you are using, which also attempts to establish a WiFi connection is not appropriate for your special platform.
Also, google.com is a bad example as a target of a web client because it redirects to a https:// address.
This new broad Arduino Uno Wifi never use but cannot work any connect to network by script.
I would like some people help me for verification this broad fail or good this would like my make robot for my son is student project.
I bought an Arduino Uno WiFi Developer Edition and everything seems to be working well -- I'm able to upload and run programs, read sensors that I plug in, etc. However, I'm not able to connect my Arduino to WiFi, or even run the example code provided in the Arduino IDE menu in File > Examples > WiFi Link. Running CheckWiFiLinkFirmwareVersion prints the welcome message "WiFi Link firmware check." but the program stops after that without printing any errors. The Uno WiFi has the ESP8266 chip so the WiFi link library should work, but I have also tried all the other WiFi libraries I could find by typing WiFi into the library manager window in Sketch > Include Library > Manage Libraries.
