Arduino Uno Wifi Rev2 and temperature
Hello everyone!
I'm trying to make temperature station.
I successfully made temperature sensor, which sends temperature information to Thingspeak.
Now I'm trying to send that data to MySQL.
So there are two methods:
  • Php to MySQL
  • Straight to to the MySQL.
I tried PHP to MySQL with this guide: https://www.instructables.com/id/PART-1-Send-Arduino-data-to-the-Web-PHP-MySQL-D3js/
But It didn't work.
Second method:
I have Raspberry Pi and I have installed Apache, MySQL and Phpmyadmin. I can contact to them correctfully but I can't connect to it with my Raspberry. It just doesn't work.
What is best method to send my data to MySQL and do you have any guides?
Here is my code to ThingSpeak, which works correctfully:
#include <WiFiNINA.h>
#define analogPin  A0 //the thermistor attach to
#define beta 4090 //the beta of the thermistor
#define resistance 10 //the value of the pull-up resistor
String apiKey = "XXXXXXXXXXXXXXX"; //API key from ThingSpeak channel
const char* ssid = "ZyXEL"; //SSID of your wifi
const char* password = "testi123"; //password of your wifi
int duration=5;//delay between each data measure and uploading
const char* server = "api.thingspeak.com";
WiFiClient client; //Start clinet
  WiFi.begin(ssid, password);
  Serial.print("Connecting to ");
  Serial.println(ssid);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  //read thermistor value
  long a =analogRead(analogPin);
  //the calculating formula of temperature
  float tempC = beta /(log((1025.0 * 10 / a - 10) / 10) + beta / 298.0) - 273.0;
  float tempF = 1.8*tempC + 32.0;
  delay(200); //wait for 100 milliseconds
  if (client.connect(server, 80)) {
    String postStr = apiKey;
    postStr += "&field1=";
    postStr += String(tempC);
    postStr += "&field2=";
    postStr += String(tempF);
    postStr += "\r\n\r\n";
    //Uplad the postSting with temperature and Humidity information every
    client.print("POST /update HTTP/1.1\n");
    client.print("Host: api.thingspeak.com\n");
    client.print("Connection: close\n");
    client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
    client.print("Content-Type: application/x-www-form-urlencoded\n");
    client.print("Content-Length: ");
    client.print(postStr.length());
    client.print("\n\n");
    client.print(postStr);
    Serial.print("Temperature: ");
    Serial.print(tempC);
    Serial.print(" degrees Celcius Humidity: ");
    Serial.print(tempF);
    Serial.println("% send to Thingspeak");
  client.stop();
  Serial.println("Waiting…");
  // thingspeak needs minimum 15 sec delay between updates
  delay(duration*1000);
Show the code (your method 2) that you attempted to use to contact your raspberry pi (apache/mysql/php server).
Try (a) changing the code (c++ and php) to use the HTTP GET method instead of POST then (b) attempt to issue a command in a web browser (in the same network as the raspberry pi and the arduino wifi) which adds a record to the raspberry mysql database.
