Arduino UNO with Sparkfun ARGOS Satellite Transceiver Shield
I'm new to this forum so please correct me if i have formatting issues.
I'm having trouble connecting arduino Uno with the Sparkfun ARGOS Satellite Transceiver Shield. I tried to transmit signals to the Argos, but failed.
I will be very grateful for any suggestions!
ARTIC : Arduino
GND : GND
VUSB : 5V
SCLK : 13 (SCK)
CIPO : 12 (MISO)
COPI : 11 (MOSI)
CS : 10(SS)
G8 : 3
BOOT : 4
INT1 : 5
INT2 : 6
RESETB : 7
PWR_EN : 8
RF_EN : 9
const uint8_t Nx32_bits = 8; // In this example, transmit the maximum amount of data
// The user data. Note: only the least-significant 24 bits of userData[0] are transmitted.
const uint32_t userData[Nx32_bits] = {0x00111213, 0x21222324, 0x31323334, 0x41424344, 0x51525354, 0x61626364, 0x71727374, 0x81828384};
const unsigned long repetitionPeriod = 50000; // Define the repetition period in milliseconds
const uint32_t tcxoWarmupTime = 10; // Define the TCXO warmup time
#include <SPI.h>
#include "SparkFun_ARGOS_ARTIC_R2_Arduino_Library.h" // Click here to get the library: http://librarymanager/All#SparkFun_ARGOS_ARTIC_R2
ARTIC_R2 myARTIC;
// Pin assignments for the SparkFun Thing Plus - Artemis
// (Change these if required)
int CS_Pin = 10;
int GAIN8_Pin = 3; // Optional. Set to -1 if you don't want to control the gain. The library defaults to maximum power.
int BOOT_Pin = 4;
int INT1_Pin = 5;
int INT2_Pin = 6;
int RESET_Pin = 7;
#ifdef IOTA
int IOTA_PWR_EN_Pin = 8; // IOTA has a single power enable pin
#else
int ARTIC_PWR_EN_Pin = 8; // The ARTIC R2 Breakout has separate enables for the ARTIC and the RF Amplifier
int RF_PWR_EN_Pin = 9;
#endif
// Loop Steps - these are used by the switch/case in the main loop
// This structure makes it easy to jump between any of the steps
enum {
  configure_ARTIC,     // Configure the ARTIC (set the satellite detection timeout and TX mode)
  ARTIC_TX,            // Start the ARTIC TX
  wait_for_ARTIC_TX,   // Wait for the ARTIC to transmit
} loop_steps;
int loop_step = configure_ARTIC; // Make sure loop_step is set to configure_ARTIC
// AS3-SP-516-274-CNES specifies a ±10% 'jitter' on the repetition period to reduce the risk of transmission collisions
unsigned long nextTransmitTime; // Time of the next satellite transmission (before jitter is added)
unsigned long nextTransmitTimeActual; // Actual time of the next satellite transmission (including jitter)
  Serial.println(F("ARGOS ARTIC R2 Example"));
  SPI.begin();
  // Uncomment the next line to enable the helpful debug messages
  //myARTIC.enableDebugging(); // Enable debug messages to Serial
  Serial.println(F("Starting the ARTIC R2..."));
  // Begin the ARTIC: enable power and upload firmware or boot from flash
#ifdef IOTA
  if (myARTIC.beginIOTA(CS_Pin, RESET_Pin, BOOT_Pin, IOTA_PWR_EN_Pin, INT1_Pin, INT2_Pin, GAIN8_Pin) == false)
#else
  if (myARTIC.begin(CS_Pin, RESET_Pin, BOOT_Pin, ARTIC_PWR_EN_Pin, RF_PWR_EN_Pin, INT1_Pin, INT2_Pin, GAIN8_Pin) == false)
#endif
    Serial.println("ARTIC R2 not detected. Freezing...");
    while (1)
      ; // Do nothing more
  // From v1.1.0: we were instructed by Kineis to ensure the Platform ID was written into each module
  // and not stored in a configuration file accessible to standard users. To comply with this, SparkFun
  // ARTIC R2 boards are now shipped with the Platform ID programmed into PMEM. Customers who have
  // earlier versions of the board will need to use version 1.0.9 of the library.
  uint32_t platformID = myARTIC.readPlatformID();
  if (platformID == 0)
    Serial.println(F("You appear to have an early version of the SparkFun board."));
    Serial.println(F("Please use the Library Manager to select version 1.0.9 of this library."));
    Serial.println(F("Freezing..."));
    while (1)
    Serial.print(F("Your Platform ID is: 0x"));
    Serial.println(platformID, HEX);
  // Define the time of the first transmit
  nextTransmitTime = repetitionPeriod;
  nextTransmitTimeActual = nextTransmitTime - tcxoWarmupTime; // Start the transmit early to compensate for the TCXO warmup time
  // loop is one large switch/case that controls the sequencing of the code
  switch (loop_step) {
    case configure_ARTIC:
      // Set the TCXO voltage to 1.8V and autoDisable to 1
      if (myARTIC.setTCXOControl(1.8, true) == false)
        Serial.println("setTCXOControl failed. Freezing...");
        while (1)
      // Set the TCXO warm-up time
      if (myARTIC.setTCXOWarmupTime(tcxoWarmupTime) == false)
        Serial.println("setTCXOWarmupTime failed. Freezing...");
        while (1)
      // Set the satellite detection timeout to 60 seconds
      if (myARTIC.setSatelliteDetectionTimeout(60) == false)
        Serial.println("setSatelliteDetectionTimeout failed. Freezing...");
        while (1)
      // Set the TX mode to ARGOS 3 PTT-A3
      ARTIC_R2_MCU_Command_Result result = myARTIC.sendConfigurationCommand(CONFIG_CMD_SET_PTT_A3_TX_MODE);
      myARTIC.printCommandResult(result); // Pretty-print the command result to Serial
      if (result != ARTIC_R2_MCU_COMMAND_ACCEPTED)
        Serial.println("sendConfigurationCommand failed. Freezing...");
        while (1)
      // Read and print the ARGOS configuration
      ARGOS_Configuration_Register configuration;
      myARTIC.readARGOSconfiguration(&configuration);
      myARTIC.printARGOSconfiguration(configuration);
      // Set the ARGOS PTT A3 frequency to 401.630 MHz
      // From AS3-SP-516-274-CNES:
      // The transmitted frequency for PTT/PMT-A3 in the ARGOS 4 system is set between 399.90 MHz to 401.69 MHz
      // Due to frequency regulations, the frequency ranges [400.05 MHz to 401.0 MHz] and [401.2 MHz to 401.3 MHz] are forbidden for VLD-A4 transmissions.
      if (myARTIC.setARGOS23TxFrequency(401.630) == false)
        Serial.println("setARGOS23TxFrequency failed. Freezing...");
        while (1)
      // Print the TX frequency
      float tx23freq = myARTIC.getARGOS23TxFrequency();
      Serial.print(F("The ARGOS 2/3 TX Frequency is "));
      Serial.print(tx23freq, 3);
      Serial.println(F(" MHz."));
      loop_step = ARTIC_TX; // Move on
    // Start the ARTIC in Transmit One Package And Go Idle mode
    case ARTIC_TX:
      // Configure the Tx payload for ARGOS PTT A3 using the platform ID and the defined user data
      // From v1.1.0 of the library, the platform ID is stored in PMEM and, for this example, should be 0x01234567
      if (myARTIC.setPayloadARGOS3(Nx32_bits, (uint32_t *)&userData) == false)
        Serial.println(F("setPayloadARGOS3 failed!"));
        // Read the payload back again and print it
        myARTIC.readTxPayload();
        myARTIC.printTxPayload();
        while (1)
      // Wait for the next repetition period
      while (nextTransmitTimeActual > millis())
        if ((millis() % 1000) < 50) // Print how long it is until the next transmit
          Serial.print(F("The next transmit will take place in "));
          unsigned long remaining = (nextTransmitTimeActual - millis()) / 1000;
          Serial.print(remaining);
          Serial.println(F(" seconds"));
        delay(50);
      nextTransmitTime += repetitionPeriod;
      nextTransmitTimeActual = nextTransmitTime + random((-0.1 * repetitionPeriod), (0.1 * repetitionPeriod));
      nextTransmitTimeActual -= tcxoWarmupTime; // Start the transmit early to compensate for the TCXO warmup time
      // Tell the ARTIC to do its thing!
      ARTIC_R2_MCU_Command_Result result = myARTIC.sendMCUinstruction(INST_TRANSMIT_ONE_PACKAGE_AND_GO_IDLE);
        Serial.println("sendMCUinstruction(INST_TRANSMIT_ONE_PACKAGE_AND_GO_IDLE) failed!");
        ARTIC_R2_Firmware_Status status;
        myARTIC.readStatusRegister(&status); // Read the ARTIC R2 status register
        Serial.println(F("ARTIC R2 Firmware Status:"));
        myARTIC.printFirmwareStatus(status); // Pretty-print the firmware status to Serial
        Serial.println(F("ARTIC_R2_MCU_Command_Result:"));
        Serial.println("Freezing...");
        while (1)
      loop_step = wait_for_ARTIC_TX; // Move on
    case wait_for_ARTIC_TX:
      delay(1000); // Check the status every second
      // Read and print the ARTIC R2 status register
      if (status.STATUS_REGISTER_BITS.DSP2MCU_INT1) // Check the interrupt 1 flag. This will go high when TX is finished
        Serial.println(F("INT1 pin is high. TX is finished (or MCU is in IDLE_STATE)!"));
      if (status.STATUS_REGISTER_BITS.DSP2MCU_INT2) // Check the interrupt 2 flag. This will go high when if the message was invalid
        Serial.println(F("INT2 pin is high. TX message was invalid! (Something really bad must have happened...)"));
      // Read and print the instruction progress
      ARTIC_R2_MCU_Instruction_Progress progress;
      // checkMCUinstructionProgress will return true if the instruction is complete
      boolean instructionComplete = myARTIC.checkMCUinstructionProgress(&progress); // Check the instruction progress
      Serial.println(F("ARTIC R2 instruction progress:"));
      myARTIC.printInstructionProgress(progress); // Pretty-print the progress to Serial
      if (instructionComplete)
        Serial.println(F("Transmission is complete!"));
        Serial.println(F("Clearing INT1."));
        // Clear INT1
        if (myARTIC.clearInterrupts(1) == false)
          Serial.println("clearInterrupts failed! Freezing...");
          while (1)
        loop_step = ARTIC_TX; // Do over...
Welcome to the forum.
Please edit your post, select all code and click the </> button. Next save your post.
Thanks for your reminding!
How are you powering your project/
Can you please post a circuit diagram of your project?
A hand drawn image would be fine, include component names and pin labels as well as your power supply.
Can you please post a link to the satellite shield data/specs?
Thanks.. Tom.... :smiley: :+1: :coffee: :australia:
Thanks for your question. Sparkfun ARGOS Satellite Transceiver Shield link is ARGOS Satellite Transceiver Shield - ARTIC R2 - SPX-17236 - SparkFun Electronics. I powered the arduino and Argos satellite Transceiver Shield with DC power supply 3.3v. The pin connection is blew.
Satellite board to Arduino Uno
GND : GND
VUSB : 5V
SCLK : 13 (SCK)
CIPO : 12 (MISO)
COPI : 11 (MOSI)
CS : 10(SS)
G8 : 3
BOOT : 4
INT1 : 5
INT2 : 6
RESETB : 7
PWR_EN : 8
RF_EN : 9
What current rating?
Do you have enough current for the shield on TX.
What antenna are you using?
A diagram would be better...
Do you know if you failed to TX or recieve?
Tom... :smiley: :+1: :coffee: :australia:
Hello,
I don't have a schematic, but I show the sketch blew.
You can not power an Uno with 3 3V; it needs 5V (on the 5V pin or USB). The Vin pin needs at least 7V.
Be careful; it's in my opinion not advisable to power the Uno with 5V on Vin and be connected over USB to a PC at the same time.
PLEASE draw a circuit diagram with pen and paper and include you power supply and how you have it connected.
As you are using the serial port of the UNO it is being powered by your PC's 5V supply.
You do not need the connection between Vin and the 3V3 power supply, it does nothing.
Keep the gnd connections between UNO and shield.
Do you have a DMM?
Can you please post an image(s) of your project so we can see your component layout.
What are you using to connect the UNO to the shield?
