Arduino Uno with SparkFun OpenLog MicroSD code not working
Hi, everyone! I have an Arduino Uno R3, and I've connected a SparkFun OpenLog to it. My setup is like this:
I managed to get power to the open log, and right now, it just has one solid blue light. The text files that are supposed to be created in the microSD I've plugged into the open log are being created. However, when I run the sample programs, It never gets past the initial part for the SD card. The error I get depends on the sample program I get.
This is what I get when I run the SerialPort ReadWriteTest
Arduino: 1.8.13 (Windows Store 1.8.39.0) (Windows 10), Board: "Arduino Uno"
In file included from C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\SerialPort\examples\ReadWriteTest\ReadWriteTest.pde:2:0:
C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\SerialPort/SerialPort.h: In member function 'size_t SerialPort<PortNumber, RxBufSize, TxBufSize>::write(const __FlashStringHelper*)':
C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\SerialPort/SerialPort.h:583:11: error: 'prog_char' does not name a type; did you mean 'putchar'?
     const prog_char* p = (const prog_char*)s;
           putchar
C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\SerialPort/SerialPort.h:584:25: error: 'p' was not declared in this scope
     size_t n = strlen_P(p);
C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\SerialPort\examples\ReadWriteTest\ReadWriteTest.pde: In function 'void loop()':
ReadWriteTest:26:21: error: 'class SerialPort<0, 16, 16>' has no member named 'getRxError'; did you mean 'getWriteError'?
   uint8_t e = port0.getRxError();
                     getWriteError
ReadWriteTest:30:11: error: 'class SerialPort<0, 16, 16>' has no member named 'clearRxError'; did you mean 'clearWriteError'?
     port0.clearRxError();
           clearWriteError
exit status 1
Invalid library found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\firmware: no headers files (.h) found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\firmware
Invalid library found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog: no headers files (.h) found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog
Invalid library found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_Benchmarking: no headers files (.h) found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_Benchmarking
Invalid library found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_CommandTest: no headers files (.h) found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_CommandTest
Invalid library found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_Light: no headers files (.h) found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_Light
Invalid library found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_Minimal: no headers files (.h) found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_Minimal
Invalid library found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_ReadExample: no headers files (.h) found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_ReadExample
Invalid library found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_ReadExample_LargeFile: no headers files (.h) found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_ReadExample_LargeFile
Invalid library found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_Test_Sketch: no headers files (.h) found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_Test_Sketch
Invalid library found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_Test_Sketch_Binary: no headers files (.h) found in C:\Users\sasuk\OneDrive\Documents\Arduino\libraries\OpenLog_Test_Sketch_Binary
option enabled in File -> Preferences.
Just off hand, it looks like a mismatch between the sketch and the library, i.e. the library isn't the one the sketch is written for.
Ah, I see. Do you know which code I'm supposed to use with the OpenLog?
Did you install the SerialPort library?
Did you read this all the way through.
https://learn.sparkfun.com/tutorials/openlog-hookup-guide
