Ошибка при загрузке скетча в Arduino UNO
Вот то что выдаёт, если что использую визуальную среду программирования OmegaBot IDE, когда её скачивал там же и ардуино скачал.
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\Dimac\AppData\Local\Temp\arduino_build_576507/Scetch_test.ino.hex"
avrdude: writing flash (444 bytes):
Writing | ################################################## | 100% 0.07s
avrdude: 444 bytes of flash written
avrdude: verifying flash memory against C:\Users\Dimac\AppData\Local\Temp\arduino_build_576507/Scetch_test.ino.hex:
avrdude: load data flash data from input file C:\Users\Dimac\AppData\Local\Temp\arduino_build_576507/Scetch_test.ino.hex:
avrdude: input file C:\Users\Dimac\AppData\Local\Temp\arduino_build_576507/Scetch_test.ino.hex contains 444 bytes
avrdude: reading on-chip flash data:
Произошла ошибка при загрузке скетча
Reading | ################################################## | 100% 0.06s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x62 != 0x0c
avrdude: verification error; content mismatch
avrdude done.  Thank you.
Спасибо за вариант решения, но к сожалению дата когда придёт USBasp для меня не подходит. Так же хотел уточнить что с другого ноутбука к которому у меня нет доступа всё прекрасно работало.
Привет, @offchik. В качестве альтернативы USBasp, если у вас есть лишняя плата Arduino, вы можете сделать из нее программатор "Arduino as ISP" своими руками:
https://docs.arduino.cc/built-in-examples/arduino-isp/ArduinoISP/
Вот такое вот мне выдало когда попытался записать загрузчик, прикреплю ещё и фото того что пришло.
Прошу помогите, мне очень срочно нужна помощь!
Возможно, вы сможете исправить это, установив драйвер.
Я предоставил инструкции, как это сделать, здесь:
Дорогие друзья вопрос решился после применения этих двух шагов что мне посоветовали.
