Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x29
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x79
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x65
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x70
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x68
An error occurred while uploading the sketch
option enabled in File -> Preferences.
If using windows, does the Uno show up on device manager as a COM port ?
If yes, is that port configured in the IDE ?
If not, you'll need drivers, Chinese clones use a usb chip that need the correct driver, tell us more about your Uno, probably a pic or a link to your board will do.
Скетч использует 11534 байт (35%) памяти устройства. Всего доступно 32256 байт.
Глобальные переменные используют 814 байт (39%) динамической памяти, оставляя 1234 байт для локальных переменных. Максимум: 2048 байт.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x42
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x42
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xff
Проблема загрузки в плату. Помощь по загрузке: http://www.arduino.cc/en/Guide/Troubleshooting#upload .
What's wrong?
