Can somebody help me with this error code
I dont know what to do. I cant upload any codes to my arduino uno. Heres the error code:
Arduino: 1.8.18 (Windows 10), Board: "Arduino Uno"
Sketch uses 5406 bytes (16%) of program storage space. Maximum is 32256 bytes.
Global variables use 515 bytes (25%) of dynamic memory, leaving 1533 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x58
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x58
Welcome to the forum
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
Hi @goodprogrammer153 ,
did you already try to change the USB cable? Just to make sure not to spend unnecessary time...
If you did without success you may read this
https://support.arduino.cc/hc/en-us/articles/4401874331410--Error-avrdude-when-uploading#avrdude-stk500_recv-and-stk500_getsync
or
https://forum.arduino.cc/t/sync-uploading-error-uno-clone/1250386
to find a solution...
Good luck!
ec2021
Have you EVER been able to do it using the same configuration (PC, IDE, USB port, cable, Arduino board)?
Are you using a genuine board, or a clone?
i am using i think a clone its called elegoo uno. but i have been able to run codes until this time
