My IDE 1.8.19 was working fine until I updated some of the libraries. Since then, nothing can upload, including previous loads and boards. Error message:
Arduino: 1.8.19 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\don\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\don\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\don\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\don\AppData\Local\Temp\arduino_build_983407 -warnings=none -build-cache C:\Users\don\AppData\Local\Temp\arduino_cache_825885 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\don\Documents\Arduino\sketches\Vehicle2\DHT11\DHT11.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\don\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\don\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\don\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\don\AppData\Local\Temp\arduino_build_983407 -warnings=none -build-cache C:\Users\don\AppData\Local\Temp\arduino_cache_825885 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\don\Documents\Arduino\sketches\Vehicle2\DHT11\DHT11.ino
Using board 'nano' from platform in folder: C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Using core 'arduino' from platform in folder: C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Detecting libraries used...
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\sketch\DHT11.ino.cpp" -o nul
Alternatives for DHT.h: [DHT_sensor_library@1.4.2]
ResolveLibrary(DHT.h)
-> candidates: [DHT_sensor_library@1.4.2]
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\sketch\DHT11.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.10.14]
ResolveLibrary(Adafruit_GFX.h)
-> candidates: [Adafruit_GFX_Library@1.10.14]
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\sketch\DHT11.ino.cpp" -o nul
Alternatives for Adafruit_SSD1306.h: [Adafruit_SSD1306@2.5.3]
ResolveLibrary(Adafruit_SSD1306.h)
-> candidates: [Adafruit_SSD1306@2.5.3]
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\sketch\DHT11.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\sketch\DHT11.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\sketch\DHT11.ino.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "C:\Users\don\Documents\Arduino\libraries\DHT_sensor_library\DHT.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "C:\Users\don\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp" -o nul
Alternatives for Adafruit_Sensor.h: [Adafruit_Unified_Sensor@1.1.5]
ResolveLibrary(Adafruit_Sensor.h)
-> candidates: [Adafruit_Unified_Sensor@1.1.5]
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "C:\Users\don\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "C:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "C:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.11.3]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit_BusIO@1.11.3]
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library\glcdfont.c" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src\SPI.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src\Wire.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src\utility\twi.c" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor\Adafruit_Sensor.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp" -o nul
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp" -o nul
Generating function prototypes...
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\sketch\DHT11.ino.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\don\AppData\Local\Temp\arduino_build_983407\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\sketch\DHT11.ino.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\sketch\DHT11.ino.cpp.o"
Compiling libraries...
Compiling library "DHT_sensor_library"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\DHT_sensor_library\DHT.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\DHT_sensor_library\DHT.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\DHT_sensor_library\DHT_U.cpp.o"
Compiling library "Adafruit_GFX_Library"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library\glcdfont.c" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_GFX_Library\glcdfont.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp.o"
Compiling library "Adafruit_SSD1306"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp.o"
Compiling library "SPI"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src\SPI.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\SPI\SPI.cpp.o"
Compiling library "Wire"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src\Wire.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Wire\Wire.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src\utility\twi.c" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Wire\utility\twi.c.o"
Compiling library "Adafruit_Unified_Sensor"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor\Adafruit_Sensor.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_Unified_Sensor\Adafruit_Sensor.cpp.o"
Compiling library "Adafruit_BusIO"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "-IC:\Users\don\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI\src" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire\src" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o"
Compiling core...
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring_pulse.S" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring_pulse.S.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\WInterrupts.c" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\WInterrupts.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring_analog.c" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring_analog.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring_pulse.c" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring_pulse.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring_shift.c" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring_shift.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\hooks.c" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\hooks.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring.c" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring_digital.c" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring_digital.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\HardwareSerial.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\HardwareSerial.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\CDC.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\CDC.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\HardwareSerial2.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\HardwareSerial2.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\PluggableUSB.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\PluggableUSB.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\HardwareSerial0.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\HardwareSerial0.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\IPAddress.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\IPAddress.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\HardwareSerial1.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\HardwareSerial1.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\HardwareSerial3.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\HardwareSerial3.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\Print.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\Print.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\Stream.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\Stream.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\Tone.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\Tone.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\WMath.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\WMath.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\USBCore.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\USBCore.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\WString.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\WString.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\abi.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\abi.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\main.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\main.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino" "-IC:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\variants\eightanaloginputs" "C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\new.cpp" -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\new.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring_pulse.S.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\WInterrupts.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\hooks.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring_analog.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring_digital.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring_pulse.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\wiring_shift.c.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\CDC.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\HardwareSerial.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\HardwareSerial0.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\HardwareSerial1.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\HardwareSerial2.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\HardwareSerial3.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\IPAddress.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\PluggableUSB.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\Print.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\Stream.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\Tone.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\USBCore.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\WMath.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\WString.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\abi.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\main.cpp.o"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\core.a" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\core\new.cpp.o"
Archiving built core (caching) in: C:\Users\don\AppData\Local\Temp\arduino_cache_825885\core\core_arduino_avr_nano_cpu_atmega328_5c46d03e415fb43c48af5417dc179069.a
Linking everything together...
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\don\AppData\Local\Temp\arduino_build_983407/DHT11.ino.elf" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\sketch\DHT11.ino.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\DHT_sensor_library\DHT.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\DHT_sensor_library\DHT_U.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_GFX_Library\glcdfont.c.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\SPI\SPI.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Wire\Wire.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Wire\utility\twi.c.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_Unified_Sensor\Adafruit_Sensor.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o" "C:\Users\don\AppData\Local\Temp\arduino_build_983407/core\core.a" "-LC:\Users\don\AppData\Local\Temp\arduino_build_983407" -lm
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\don\AppData\Local\Temp\arduino_build_983407/DHT11.ino.elf" "C:\Users\don\AppData\Local\Temp\arduino_build_983407/DHT11.ino.eep"
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\don\AppData\Local\Temp\arduino_build_983407/DHT11.ino.elf" "C:\Users\don\AppData\Local\Temp\arduino_build_983407/DHT11.ino.hex"
Using library DHT_sensor_library at version 1.4.2 in folder: C:\Users\don\Documents\Arduino\libraries\DHT_sensor_library
Using library Adafruit_GFX_Library at version 1.10.14 in folder: C:\Users\don\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_SSD1306 at version 2.5.3 in folder: C:\Users\don\Documents\Arduino\libraries\Adafruit_SSD1306
Using library SPI at version 1.0 in folder: C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\don\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire
Using library Adafruit_Unified_Sensor at version 1.1.5 in folder: C:\Users\don\Documents\Arduino\libraries\Adafruit_Unified_Sensor
Using library Adafruit_BusIO at version 1.11.3 in folder: C:\Users\don\Documents\Arduino\libraries\Adafruit_BusIO
"C:\Users\don\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\Users\don\AppData\Local\Temp\arduino_build_983407/DHT11.ino.elf"
Sketch uses 15952 bytes (51%) of program storage space. Maximum is 30720 bytes.
Global variables use 568 bytes (27%) of dynamic memory, leaving 1480 bytes for local variables. Maximum is 2048 bytes.
Error downloading https:adafruit.github.io/arduino-board-index/package_adafruit_index.json
An error occurred while uploading the sketch
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0c
I downloaded the new IDE 2.0. It does not even give me the option for what port to use. Does it really take 24,000 files to run IDE 2.0?
As of now, I am stopped completely with my Arduino projects.
