Problema con le porte com
ciao
Oggi window 10 si e’ aggiornato e ultima volta che ho caricato sketch e’ stato qualche sett fa’
ho provato diversi cavi e porte ma senza risultato usando i due ide di arduino
1.8.19
e
Version: 2.3.6
Date: 2025-04-09T11:26:55.498Z
CLI Version: 1.2.0
Copyright © 2025 Arduino SA
Sotto l errore con ide 1.8.19
Arduino: 1.8.19 (Windows 10), Board: "Arduino Nano, ATmega328P"
D:\Downloads\arduino-1.8.19-windows\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware D:\Downloads\arduino-1.8.19-windows\arduino-1.8.19\hardware -hardware C:\Users\stefano\AppData\Local\Arduino15\packages -tools D:\Downloads\arduino-1.8.19-windows\arduino-1.8.19\tools-builder -tools D:\Downloads\arduino-1.8.19-windows\arduino-1.8.19\hardware\tools\avr -tools C:\Users\stefano\AppData\Local\Arduino15\packages -built-in-libraries D:\Downloads\arduino-1.8.19-windows\arduino-1.8.19\libraries -libraries D:\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\stefano\AppData\Local\Temp\arduino_build_243063 -warnings=none -build-cache C:\Users\stefano\AppData\Local\Temp\arduino_cache_935509 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose D:\Documents\Arduino\libraries\Adafruit_VL53L0X\examples\vl53l0x\vl53l0x.ino
D:\Downloads\arduino-1.8.19-windows\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware D:\Downloads\arduino-1.8.19-windows\arduino-1.8.19\hardware -hardware C:\Users\stefano\AppData\Local\Arduino15\packages -tools D:\Downloads\arduino-1.8.19-windows\arduino-1.8.19\tools-builder -tools D:\Downloads\arduino-1.8.19-windows\arduino-1.8.19\hardware\tools\avr -tools C:\Users\stefano\AppData\Local\Arduino15\packages -built-in-libraries D:\Downloads\arduino-1.8.19-windows\arduino-1.8.19\libraries -libraries D:\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\stefano\AppData\Local\Temp\arduino_build_243063 -warnings=none -build-cache C:\Users\stefano\AppData\Local\Temp\arduino_cache_935509 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose D:\Documents\Arduino\libraries\Adafruit_VL53L0X\examples\vl53l0x\vl53l0x.ino
Using board 'nano' from platform in folder: C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\sketch\\vl53l0x.ino.cpp" -o nul
Alternatives for Adafruit_VL53L0X.h: [Adafruit_VL53L0X@1.2.4]
ResolveLibrary(Adafruit_VL53L0X.h)
  -> candidates: [Adafruit_VL53L0X@1.2.4]
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\sketch\\vl53l0x.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\sketch\\vl53l0x.ino.cpp" -o nul
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\Adafruit_VL53L0X.cpp" -o nul
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\core\\src\\vl53l0x_api.cpp" -o nul
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\core\\src\\vl53l0x_api_calibration.cpp" -o nul
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\core\\src\\vl53l0x_api_core.cpp" -o nul
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\core\\src\\vl53l0x_api_ranging.cpp" -o nul
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\core\\src\\vl53l0x_api_strings.cpp" -o nul
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\platform\\src\\vl53l0x_i2c_comms.cpp" -o nul
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\platform\\src\\vl53l0x_platform.cpp" -o nul
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\utility\\twi.c" -o nul
Generating function prototypes...
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\sketch\\vl53l0x.ino.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\sketch\\vl53l0x.ino.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\sketch\\vl53l0x.ino.cpp.o"
Compiling libraries...
Compiling library "Adafruit_VL53L0X"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\Adafruit_VL53L0X.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\Adafruit_VL53L0X.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\core\\src\\vl53l0x_api.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\core\\src\\vl53l0x_api.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\core\\src\\vl53l0x_api_ranging.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\core\\src\\vl53l0x_api_ranging.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\core\\src\\vl53l0x_api_calibration.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\core\\src\\vl53l0x_api_calibration.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\core\\src\\vl53l0x_api_strings.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\core\\src\\vl53l0x_api_strings.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\core\\src\\vl53l0x_api_core.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\core\\src\\vl53l0x_api_core.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\platform\\src\\vl53l0x_i2c_comms.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\platform\\src\\vl53l0x_i2c_comms.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "D:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src\\platform\\src\\vl53l0x_platform.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\platform\\src\\vl53l0x_platform.cpp.o"
Compiling library "Wire"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Wire\\Wire.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-ID:\\Documents\\Arduino\\libraries\\Adafruit_VL53L0X\\src" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\utility\\twi.c" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Wire\\utility\\twi.c.o"
Compiling core...
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring_pulse.S.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring_digital.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring_pulse.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring.c" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\WInterrupts.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring_shift.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring_analog.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\hooks.c" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\hooks.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\CDC.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\HardwareSerial.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\IPAddress.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\PluggableUSB.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Print.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\Print.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\Stream.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\Tone.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\USBCore.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\WMath.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WString.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\WString.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\abi.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\abi.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\main.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\main.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\new.cpp" -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\new.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring_pulse.S.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\WInterrupts.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\hooks.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring_analog.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring_digital.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring_pulse.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\wiring_shift.c.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\CDC.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\HardwareSerial.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\IPAddress.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\PluggableUSB.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\Print.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\Stream.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\Tone.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\USBCore.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\WMath.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\WString.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\abi.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\main.cpp.o"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\core.a" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\core\\new.cpp.o"
Archiving built core (caching) in: C:\Users\stefano\AppData\Local\Temp\arduino_cache_935509\core\core_arduino_avr_nano_cpu_atmega328_c0a926c296899de7529009f4d39f3f12.a
Linking everything together...
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063/vl53l0x.ino.elf" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\sketch\\vl53l0x.ino.cpp.o" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\Adafruit_VL53L0X.cpp.o" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\core\\src\\vl53l0x_api.cpp.o" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\core\\src\\vl53l0x_api_calibration.cpp.o" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\core\\src\\vl53l0x_api_core.cpp.o" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\core\\src\\vl53l0x_api_ranging.cpp.o" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\core\\src\\vl53l0x_api_strings.cpp.o" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\platform\\src\\vl53l0x_i2c_comms.cpp.o" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Adafruit_VL53L0X\\platform\\src\\vl53l0x_platform.cpp.o" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063/core\\core.a" "-LC:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063" -lm
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063/vl53l0x.ino.elf" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063/vl53l0x.ino.eep"
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063/vl53l0x.ino.elf" "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063/vl53l0x.ino.hex"
Using library Adafruit_VL53L0X at version 1.2.4 in folder: D:\Documents\Arduino\libraries\Adafruit_VL53L0X
Using library Wire at version 1.0 in folder: C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
"C:\\Users\\stefano\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\stefano\\AppData\\Local\\Temp\\arduino_build_243063/vl53l0x.ino.elf"
Sketch uses 17248 bytes (56%) of program storage space. Maximum is 30720 bytes.
Global variables use 1236 bytes (60%) of dynamic memory, leaving 812 bytes for local variables. Maximum is 2048 bytes.
C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\stefano\AppData\Local\Temp\arduino_build_243063/vl53l0x.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\stefano\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't set com-state for "\\.\COM4"
avrdude done.  Thank you.
An error occurred while uploading the sketch
ho anche guardato dentro il device manager ma i driver mi dice che sono aggiornati
avete qualche suggerimento?
grazie
stefano
ciao
sotto due immagini prima e dopo aver collegato il cavo, da quello che vedo la board dovrebbe essere collegata
sotto quello che mi dice gemini
This message, "avrdude: ser_open(): can't set com-state for "\.\COM4" usually means the AVRDUDE software, used for uploading code to an AVR microcontroller (like those on Arduino boards), is unable to open or properly configure the specified serial port, which in this case is COM4.
Here are the most common reasons and solutions:
1. Common Causes
Port is Already in Use: Another program (like the Arduino IDE's Serial Monitor, another IDE, or a utility) is currently connected to and using COM4.
Incorrect Port/Board Selection: The port you selected in the IDE or specified in the command line is wrong, or the wrong board type is selected.
Missing or Incorrect Drivers: The drivers for the USB-to-Serial chip on your microcontroller board (e.g., FTDI, CH340G, or WCH) are not installed or are corrupted.
Cable or Hardware Issue: The USB cable is faulty, or the board is not properly plugged in or powered.
Administrative Permissions: On some systems, AVRDUDE may not have the necessary permissions to access the serial port's configuration.
2. Solutions and Troubleshooting Steps
🛠️ Check Port Availability
Close the Serial Monitor: If you have the Arduino IDE open, make sure the Serial Monitor or Serial Plotter window is completely closed. Only one application can use a serial port at a time.
Restart the IDE: Close and reopen the Arduino IDE or whatever software you are using.
Check Other Programs: Close any other software that might be communicating with a serial port, such as terminal programs (PuTTY, Tera Term), other IDEs, or custom scripts.
🔌 Verify Connections and Drivers
Unplug and Replug: Disconnect the microcontroller board from the USB port and plug it back into a different USB port on your computer. This often forces the operating system to re-recognize the device.
Change the Cable: Faulty or "charge-only" USB cables are a frequent cause of connection issues. Try a different, known-good data-capable USB cable.
Check Drivers: Open your computer's Device Manager (on Windows) and look under Ports (COM & LPT).
If you don't see the board listed when it's plugged in, the drivers are likely the issue.
Search for and install the appropriate drivers for the specific USB-to-Serial chip on your board (e.g., CH340G driver, CP210x driver, or FTDI driver).
⚙️ Confirm IDE Settings
Select the Correct Port: In your IDE (e.g., Arduino IDE), go to Tools > Port and ensure that COM4 is actually the correct port for your device. The port number often changes if you plug the board into a different USB slot. Try the other available COM ports if you're unsure.
Select the Correct Board: Double-check that the correct Board type (e.g., Arduino Uno, Mega, etc.) is selected under Tools > Board.
💻 Permissions (Less Common)
Run as Administrator: If the above steps fail, try closing the IDE and running it again with "Run as administrator" (right-click the shortcut/executable). This ensures the software has the necessary permissions to configure the serial port's state.
unica cosa rimasta e’ disintallare e reinstallare driver
ciao
ho seguito questo link
https://support.arduino.cc/hc/en-us/articles/13148652511260-avrdude-ser-open-can-t-set-com-state-for-COMn?_gl=1rwh49x_upMQ.._gaODQ3MDYyNDg1LjE3NjA4NjI2Nzk._ga_NEXN8H46L5*czE3NjA4NjI2NzkkbzEkZzAkdDE3NjA4NjI2NzkkajYwJGwwJGgxMzAyOTUzOTU1
tornando indietro a versioni precedenti del driver
adesso ha caricato lo sketch
stefano
