Arduino vga
OK guys so I finally found a vga output solution for my arduino pc. :slight_smile: Here is the link:Google Code Archive - Long-term storage for Google Code Project Hosting.
But wait...
When you open the program .zip files that are provided, there is always a comment on the top of each program that says cpu board:arduino duemilanove.And I have an arduino uno atmega328p rev 3. :frowning: So I was wondering whether their code would also work with the uno.Also,there is no library download but they have included libraries in their code.I don't know where to download these libraries.Also when I verify the sketch tons of errors pop up.I'm assuming they pop up because I don't have any of the libraries in the example code.Here is the code that I tried verifying.
    System Name : Simple Analog RGB 2013
    File Name   : VGA13_0216.pde
    Content     :
    Version     : 0.0
    CPU board   : Arduino Duemilanove
    Compiler    :
    History     :2013/02/16
;  Copyleft Nabe_RMC
/*  Includes        */
#include "SYSdef.h"
#include "CRTdef.h"
#include "INTdef.h"
#include "CSLdef.h"
/*  DEFINE        */
/*--- blink LED ------------------------------------------------------------*/
#define BLK_LED_CYC_NOM     0x80
/*  Program        */
CSYS objSYS;
CCRT objCRT;
CCSL objCSL;
CINT objINT;
const float pi = 3.14;
const float delta = (2*pi)/VRAM_SIZE;
    objSYS.Ini();               /* re-initialize after Arduini IDE init()   */
    randomSeed(analogRead(0));
    sei();                      /* interrupt enable                         */
	unsigned char ColorData[7] ={	COL_RED, COL_GRN, COL_BLU, COL_YEL,
									COL_CYA, COL_MAG, COL_WHI };
	unsigned char	ColorStart	= COL_BLK;
	unsigned char	ColorEnd1 	= COL_BLK;
	unsigned char	ColorEnd2 	= COL_BLK;
	unsigned short	LineStart;
	unsigned short	LineEnd;
	unsigned short	Position;
	unsigned char 	Data;
	float angle;
	unsigned short i,j;
	objCRT.ChangeMode( CRT_TEXT );
    objCSL.put_char( 0, 0, 'A' );   objSYS.delay66( 5 );
    objCSL.put_char( 1, 0, 'r' );   objSYS.delay66( 5 );
    objCSL.put_char( 2, 0, 'd' );   objSYS.delay66( 5 );
    objCSL.put_char( 3, 0, 'u' );   objSYS.delay66( 5 );
    objCSL.put_char( 4, 0, 'i' );   objSYS.delay66( 5 );
    objCSL.put_char( 5, 0, 'n' );   objSYS.delay66( 5 );
    objCSL.put_char( 6, 0, 'o' );   objSYS.delay66( 10 );
	Data = 0x80;
	while( Data <= 0x8B ){
		for( i = 0; i < 5; i++ ){
			objCSL.put_char( 0, 0, Data );	objCSL.put_char( 1, 0, Data+1 );
			objCSL.put_char( 0, 0, Data+2 );	objCSL.put_char( 1, 0, Data+3 );
			objCSL.set_line_color( 0, ColorData[i] );
		Data +=4;
	objCSL.set_cursor( 0, 1 );
	objCSL.print("2013\n");			objSYS.delay66( 10 );
	objCSL.print("Nabe_RMC\n");		objSYS.delay66( 10 );
	objCRT.ChangeMode( CRT_DRAW );
	for( Position = 0; Position < VRAM_SIZE; Position++ ){	/* vertical line thin	*/
		for( i = 0; i < Position; i++ ){
			if( Position < 200 ){
				vram_data[i] = (unsigned char)Position;
			else{
				vram_data[i] = (400 - Position);
		objSYS.delay66( 1 );
		ColorEnd1 = ColorData[((Position/8) & 0x07)];
		objCRT.set_color( COL_BLK, ColorEnd1, COL_BLK );
	objCRT.clear_screen();
	for( Position = 0; Position < 200; Position++ ){	/* vertical line thick	*/
			vram_data[i] = Position;
		ColorEnd2 = ColorData[((Position+1)/8) & 0x07];
		objCRT.set_color( COL_BLK, ColorEnd1,ColorEnd2 );
	for( Position = 1; Position < VRAM_SIZE; Position++ ){	/* horizontal line	*/
		ColorStart = ColorData[((Position/8) & 0x07)];
		objCRT.set_color( ColorStart, COL_BLK,COL_BLK );
		vram_data[Position-1] = 0xFF;
		vram_data[Position] = (unsigned char)Position;
	angle = 0;
	for( i = 0; i < VRAM_SIZE; i++ ){					/* sine wave line	*/
		Data = (unsigned char)( ( sin( angle ) +1) *100 );
		vram_data[i] = Data;
		ColorEnd1 = ColorData[((i/8) & 0x07)];
		angle += delta;
	for( j = 0; j < 200; j++ ){							/* sine wave line move	*/
		Data = vram_data[0];
		for( i = 0; i < (VRAM_SIZE-1); i++ ){
			vram_data[i] = vram_data[i+1];
		ColorEnd1 = ColorData[((j/8) & 0x07)];
		ColorEnd2 = ColorData[(((j+1)/8) & 0x07)];
		objCRT.set_color( COL_BLK, ColorEnd1, ColorEnd2 );
		vram_data[VRAM_SIZE-1] = Data;
	angle = 0;
	for( i = 0; i < VRAM_SIZE; i++ ){					/* sine draw	*/
		ColorStart = ColorEnd1;
		objCRT.set_color( ColorStart, ColorEnd1, COL_BLK );
		angle += delta;
	for( i = 0; i < 10000; i++ ){						/* put dot		*/
		if( (i%500) == 0 ){
		LineStart = (unsigned char)random( 0, 200 );
		Position = (unsigned short)random( 0, VRAM_SIZE-1 );
		vram_data[Position] = LineStart;
I have one more question and it's pretty dumb.I'm also connecting a ps2 mouse and kbd.Would the input data from the mouse/kbd affect the vga output?
you can unzip the library & upload the code
https://code.google.com/p/arduino-vgaout/downloads/list
still facing library. you can download in above link
VGA13_0216.zip (37.7 KB)
The Duemilanove is pretty close to the Uno. It should probably work.
I don't understand your problem with the libraries. You don't know where to get them from or you have the .zip files and you don't know where they go in your system?
I don't think you can connect a mouse and keyboard to the Uno. A Leonardo can do it.
From the information so far, I would suggest that a Rasberry Pi will do what you want much better.
Where are the libraries?I see code downloads but not libraries.
Morgan S and AMPS-N thanks for the replies :smiley: .I know where to put the libraries when i get them it's just that I don't know where to download them from.The ps2 mouse and kbd work I've already tried it.It sends data back to the serial monitor pretty quickly.I'm not trying to use the ps2 mouse as my computer mouse or kbd as my computer kbd.So i don't need an esplora or a leonardo.
