Arduino with XBee WiFi
Hi!
I need help here. I am doing a project which Android send command to Arduino to light up an LED on pin 13. This is a wireless communication. The problem is the LED on pin13 keep on flashing automatically after I upload the code. It suppose to receive command, then only flash.
Here's my code for arduino:
#include <SPI.h> // needed for Arduino versions later than 0018
#include <WiFi.h>
#include <WiFiUdp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
#include <SoftwareSerial.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {0x90,0xA2,0xDA,0x0D,0x8B,0x8F};
IPAddress ip(192, 168, 1, 105);
IPAddress ip1(192, 168, 1, 1);
WiFiServer server(8032);
unsigned int localPort = 8032;
boolean incoming = 0;
// local port to listen on
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char ReplyBuffer[] = "acknowledged"; // a string to send back
// An EthernetUDP instance to let us send and receive packets over UDP
WiFiUDP Udp;
// start the Ethernet and UDP:
Udp.begin(localPort);
pinMode(13,OUTPUT);
WiFiClient client = server.available();
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
//reads URL string from $ to first blank space
if(incoming && c == ' '){
incoming = 0;
if(c == '$'){
incoming = 1;
//Checks for the URL string $1 or $2
if(incoming == 1){
Serial.println(c);
if(c == 'a'){
Serial.println("ON");
digitalWrite(13, HIGH);
int rd=digitalRead(13);
delay(10);
server.write("ON");
delay(10);
Serial.println(rd);
if(c == 'b'){
Serial.println("OFF");
digitalWrite(13, LOW);
delay(10);
server.write("OFF");
Serial.println(rd);
delay(10);
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(10);
client.stop();
// if there's data available, read a packet
int packetSize = Udp.parsePacket();
Serial.println(packetSize);
if(packetSize)
Serial.print("Received packet of size ");
Serial.print("From ");
IPAddress remote = Udp.remoteIP();
for (int i =0; i < 4; i++)
Serial.print(remote*, DEC);*
  • if (i < 3)*
  • Serial.print(".");*
  • Serial.print(", port ");*
  • Serial.println(Udp.remotePort());*
  • // read the packet into packetBufffer*
  • Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);*
  • Serial.println("Contents:");*
  • Serial.println(packetBuffer);*
  • Serial.println(packetBuffer[0]);*
  • if(packetBuffer[0]=='1'){*
  • digitalWrite(13,HIGH);*
  • }else if(packetBuffer[0]=='13'){*
  • digitalWrite(13,LOW);*
  • // send a reply, to the IP address and port that sent us the packet we received*
  • Udp.beginPacket(Udp.remoteIP(),Udp.remotePort());*
  • Udp.write("WAHh BHurA");*
  • Udp.endPacket();*
  • Udp.beginPacket(ip1,8032);*
  • Udp.write(ReplyBuffer);*
  • Udp.endPacket();*
  • delay(400);*
  • client.stop();*
How to use this forum
#7
I don't have errors in my code. I just can't find why the LED on pin13 automatically flashing without receiving commmand from android phone.
rkosharil:
If you're not going to follow simple directions, providing help seems like it wouldn't be effective.
Here's my code:
#include <WiFi.h>
WiFiUDP Udp;
  pinMode(13,OUTPUT);
  if (client) {
          incoming = 0;
        if(c == '
          incoming = 1;
        if(incoming == 1){
          Serial.println(c);
          if(c == 'a'){
            delay(10);
            server.write("ON");
            delay(10);
            Serial.println(rd);
          if(c == 'b'){
            delay(10);
            Serial.println(rd);
            delay(10);
if (c == '\n') {
    delay(10);
    client.stop();
if(packetSize)
      Serial.print(remote[i], DEC);
      if (i < 3)
        Serial.print(".");
    Udp.endPacket();
    Udp.endPacket();
  delay(400);
  client.stop();
