Arduino won't compile. I get error message
runtime stack:
runtime.throw(0x18113e, 0x21)
/home/jenkins/go/src/runtime/panic.go:566 +0x95 fp=0x7ff7bfeff680 sp=0x7ff7bfeff660
runtime.goenvs()
/home/jenkins/go/src/runtime/os_darwin.go:88 +0xa0 fp=0x7ff7bfeff6b0 sp=0x7ff7bfeff680
runtime.schedinit()
/home/jenkins/go/src/runtime/proc.go:450 +0x9c fp=0x7ff7bfeff6f0 sp=0x7ff7bfeff6b0
runtime.rt0_go(0x7ff7bfeff728, 0x17, 0x7ff7bfeff728, 0x0, 0x1000, 0x17, 0x7ff7bfeff900, 0x7ff7bfeff938, 0x7ff7bfeff944, 0x7ff7bfeff954, ...)
/home/jenkins/go/src/runtime/asm_amd64.s:145 +0x14f fp=0x7ff7bfeff6f8 sp=0x7ff7bfeff6f0
/Applications/Arduino.app/Contents/Java/arduino-builder returned 2
Error compiling for board Arduino/Genuino Uno.
No clues in your post!
Please post the code, using code tags, the complete error message (also using code tags) and identify the Arduino IDE version.
Please post your code. All of it. Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Can you also tell us what version IDE you are using?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
fatal error: runtime: bsdthread_register error
runtime stack:
	/home/jenkins/go/src/runtime/panic.go:566 +0x95 fp=0x7ff7bfeff6d0 sp=0x7ff7bfeff6b0
runtime.goenvs()
	/home/jenkins/go/src/runtime/os_darwin.go:88 +0xa0 fp=0x7ff7bfeff700 sp=0x7ff7bfeff6d0
runtime.schedinit()
	/home/jenkins/go/src/runtime/proc.go:450 +0x9c fp=0x7ff7bfeff740 sp=0x7ff7bfeff700
runtime.rt0_go(0x7ff7bfeff770, 0x17, 0x7ff7bfeff770, 0x1000, 0x17, 0x7ff7bfeff948, 0x7ff7bfeff980, 0x7ff7bfeff98c, 0x7ff7bfeff99c, 0x7ff7bfeff9a6, ...)
	/home/jenkins/go/src/runtime/asm_amd64.s:145 +0x14f fp=0x7ff7bfeff748 sp=0x7ff7bfeff740
option enabled in File -> Preferences.
```Preformatted text
IDE 1.8.2
Code is blink sketch.```// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
I'm not a Mac person. Search results for arduino bsdthread_register error
runtime stack:
	/home/jenkins/go/src/runtime/panic.go:566 +0x95 fp=0x7ff7bfeff6c0 sp=0x7ff7bfeff6a0
runtime.goenvs()
	/home/jenkins/go/src/runtime/os_darwin.go:88 +0xa0 fp=0x7ff7bfeff6f0 sp=0x7ff7bfeff6c0
runtime.schedinit()
	/home/jenkins/go/src/runtime/proc.go:450 +0x9c fp=0x7ff7bfeff730 sp=0x7ff7bfeff6f0
runtime.rt0_go(0x7ff7bfeff768, 0x17, 0x7ff7bfeff768, 0x0, 0x1000, 0x17, 0x7ff7bfeff940, 0x7ff7bfeff978, 0x7ff7bfeff984, 0x7ff7bfeff994, ...)
	/home/jenkins/go/src/runtime/asm_amd64.s:145 +0x14f fp=0x7ff7bfeff738 sp=0x7ff7bfeff730
Sketch is the blink sketch
Try reinstalling the Arduino IDE.
IED 1.8.2
runtime stack:
runtime.goenvs()
runtime.schedinit()
IDE 1.8.2
runtime stack:
runtime.goenvs()
runtime.schedinit()
Sketch is the blink sketch,
I know absolutely zero about the Mac so my best suggestion is that I second the suggestion from @sterretje to Google "fatal error runtime bsdthread_register error arduino" to see what you can find out. Others have come up with the same error.
It's obviously not a problem with the sketch. So perhaps a moderator could move this thread to a more suitable sub-forum.
This is the best thread that I have found in my searching addressing this Go failure: Mama needs help
That error is from the IDE itself, and has NOTHING to do with the sketch code. There is a problem with the IDE installation. Best chance of fixing it is to uinstall the IDE, and re-install it from scratch with the latest version.
Reinstalled latest version of IDE. Problem solved.
I think problem developed after I had a new solid state hard drive installed into my mini Mac. Thank you all for your help.
Please, next time provide all the details.
You can mark your topic as solved using the solution under the most useful post (yours in this case) so others know that a solution was provided.
