Arduino + XBee Wireless Sensor Network
This project was built as a final project for my CPE400(Computer Networks) class
Remote Node:
Atmega328P
XBee Series 1 modules
TMP36 temperature sensors
misc resistors, caps, etc
Coordinator:
XBee USB adapter
PC Software:
Custom processing application
Data Logging
Schematic
Remote Nodes
Data Logging
YouTube Video
Arduino Code:
//Dino Tinitigan
//Sleeping Node
//Sleep code derived form sleep code from arduino website
//Sends temperature data to coordinator
//Goes back to sleep after sending data
#include <avr/sleep.h>
int wakePin = 2;  // pin used for waking up
int sleepStatus = 0;  // variable to store a request for sleep
int temp1;
int ID = 3;  //ID of node, change this!!!
int ledPin = 3;
double t1;
int temp2;
double vref = 5.04;
void wakeUpNow()        // here the interrupt is handled after wakeup
  // execute code here after wake-up before returning to the loop() function
  // timers and code using timers (serial.print and more...) will not work here.
  // we don't really need to execute any special functions here, since we
  // just want the thing to wake up
  pinMode(ledPin, OUTPUT);
  pinMode(wakePin, INPUT);
  attachInterrupt(0, wakeUpNow, LOW); // use interrupt 0 (pin 2) and run function
                                      // wakeUpNow when pin 2 gets LOW
void sleepNow()         // here we put the arduino to sleep
    //Serial.println("Sleeping");
    digitalWrite(ledPin, LOW);
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);   // sleep mode is set here
    sleep_enable();          // enables the sleep bit in the mcucr register
                             // so sleep is possible. just a safety pin
    attachInterrupt(0,wakeUpNow, LOW); // use interrupt 0 (pin 2) and run function
    sleep_mode();            // here the device is actually put to sleep!!
                             // THE PROGRAM CONTINUES FROM HERE AFTER WAKING UP
    sleep_disable();         // first thing after waking from sleep:
                             // disable sleep...
    detachInterrupt(0);      // disables interrupt 0 on pin 2 so the
                             // wakeUpNow code will not be executed
                             // during normal running time.
  digitalWrite(ledPin, HIGH); //turn led on while awake
  // display information about the counter
  temp1 = getTemp();
  byte checksum = ID + temp1;
  Serial.write(255); //header
  Serial.write(ID); //ID BYTE
  Serial.write(temp1); //DATA BYTE/S
  Serial.write(checksum);
  //Serial.print("I am ");
  //Serial.println(ID);
  delay(3000);
  sleepNow();
int getTemp()
  t1 = analogRead(0);
  t1 = t1*1000; //millivolts factor
  t1 = t1/1024; //10-bit range
  t1 = t1*vref; //vref
  temp2 = (t1-500)/10;
  return temp2;
Processing Code:
//Dino Tinitigan
//CPE 400
//Coordinator Application
import processing.serial.*;
int incoming;
int nodeID;
int value;
int numMembers = 5;
int[] members = {2,3,4,5,6};
int[] values = new int[5];
int checksum;
int t = 5;
int ID;
Serial myPort;
//----File IO---------
//use hour(), minute(), seconds();
//ude date()
PrintWriter output;
  myPort = new Serial(this, Serial.list()[0], 9600);
  println(Serial.list());
  textSize(30);
  size(800, 600);
  background(80, 120, 255);
  //-------------------setup File IO-------------------
  output = createWriter("log.csv");
  output.print("Date and Time," + "millis since start,");
  for(int i = 0; i < numMembers; i++)
    output.print("Node " + i + ",");
  output.println();
void draw()
  if(myPort.available()>0) //data is on serial port
    incoming = myPort.read();
    println("Data Received");
    while((incoming != 255) && myPort.available()>0) //look for header if their is data on serial port
    if(incoming == 255) //header found
      //header received
      println("----------header received-----------");
      nodeID = myPort.read(); //read ID
      value = myPort.read();  //read data
      println("Node " + nodeID);
      println(value + " C");
      updateValue(nodeID, value);
void updateValue(int ID, int val)
  switch(ID)
    case 2:
      int check = myPort.read();
      checksum = ID + val;
      if(checksum >=256)
        checksum = checksum - 256;
      if(checksum == check)
        //draw box
        fill(0,255,0);
        rect(10,10,200, 100);
        fill(0);
        text("Node: " + ID, 30, 40);
        text(val + " C", 30, 100);
        output.print(month() + "/" + day() + "/" + year() + "/" + hour() + ":" + minute() + ":" + second() + "," + millis());
        output.println("," + val);
    case 3:
      if(checksum >=256)
        fill(0,255,0);
        rect(10,200,200, 100);
        fill(0);
        text("Node: " + ID, 30, 225);
        text(val + " C", 30, 285);
        output.println(",," + val);
    case 4:
      if(checksum >=256)
        //draw box
        fill(0,255,0);
        rect(200,10,200, 100);
        fill(0);
        text("Node: " + ID, 220, 40);
        text(val + " C", 220, 100);
        output.println(",,," + val);
    case 5:
      if(checksum >=256)
        fill(0,255,0);
        rect(200,200,200, 100);
        fill(0);
        text("Node: " + ID, 220, 225);
        text(val + " C", 220, 285);
        output.println(",,,," + val);
    case 6:
      if(checksum >=256)
        //draw box
        fill(0,255,0);
        rect(490,10,200, 100);
        fill(0);
        text("Node: " + ID, 510, 40);
        text(val + " C", 510, 100);
        output.println(",,,,," + val);
    default:
  if(key=='x')
    output.close();
    exit();
void keyPressed()
  println("key pressed");
  if(key=='x')
    exit();
void stop()
  output.close();
  super.stop();
