Hi guys. I am looking for some help please.
I have found this video that refers to another video mentioned in tbe comments
It is mentioned a Brokking's video.
Do you know which video is that please?
Thanks
'Do you want us lokking for a vidio or do you have an actual question?
zwieblum:
Someone sent me the link of the video in the comments but after seeing It, It did not help me to figure out how to put in practice the same or a similar project ![]()
My end goal would be to replace the left joystick of the controller , instead of the right , for locomotion purpose using feet.
So the starting point was to understand each single step of the project in the video .
It is not clear to me all the connections on the arduino ![]()
Also i can't see the wire wired on the controller in place of the joystick ![]()
Get a controller, get a voltmeter, soldering iron, wires etc., diassemble the controller and start pooking around. Then start reading. When you have questions left, atart asking by formulating a propper question.
zwieblum:
Get a controller, get a voltmeter, soldering iron, wires etc., diassemble the controller and start pooking around. Then start readin1z weg. When you have questions left, atart asking by formulating a propper question.
I have actually a tons of proper questions.
I am looking also at how to formulate questions regarding coding since i already have softwares that from sensors movements , they output keystrokes that i nusually bind to controllers via virtual controllers . I meed to underatand how i can connect the coding of the video with the hardware/software i use for locomotion.
